Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
How do i start washing the clean light keeps blinking
    President:
  • 949 Answers
The clean light can be blinking for several reasons, here is link to some instructions I put together to explain this and how to reset the unit so you can use it. If the problem persists let me know.
flashing_or_blinking_green_clean_light_7
Posted on May 01, 2010
The green light for "clean" is blinking green and
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Mar 07, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher started up....didn't notice it quit running overnight...dishes seem only half clean. The "clean" green light is blinking. Tried opening and closing and then re-starting it. Can't get...
Greetings,
there is a temp related problem..this could be in the wash cycle not letting water get hot enough or a heater failure....remove your kickplate..there is a tech sheet..it explains how to reset this blinking light.....Bruce Denton
Jan 18, 2011 | Whirlpool Dishwashers
The dishwasher will not Start and the Clean Light keeps blinking
This blinking indicates the water did not heat up properly in the heated wash part of the cycle. I have put together some instructions on resetting the control so you can use the machine and some details on why it might have happened. Follow the link and if you have any trouble let me know.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 03, 2010 | KitchenAid 24 in. KUDP02CRBS Stainless...
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Kenmore dishwasher wont start blinking clean light
today January 9, 2009...blinking clean light, kenmore dishwasher would not run,,,the solution on Fixya ..."keep hitting normal -heated wash-normal -heated wash buttons over and over...unlocked the blinking green light problem. Dishwasher is running as I type this....will post again when I see the results of another washing tomorrow. H.T. Las Vegas Nv
Jan 18, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Machine won't start and the START light keeps blinking
A flashing start button shows that the filter is dirty. Remove the filter assembly from the machine. The "tube" can be split into 2 sections fairly simply - do so, and wash each piece under the tap to clean it.
Once the assembly is cleaned properly, select the program that you desire, and press and HOLD the start button for 2 seconds. The wash cycle should begin.
Nov 05, 2007 | Zanussi 24 in. IZZI ALU Built-In...
Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
May 11, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Clean light keeps blinking and I can't start a new cycle
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. Catriver...post back
Apr 01, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
94 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
