Question about Tricity Bendix AW1054 Front Load Washer
Drum dosent turn? - Tricity Bendix AW1054 Front Load Washer
Replace drive belt
Posted on Oct 21, 2010
My front end load dryer makes a humming noise when started then goes to pause
Have you checked the drying drum to see if it spins freely? Open the door and verify it spins freely. if it does then the motor may just be in a bad spot. usually after spinning the drum a turn or two it will get it running. it humms and clicks because of the motor not turning and trips an thermal overload switch and you have to wait for it to reset. Now if the drum dosent turn then you have a problem with drum rollers or something stuck in the way of the drum.
Dec 06, 2013 | Frigidaire Dryers
I used the dryer last night with no issue. When I went to use it this morning, I pressed the start button, I heard the motor run, but the drun did not move. After a second, the motor stopped trying. ...
i would say the belt that turns drum is broke,slipping or jumped off motor.try running without clothes in it.if drum dosent turn belt is broke or off
Oct 22, 2013 | Electrolux EIED55H Dryer
The dryer is making a terrible noise, and the drum has stop turning. How many belts are required? when lifting the top and checking the belt should there be any play between the belt and the drum?
Only one belt is used ,their should be no slack between belt and drum.If you can lift up the belt and it dosent snap back tou have a tensioner problem , that could also be part of your noise concern
good luck
Aug 08, 2010 | Magic Chef CYE3005AYW Electric Dryer
Turns on and makes noise but drum dosent move what is wrong . the drum wont move to wash or anything.
Check that the drum is free to move - by rotaiing it by hand. If it rotates very freely - it is likely you need a new drive belt. If the drum is very stiff - and won't move, it is possibly a faulty rear bearing. If both these checks are not the problem, it could be a motor or control board fault. It can be a cheap set of brushes needed for the motor - or a new control board.
It really needs investigation to identify which part is needed before replaements are ordered.
Turn off and unplug before investigating further.
Sep 30, 2009 | Washing Machines
My drums are showing up as guitar and guitar is showing as drums. Has anyone seen this b4?
when u log in use the guitar or drums depending on what one you are using if u are putting it on multiplayer go to band then connect the guitar or drums depending on what you logged in with and connect that first then connect the drums or whatever else you want ..if that dosent work ring microsoft ..
Jul 21, 2009 | Activision Xbox 360 Guitar Hero II
Ive got a hotpoint electric dryer that intermitantly blows hot air..in other words sometimes it wroks while other times dosent blow that much needed hot air to dry clothes..ive tried different things like...
Sounds like the drum is not turning under heavy load.this is a common problem with dryers but usually easily remedied if a competent diyer. first check the theory by putting in big load and see if drum turns. if not then replacing capacator should cure it.
Nov 06, 2008 | Dryers
Machine dosent seem to drain model #lat8840b maytag
my machine had a pair of kids underware stopping the water from entering the draij pump,you may have clothes inbetween the drum and outer wall stopping the normal rotation
Aug 25, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Tricity Bendix AW1054 Front Load Washer Logo
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Colin Stickland
Colin Stickland
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
