How to work wifi box - Computers & Internet
  • 4 Answers
Whats ur problem please describe in detail . so that i can help u out
Posted on Apr 30, 2010
Wifi is unstable on my android tv box, all other devices work fine
Try to activate a second option on your wifi router, normally these days they come with 2 types, one is the normal 2.4 Mhz and the new one is 5 Mhz, you have to make sure that your Android TV box can operate on this wavelength too. Once verified try to connect to this one. On the other hand if you can't connect to your router then I might advise you to get a WIFI amplifier, they work really well.
Nov 04, 2017 | Tablets & eReaders
Help, connection fails from wifi, after walking away from the wifi box
All WiFi "boxes", called WiFi routers, have a limited reach. That reach can be limited, when you are in a building with concrete walls and steel plating. But even when you have a free sight tot the router the range can be limited to 25 or 50 meters. Although manufactures say up to . Be aware other rower working on the same frequency, close to you also will limit the range of operation.
Mar 15, 2015 | Tablets & eReaders
Which wifi dongle to use.
As far as I am aware, a youview box has to be hardwired via ethernet or ethernet over homeplug to work. Not a lot of help, but there you are.
Cheers
Oct 09, 2014 | Computers & Internet
My NEXTBOOK tablet won't connect to the wi-fi. Keeps saying "obtaining IP address"
Something could be getting in the way of the connection or your ip number may not be working. see if it will allow you to enter the ip address which should be located on your wifi box.
Jan 05, 2013 | Computers & Internet
Connection wifi
dear try this..hope u will be helped
1. Go to Settings > Connections > Connections > advanced tab >
On the top half, for select networks to automatically used, click "select networks"
For top half, for programs that automatically connect to the internet should connect using "My Work Network , and then
continue by clicking "edit", go to proxy settings tab... just tick "this network connects to the internet" box only....
leaving the proxy server box unchecked, as well as advanced ( these would be set automatically ) and click ok on top..
This will return you to the network management settings,
On the bottom half, for program to that automatically connect to a private network should connect using ...
select "My Work Network" as well, then click "edit", go to proxy settings, and just tick same as above procedure....
Note: Besides the above steps to select networks, you can ignore the "dialing rules" and "exceptions" boxes alone...
2. Go to Settings > Connections > Wi-fi
Under configure wireless networks, you should be able to see the list of your wifi networks...
First, go to Network Adapters tab and then for my network card connects to.... select " The Internet" ( not Work )..
Secondly, go back to Wireless tab, scroll down to your house wifi...and click on Menu > Edit. select connect to the internet ( not Work),
click Next ....For Authentication box ,select "Open" and for data encryption box, select "disabled".
Other boxes can be left blank, and click "Next" and then "Finish".
Nov 08, 2010 | Samsung Star GT-S5233 Cell Phone
Wifi button won't work When I depress the wifi button it stays orange instead of turning blue.
Look by the clock.. on the start bar for a icon to conect
open it and makesure its on,, and then conect to you WIFI, try reseting your wifi router, try reseting your internet box
If you already know how to do all that with no luck,
check the drivers for the wifi card
Its ether not conected to a network, lost driver, wrong network setings or bad wifi card.
May 16, 2010 | HP Compaq nc6220 Notebook
My Archos 605 WiFi will not always switch my NTL (Samsung) set top box on to make a scheduled recording.It will however change it to the correct channel if the box is left switched on and make the...
I have partly solved the problem by leaving the box switched on (any channel) then when the programme is about to record Archos 606 WiFi will switch the cable box to the correct channel and record. It will not however turn the box off after recording this has to be done manually using the remote handset.
In the instruction manual for the Archos docking station there is a footnote saying that in very rare cases the On/Off function does not always work and I am wondering if the Samsung (NTL) Box is one of them. I cannot get a direct answer from Archos support team on this issue when I have sent numerous E-mails. According to the manual I am working on the correct code number for the Samsung (NTL) box.
Feb 19, 2009 | Archos 605 WiFi Digital Media Player
Wifi
make sure your wifi doesn't have a password and  wifi will not work unless you have a box like 2wire or linksy's it uses the same thing a labtop would need to connect
Jan 11, 2009 | Apple iPod touch
I av reistalled windows xp to my acer aspire 3000 laptop and how my wifi wont work how would i fix this thanks
you will have to install the driver for wifi please go to microsoft.com and type wifi driver in the search box and download the driver > restart the computer and it should work
Aug 14, 2008 | Computers & Internet
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
