Question about JVC Televison & Video
When I turn on I can only get a blue screen. Menu shows up but no picture
  • 308 Answers
A blue screen usually means that there is no input signal, either an empty input was selected or the input board/main board is defective and doesn't see a good input signal.
Posted on Apr 30, 2010
Screen keeps changing colors and will not show picture
hi is it flashing red blue green, if so the tv is in screen burn mode, just press menu on the remote retune the tv, what is the model number of the tv you may need to go into the service menu turn screen burn mode off, thanks
shaun
Feb 25, 2017 | Televison & Video
Sony KDL46S4100 when turned on there is no picture just a blue screen
Is this blue screen on all inputs (HDMI, etc.), or just on the one?
Does the remote control work, can you get the menu to display, is there any sound?
If no sound and picture, no menu etc., might be a software problem, the main PCB, or a missing voltage on this board.
Feb 24, 2015 | Sony KDL46S4100 Bravia S Series 46" 1080p...
I can't get a picture to come up.
Have you gone into your setup menu on the satellite and changed any display settings? My 60" HDTV was doing similar things and i was not able to use picture format on my controller to get fom zoom to wide screen, and so on. I had to go into my dish menu and go to setup then video and adjust some settings to display the TV resolution ratio. I was not in the HDMI connection menu when the new TV was origianlly installed to my DIsh. Also had to do same thing on my PS3 under settings and video output resolution.
Just a thought!
May 29, 2012 | Panasonic PT-AX200U Projector
I have a hp c4240, when i scan pictures (8x10) there is space around the picture, it will not resize to the size of the picture. adjusting the picture size and adjusting borders make no difference, did...
take pritner to factory defaults .
press cancell and power button at same time.
you will see message on screen enter special key combo. then press blue green and gray button in a sequesnce. it will show you support on screen. press blue button 2 times it will show reset menu. press ok on it. then press blue button 2 times it will show semifull reset press ok.
Dec 20, 2009 | HP Photosmart C4240 All-In-One InkJet...
Mitsubishi WS-55857 with a flickering blue edge.
The vertical IC needs to be replaced. You can get new Vertical output ICs at www.tvrepairworld.com and they will also help explain where its located.
Nov 27, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Toshiba 32a43 32' picture garbled mess
If you can get the tv to display the blue blackground(usually happens when there is no antenna or cable feed to tv) check to see if the whole screen is a solid blue, if it shows discolored areas around the screen then you might have to "demag" the screen. See if you can rent a demad coil from a tv shop and with tv on turn the coil in circular movements all over the front of screen till blue is solid.good luck!
Aug 03, 2009 | Toshiba 32A43 32" TV
Bush tv 20" lcd tv LCDS20TV006/A - blue screen no picture availab
DOES THE MENU SCREEN COME UP? IF YES TRY ANOTHER INPUT. A BLUE SCREEN IS USUALLY INDICATIVE OF THE SET NOT SEEING A VIDEO SIGNAL.
Apr 10, 2009 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Blank Blue Screen
If you go to menu do you get that on the screen?
Nov 21, 2017 | Samsung CXN2085TP 20 in. TV/VCR/DVD Combo
Apex gb5108
'I to am getting only wavy blue lines, no sound, doesn't even show channel indicators. TV was off for 4 days, came home turned it on and ten minutes later this screen appeared, it wont even show the menu screen, different channels or video inputs no sound either.
Jun 21, 2008 | Apex Digital GB5108 51" Rear Projection...
Televison & Video Logo
202 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
