Question about Kingston 4GB Secure Digital High Capacity Memory Card
The USB flash drive doesnot shows the file system option and shows 0 of 0 bytes free.
    Sergeant:
  • 252 Answers
There will be 3 reasons of this problems.
If you not not connects this drive properly to system it will show drive property 00 bytes. If you has set up password for this drive then this problem will appeared OR drive is damaged & stopped working. If you trying to connect memory card then change your card reader.
If this flash drive in warranty period then go to authorized service center & give it for replacement.
Thanks.
Happy to help you.
Posted on Apr 30, 2010
Transcend jet flash v33
Hi Virus or Trojans can run some process that keeps running in background. This not only harms the computer, but also prevents the pen drive from formatting as it shows that the drive is in use. Remove and re-insert the pen drive, don't double click on drive and cancel autorun operations if it starts automatically. Run a virus scan on pen drive, this will help fix the issue. Now format the pen drive.
Mar 30, 2014 | Electronics - Others
32gb SD card is showing 0 bytes used space and 0 bytes free space
Try formatting the card and be sure the locking switch is in the off position.
Sep 14, 2011 | Transcend (589307) Media
When i plug it into my computer it comes up as a cd drive with 0 bytes free of 0 bytes im running windows 7 now but when i got it i was running windows xp
Some flash-drives imitate a CD-disk (which, after being written and "closed", always show up as having "zero bytes free space"), in order to automatically run some software from the flash-drive each time that the flash-drive is connected to a computer. For example, that "auto-run" software may be a file encryption/decryption routine, requiring you to enter a password to access your files.
So, if you "lose" the flash-drive, whoever finds it cannot access your files, without having your password.
Apr 27, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My (Transcend)pen drive showing free space 0 byte and used space 0 byte .
jmy (Transcend)pen drive showing free space 0 byte and used space 0 byte
Nov 26, 2010 | Transcend (589307) Media
Formatting the pendrive
Plug it into another usb socket and you should find it works, Sometimes usb sockets and drives can become corrup.. by right when you reboot you machine it will revert back to normal
Nov 17, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
On opening a pen drive it is showing 'please insert a disk into removable disk (h:)' and opening its properties it is showing used space 0 bytes free space 0 bytes
Hello there yogeshpat876.
Here's your geek-steer ...
Is this a new drive? If so, it probably just needs to be formatted [and optionally assigned to whatever free drive (letter) you desire]:
Start > Run... > tpye "diskmgmt.msc" (without quotes), then OK
Good luck, and please do post back ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback,
  • if you have ANY further questions.
Today's the best day of my life ... and NOW you're part of it!
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
Oct 13, 2009 | Transcend (589307) Media
Pen drive display free space 0 byte and used space also 0 byte
Try formatting the drive. Assuming Windows XP, just open your "my computer" icon, right-click on the device and choose format. Be aware, formatting will remove any data you may have had on there previously.
If you're using another OS, or if it's an existing drive, please re-state your question giving further details (what OS, what you are trying to retrieve, etc).
Aug 17, 2009 | Transcend (589307) Media
My usb was suddenly says used capacity 0 bytes,free 0 bytes,FILE SYSTEM raw.Cannot be formated.it says insert flash drive.give me the best solution.
Jun 05, 2009 | PNY USB SmartMedia Reader PC (SFRUSBWB)
Pen drive is showing o bytes
I would first put it through a fast formatte then a standard formatte, then i would recommend asector scan and see if there are any sectors that are not recoverable, if they are messed up and or still not solved try to uninstall the file that has stored the recognition files for the pen drive remove the main file in c drive program files , find the file by name corresponding to what it is you have and delet it then do a full shutdown and after a full cold start reboot install pen and software when asked if you still experience this post the results and i will try to help in a higher level of tech knowledge and support
May 31, 2009 | Transcend (589307) Media
Pen drive is not able to write any data
How are you formatting it? NTFS or FA32?
I suggest you reformat as FAT32
Dec 19, 2008 | Electronics - Others
Kingston 4GB Secure Digital High Capacity Memory Card Logo
298 people viewed this question
Top Kingston Electronics - Others Experts
Raghavendra Nagaraj
Raghavendra Nagaraj
jairo sanchez
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
