Question about Garden
I have a mountfield rotary mower,and i need a new blade but i cannot undoe the existing one.
    President:
  • 2,468 Answers
Are you loosening it the right way?as some have left handed threads and loosen the opposite of a normal right hand thread,otherwise take it to a garage and have them remove it with an impact wrench
Posted on Apr 30, 2010
Can anyone tell me how difficult is it to replace a starter motor for a 1436M mountfield mower
Should be just a matter of undoing the 2 bolts that hold it to the motor undo the wires to the starter,.
Oct 16, 2016 | Garden
How do you replace the piece that the belt an blade are attached to on a mountfield RV 150
you talking about the self propelled model
Repairing Lawnmowers For Profit Part 55 Replace Mountfield Lawnmower Drive...
the blade is a one piece ..you take that off
take off the belt cover
if really stuck .. use a puller for the pully/blade boss
remove the back plate to get to the idler tension pully
there was a tension device or ider pully and spring
for the belt tension
Jul 03, 2016 | Garden
Why wont my mountfield 725m mower go into blade motion
I would check the mower deck itself. This usually happens when it clogs with grass or something got jammed in the belt or pulleys.
Aug 30, 2014 | Garden
MOUNTFIELD R25M RIDE ON MOWER 2008, ONCE STARTED, WONT STOP, HELP PLEASE
On a lot of these small engines, the blade also acts as a kind of flywheel to help smooth out the power stoke from the engine.
result? no blade, or blade very loose, engine can be a right pain to start.
I'm not very familiar with the very new mountfields, but it sounds like a standard briggs engine.
If you follow the cable down from the dead mans handle, it will normally end somewhere on the side of the engine. When you pull the handle in, it pulls back a lever that frees a brake shoe, or sometimes a band, that acts against the flywheel. this mechnism stops the engine a bit quicker than wiothout it. it should also act on a small switch in the same area.
I often find that the switch isn't turning working as it should, and needs a gentle adjustment with a pair of pliers.
have a look at this first, but please tighten that blade up for safetys sake!!!!!!
Buy custom car parts.
Jun 02, 2012 | Husqvarna Garden
Replacement blade for castelgarden C390 lawnmower
What Geographic location please?
UK:
http://www.ebay.co.uk/itm/Mountfield-Castel-Garden-EL390-R-C390-K390-Mower-blade-/280561700508
The blades on most sites are listed under Mountfield / Castel / Lawn King
There are 41cm and 37cm blades listed as fitting this mower. Seems odd that there is a 4 cm difference for the same mower.
As best I can tell this takes a 15 inch blade PN: 81004117/1 (
http://www.gardenhirespares.co.uk/product_list/81 See 15 inch blade
Thanks for choosing FixYa,
Kelly
Aug 14, 2011 | OEM Replacement Parts Lawn Mower Blade...
How do i replace blade on mountfield princess lawn mower. is it a left or righhand thread
It should be a standard thread. You may need to put a shop rag into the spark plug hole to make sure the engine does not turn while you are trying to remove the blade.
Mar 28, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
Rotary mower
is the nut holding the blade assy tight? loose nut can cause this
Apr 02, 2010 | Toro Lawn Mower With Toro Power Tools
Mountfield mower manual
it seems this mower is made by Homelite with the Mountfield name on it.
May have to see if you can locate a source for homelite to find this manual.
cheers
Sep 26, 2009 | Garden
Need to replace the rotary blade on a mm 850 19 '' cut 48 cm coupe
hello
take off the blade usually one bolt and take it to alawnmower dealer with the serial number and they should have a new blade fot it
hope this helps
Mar 12, 2009 | Black & Decker Garden
Garden Logo
307 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
