Question about Whirlpool Duet GHW9150P Front Load Washer
Washing machine vibrating when spinning
Bounces all over floor
    President:
  • 2,468 Answers
You need to level the machine and then run the jamb nuts located between the feet and base of the machine tight against the bottom of the unit or they will turn and un-level the machine when you use it
Posted on Apr 30, 2010
4 Suggested Answers
  • 51 Answers
SOURCE: vibrating only on final spin
no cement is perfectly level so you will need to level it with a spirit level
Posted on Jun 12, 2009
  • 3600 Answers
SOURCE: my Bosh washing machine has excessive vibration.
it may be level but if the feet are not adjusted to be tight to the floor this will cause it to walk so try adjusting the feet then lock the locking nut I am sure you will find 2 that are not adjusted tight enough.
Posted on Feb 05, 2010
news775
  • 699 Answers
SOURCE: why does my brand new washing machine sound like
It is the dampers on the underside of the drum that have failed.
There are normally 2 dampers.
Bit like shock absorbers
If one or both fail the machine will try to go into orbit !
Posted on Feb 05, 2011
Vibrates when it spins
Here are a few quick facts on washing machine vibration.
  1. All washing machines and dryer vibrate. Dryers usually have less vibration than washers because the load is only wet clothes (as opposed to a drum of water and clothes). Front loading washing machines cause high frequency vertical oscillation while top loading washers usually have horizontal oscillation.
  2. Almost all front loading washing machines are not recommended for use on standard joist-construction floors (most common floor type, compared to a concrete slab sub-floor). Manufactures like GE, LG, Maytag, Samsung, Whirlpool, Kenmore, Bosch and more, all recommend installing a pad like Silent Feet under the washing machine to absorb the vibration.
  3. The only alternative to using Silent Feet pads to prevent structural damage is costly upgrading of the sub-floor. This usually involves adding a second layer of plywood sub-floor and adding sister boards to the rafters that support the floor. But even this won't reduce the amount of vibration noise that you hear. Sub-floor upgrades can cost thousands of dollars.
  4. Vibration can also cause appliance "walking" (unwanted movement) usually during the spin cycle. Simply installing a pad designed to prevent walking can solve this problem and mean that you'll never have to reposition your washer after every load again. Both Original Silent Feet and Anti-Walk Silent Feet prevent walking, however for washers that move a lot or stacked units it is recommended that you install Anti-Walk Silent Feet for the best results.
You were not specific in either type or model. I hope the above information helps. Also, the size of the loads plays a great part in how a machine functions. have a nice day
You wer
Dec 16, 2013 | Kenmore Washing Machines
How to fix a bouncing floor
Is your floor the problem, or a vibrating wash machine? You can buy feet for an appliance or put carpet underneath it. anne melhuish
Jan 25, 2012 | Washing Machines
Maytag Washing Machine Out of Balance Even When Empty
the machine is not level... put a level across front back sides to check adjust legs leveling bolts as needed.... also is the machine installed on a carpet floor??? if yes put a sheet of plywood under machine so it wont "bounce" on floor.
May 15, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Excessive vibrating and banging in the spin cycle with some washes. The unit is only 1 month old. Any advice?
You have a improper installation. The machine has to be perfectly level side to side and frotnt to back. After leveling, check the feet on the bottom and see if one is bouncing on spin with a load. Adjust the bouncing foot down until machine stops bouncing.
Jan 25, 2010 | GE Profile WPRE6100G Top Load Washer
My 3431 dryer takes too long to dry and it vibrates badly during the spin cycle.
You have two issues. The cycle time on this unui in the normal mode is 3+ hours. If it is longer than this you have a clogged condensate/dry duct which needs to be cleaned out by an LG tech. The balance thing is a matter of using a level and getting it perfectly level. Once you have done this, if it still bounces check the feet and adjust the one that is not solid on the floor while the machine is bouncing.
Jan 23, 2010 | LG WM3431 Front Load Washer / Dryer
I have a top loading Kenmore Washing machine, Model 110, Heavy Duty, dual action. The machine is level but during the spin/unload cycle, the machine bounces around and makes noise. If I put two cases of...
There are pads on the tripod and skid plate that wear out and can be replaced. There is fluid in the tub ring that may have leaked out. The base (tripod) can be bent and cause vibration problems. The flooring material and support can cause this also. I would start with the floor and work up through and eliminate the causes to find the culprit.
Eric
Nov 19, 2009 | Kenmore 24032\24036 Top Load Washer
Need to balance washing machine drum
The drum should not need balancing, but the washer should be level in all directions. If the washer is level, but vibrates excessively during spin cycle, you may need to replace the springs. There is a set of suspension springs which act as shock absorbers. When these wear out the washer will bounce across the floor unless the clothes are 100% balanced in the washer.
Jul 29, 2009 | GE Washing Machines
Machine knocks and walks when spinning a small load
amke sure it is level and on a solid floor with little bounce.
Jan 23, 2009 | Admiral AAV7000A
Vibrating machine
have you check your floor..if floor is weak the hold area around unit will vibrate,,,easy test,,,stand in front of unit and bounce your body up and down things moving,,,weak floor,,cheapest fix..get a piece of pluss carpet and make 1 piece over all for legs,,when unit settles in thick carpet that will stop bouncing and noise
Dec 09, 2008 | Maytag MAH8700A Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
132 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
