Question about HP iPAQ RX3715 Pocket PC
How can i do a master reset on my ipaq, i lost the log on password and can not think of another way to start it.
The only "master reset" i know of is a hard reset. Warning! This will erase all data in the main memory (not in ipaq file store) and reload the operating system from ROM. Afterwards you should restore the latest backup.
To perform a hard reset do the following:
- place the unit on a table with the display facing upwards
- with two fingers of one hand press and hold the leftmost ("Mobile Media") and rightmost ("iTask") button simultaneously
- with the other hand press the reset knob with the stylus
Posted on May 25, 2010
Tip
Reset sql sa password directly and efficiently
A few days ago, I had a painful experience that I lost SA password on my MS SQL Server database, and I almost took the whole weekend to look for an efficient way to reset SA password. I asked friends, searched on Internet and even bought some book.... Fortunately, I finally got a SQL server password recovery software and it instantly reset SA password without data loss. And I also got a couple of good solutions for sql sa password reset to save your weekend in case you have lost or forgot MS SQL Server passwords (SA password!).
Option 1 : Use MS SQL Server Password Unlocker to Recover/Reset SA Password
The most direct, efficient way to reset SA password is to take use of the third part utility - SQL server password recovery software. Just two steps:
Step 1: Access to master.mdf file, which is default at C:\Program Files\Microsoft SQL Server\MSSQL\Data\master.mdf
Step 2: Select SA password and reset SA password
So, Reset SA password successfully!
Option 2 : Recover or Reset SA Password with Other SQL Server Login
If there is any other SQL Server Login that is a member of sysadmin role, you can log in using that account and reset SA password of SQL Server. Reset sql sa password as described here :
SQL SERVER - Reset Password of SA Login Using Management Studio.
Login into SQL Server using Windows Authentication.
In Object Explorer, open Security folder, open Logins folder. Right Click on
SA account and go to Properties.
Reset SA password, and confirm it. Click OK.
Make sure to restart the SQL Server and all its services and test new password by log into system using SA login and new password.
Option 3 : Recover or Reset SA Password with Windows Login that is a member of Windows Admin Group
If there is any other Windows Login that is a member of Windows Admin Group, log in using that account. Start SQL Server in Single User Mode as described followings :
SQL SERVER - Start SQL Server Instance in Single User Mode.
There are certain situation when user wants to start SQL Server Engine in "single user" mode from the start up.
To start SQL Server in single user mode is very simple procedure as displayed below.
Go to SQL Server Configuration Manager and click on SQL Server 2005 Services. Click on desired SQL Server instance and right click go to properties. On the Advance table enter param '-m;' before existing params in Startup Parameters box.
Make sure that you entered semi-comma after -m. Once that is completed, restart SQL Server services to take this in effect. Once this is done, now you will be only able to connect SQL Server using sqlcmd.
on Oct 05, 2010 | Computers & Internet
Forgot my password on hp ipaq pocket pc
you may visit some master reset code sites..
Jun 11, 2011 | HP iPAQ 112 Classic Pocket PC
My son changed his password on his netbook. now he doesn't remember it. he cannot log in at all. he can do absolutely nothing with it. how can we fix this?
at Windows XP's Welcome Screen, simply press Ctrl-Alt-Del keys sequence together twice, and you will be shown a Log On to Windows menu where you can specify the User Name and Password. In the User Name text box, key in "Administrator" (without quotes) and leave the Password field blank. Then press Enter or click on OK. If there it is not a password protected Administrator account, or blank password is set, then you will be able to access the Windows with full administrative privileges as Administrator.
Then simply click start > control panel > User accounts then select your sons account and click edit then click remove password. once done simply log off and then log in to your sons account and no password will be asked for. If your son is the root administrator then you will need to get software to reset the password for you
Mar 23, 2011 | Computers & Internet
Forgot the password on my Samsung Gt- S3653W cell phone
Insert the code *2767*3855# ,This will reset your phone, warning:all your data will be lost in the process .regards .
Jan 25, 2011 | Cell Phones
What my password
What do you mean?
If you mean you have lost the password, i think there are many ways for you to reset the lost password.
log into the safe mode and reset the password or use some third party Windows password recovery software like Windows Password Recovery Basic.
Nov 14, 2010 | Computers & Internet
I forget my password....so how should i break it?
the password can not be broken, but you can perform a hard reset that wipes the device clean including the password. all content is lost.
1. Press and hold the lower left and lower right buttons.
2. Press the Reset button on the bottom of the iPAQ Pocket PC
with the stylus.
3. Hold all buttons until the displayed image begins to fade
(approximately four seconds).
4. Release the program buttons and stylus.
You can verify a full reset by pressing the power button. If the
iPAQ Pocket PC has been fully reset, it will not turn on.
5. Reactivate the battery by doing one of the following:
Connecting the iPAQ Pocket PC to AC power
Pressing the Reset button with the stylus
Nov 06, 2010 | HP iPAQ H5450 Pocket PC
Rx5915
I got this info from HP website..
1. Press and hold the Quick Launch and Rotate Screen buttons.
2. While holding these buttons, use the stylus to lightly press the Reset button on the HP iPAQ until
the device restarts.
3. When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the
Reset button.
The HP iPAQ restarts and powers on
It doesn't mention a password. I also have an HP Ipaq and don't need a password to hard reset. Good luck. If this helps you plz rate this. Thank you kindly.
Jan 31, 2009 | HP iPAQ rx5915
How do you hard reset a hp ipaq rx5915?? i lost the password
Reset button.
Laptop
Restart pc but as its starting up keep pressing F8 to get you into safe mode, choose start windows in safe mode then you will get a large iconed desktop with your account and an administrator account.
Click on the admin account then go to control panel>users, then go to your own account, choose change an account, then choose delete password.
Restart pc then you will boot straight into windows
Aug 17, 2008 | Computers & Internet
HP iPAQ RX3715 Pocket PC Logo
144 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
