Question about Frigidaire GLMB209D Microwave Oven
Half of control panel lights/numbers are out
In the digital control panels, part of the numbers are lit up and part are not.
How do we resolve this?
  • Anonymous Mar 21, 2014
    only parts of the letters light up
  • 3,037 Answers
The control touch panel basically has partly burned out and so you would have to replace the whole panel.
Repairclinic.com should have a replacement, just use your model number to search for one.
Let me know how this works out for you.
Benjamin
Posted on Apr 30, 2010
The control panel of my sharp grill 2 convection microwave oven is very dim
Dimmed light might be caused by a slight contact between the panel's connector and the mainboard. Or, there is a dimmer option (feature) in the menu. Depends on model. Some of Panasonic microwave ovens are equipped with such a feature.
Regards,
Dan
Oct 12, 2016 | Sharp R-820JS 900 W 0.9 cu ft Countertop...
Microwave went totally dead while operating; there is power to the outlet.
If the control panel lights up intermittently, then you either have a loose connection somewhere near the panel, or a failing component on the circuit board itself.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Jul 10, 2015 | LG LMV1813ST Microwave Oven
Jnm1731dm1bb
For model JNM1731DM1BB, there's no reset. Your membrane keypad is failing and has to be replaced.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
It is part number WB07X11033 and you can order it from the Pros here for $148.66 (subject to change).
You can find helpful exploded view diagrams and order other parts at that link, too.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move your circuit board into the new frame.
Be careful, the display is made of glass.
Oct 26, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Lg lmv1630bb microwave
Unless you are successful with a hard reset of the elctronics you are SOL and need to get a new control board. Check out the attached for parts Search Over 2 1 Million Appliance Parts
Aug 31, 2017 | Microwave Ovens
The right Half of the touch panel does not work and there is no power when start is pressed. Fans and lights work
Without a model number, I can only give you a general answer, but feel free to contact me with the full model number and detailed symptoms for a free estimate and/or do it yourself tips and part numbers, etc.
The problem is a failed keypad, which can occur due to manufacturing weaknesses, direct spraying of spray cleaners, heat or steam or grease accumulation due to failure to use the hood vent exhaust fan while cooking on the stove top, or just poor design.
Either way, you would have to replace the membrane keypad or outer door panel or control panel frame, depending on model.
Oct 05, 2011 | LG LMVM1945 Microwave Oven
Light Bulb Blew - blue spsarks. Replacement does not work. shorted out
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Or you can order a new control circuit board from the
Sears Parts Direct Web site.
Just enter your model number there.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########.
Jan 22, 2011 | Kenmore 80412 Microwave Oven
Microwave doesn't work
Sounds like you have a faulty control panel. I would use a meter and test the power from the control board to the magnetron and circuit board. Chances are the control panel is faulty
Jul 25, 2010 | GE Microwave Ovens
Light always on
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
May 23, 2010 | Hotpoint RVM1425 Microwave Oven
Microwave won't work. Power source is fine (toaster oven is on same plug and working). There's nothing lit up on the control panel.
All have at least one internal fuse, some have separate fuses for the high voltage and low voltage supplies. The back panel is normally only secured by a half-dozen screws. I shouldn't have to remind people but -  PULL THE PLUG FIRST ;-)
Dec 18, 2008 | Microwave Ovens
Possible fuse blown
That would be located behind the control panel.
In essence, you unplug the oven, remove the grille from across the front, then you'll see the screw holding the control panel on.
Once that screw is removed, the control panel can be lifted up and out, then you should see the fuse.
You can probably find an exploded view by entering your FULL model number here: http://www.searspartsdirect.com
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 11, 2008 | Microwave Ovens
Frigidaire GLMB209D Microwave Oven Logo
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
