Question about Refrigerators
Refridgerator side not getting cold model gss201epaww
Started out with the refrigerator side not getting cold. found the defrost heater no good and coils froze up.. replaced heater and the defrost t-stat and defrosted the coils. worked good until the condensor coils froze up again.found the defrost heater wasn't working. replaced the control board and defrosted the condensor coils again. fridge is still not getting cold. freezer is cold. condensor coils are not frozen up.defrost heater is working. fan is working. and now I'm lost as to what else it could be. door seals are fine. fridge worked great until the heater defroster and control board went.
    President:
  • 2,468 Answers
Make sure the damper vent door located between the freezer and refrige compartments is opening and letting in cold air from the freezer,if they ice up they can stick shut and not allow air flow,this door is behind a plastic grille an a hair dryer works great to defrost them
Posted on Apr 30, 2010
Refidgerator side is warm freezer still working but not defrosting
Your model refrigerator has a 241508001 Defrost Control Board
found as part listed as location 23 HERE
and is the most likely cause for your refrigerator not defrosting. The other causes can be the 5303918255 Defrost Heater
instructions on testing can also be found on the same page as the defrost heater. The last part to cause defrost failure is the=> 5303918214 Defrost Thermostat
Item 14 is the defrost heater and item 21 is the defrost the
rmostat and can be found in the photo found on this page HERE
Let me know what you find so I can answer your questions, Thanks Sea Breeze
Oct 04, 2012 | Kenmore Side by Side Refrigerator
We have a refridgerator, about 2-3 years old, Model #ED5JHEXTB00. Side by side freezer, refridgerator that is not cooling as much as it should in the refer part. I'm not sure of the temp, but milk goes...
if your noticing frost on the back wall you have a defrost problem and need to address it immediatley before u get warm in freezer and refrigerator sides remeber that a refrigerator is just a cold air duct from the freezer.... defrost heater bimetal defrost thermostat ot timer defrost control is bad ...
Feb 01, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
The refridgerator is not getting cold
sometimes when the air flow is restricted cold air migrates back into the bottom of the fresh food side and could freeze the dispenser resevoir which is behind the crisper drawers. Also, just defrosting the freezer is only treating the symptom. Something malfunctione to allow the frost to build up. Either the heater, defrost limiter or defrost timer.
May 05, 2010 | GE GSS20IEP Side by Side Refrigerator
REFRIDGERATOR SIDE DONT KEEP COLD, BUT THE FREEZER DOES? WHY?
This symptom can be caused by many different failures, defrost system failure,( defrost heater,timer,thermostat), something blocking air transfer path to the fresh food section such as: ice build up, damper door not operating, main thermostat, check all these or have tech come in and check.
Good luck !
Mar 17, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The refridgerator is not staying cold. The
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others. You can post your model number into one of several appliance parts sites on the internet and search for defrost components to find your parts.
Mar 06, 2010 | Refrigerators
IFrost Free Sharp Refridgerator & Freezer-Fridge not keeping cold
hello sir/mam
please check the blower of the refrigerator if this is not working the refrigerator wont get cold.
Sep 14, 2009 | Refrigerators
I have a kenmore refridgerator side by side. The freezer is beginning to have snow buildup (it is a self defrost) the refridgerator side is not cold
That snow is the condensate build up on the evaporator coils behind the rear panel of your freezer. Normally the freezer will go into defrost about every 10 hours and this snow will melt and drain out the defrost condensate line below the evaporator and go to a pan under your refrigerator and return back to the air inside your home. I believe your freezer is missing the defrost cycle either because the controls for the defrost are defective or the defrost heater and defrost thermostat is defective. I would be watching for an increase in refrigerator temperatures soon, due to loss of defrost. We will need to unplug and examine the evaporator coils behind the rear wall of the freezer. If frozen or covered with snow then defrost with a hair dryer and lets check the defrost heater and all its related components. Could you find a model number like 321.256489 for example then I can find the parts to look for. Sea Breeze
Aug 20, 2009 | Kenmore Refrigerators
Each side won't get cold. food starts to spoil
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control
Jul 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Problem with Kitchen Aid side by Side
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck!
Jul 11, 2009 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool gold:upper half of refridgerator side not cold
Either the evap fan has a problem, or the defrost system has failed. You should never see frost in the freezer section as the defrost sensor should sense that the coils need to be defrosted before that much frost accumulates.
Unplugging to clean out helped because the frost got a chance to melt away.
If you find the evap motor is running, then the things to check are the defrost sensor, the defrost timer, and the defrost heater.
Reply back if you would like more info.
Jan 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
411 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
