Parrot Sound System speaker shutting itself off
I have a Parrot Sound System,consists off 2 bluetooth speakers.Intermittently one speaker shutting itself off,so I have to disconnect power cord off the speaker and reconnect it after a couple of minutes.I suspect a power supply PCB inside the speaker.but cannot find any spare parts anywhere.Any advise?
  • ymk1 May 10, 2010
    It was me, who have posted this issue and have received one advise to put speaker into garbage bin.Well...,but why rush? Each of those speakers has 2 PCBs.One is Parrot bluetooth board,another one is standard switching power supply with 2 ouputs +3.3v and +20V.I have noticed that faulty speaker shutting itself down,after couple of minutes,when not receiving sound from another speaker via bluetooth.I have swapped power supplies between speakers and good speaker became faulty,which means I was right- the problem is with the power supply board.I am not electrician,bit I suspect a leaking capacitor in a low voltage section of power PCB.I am going to replace all 4 caps in that section,but maybe someone will give better idea,which component is faulty?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 240 Answers
Try to check for any loose wires first you may find that there's cables somewhere that are shorting circuit. It's very hard to get parts for equipment like this. Manufactures call it "unserviceable" in other words- put it in the bin and buy new. Sorry
Posted on Apr 30, 2010
My bose bluetooth mobile won't link to my apple I pad,when I try to link them ,my I pad tell me that the sound system is not on
Switch your Bose Speaker off.
Open iPad - Settings - Bluetooth - Switch Bluetooth Off
Switch iPad Bluetooth On and quickly switch Bose Speaker On.
They should talk to each other as they find each other and fall in love :>)
Bose Bluetooth speakers from I-pod are listed in the link below with manuals.
On my Bowers and Wilkins T7 Bluetooth speaker you have to press the Bluetooth button on the SPEAKER the first time you connect it. After it is paired, it finds itself as soon as the speaker is turned on. I can highly recommend the B&W T7.
BLUETOOTH Speakers Bose
Jan 02, 2016 | Apple Bose SoundDock Series II Digital...
How to get bluetooth speaker to connect already apired and is showing but wont connect
Hello, I have already met this issue: after pairing a bluetooth speaker on a first host (computer or iPad), then pairing it on a second device (as another computer for example), when I try to pair it again to its original host device, it doesn't work.
The solution consist in
1) on the host computer, in the list of the Bluetooth devices, delete the line of the bluetooth speaker and forget this bluetooth device,
2) push on the Bluetooth detect button on Bluetooth speaker,
3) scan the bluetooth devices on your computer host, and when you see the bluetooth speaker in the list, select it.
Jul 28, 2014 | Toshiba Satellite Laptop with AMD Athlon...
My parrot minikit speaker does not work?
same problem here, no sound at all from minikit...
someone help?
May 10, 2011 | Parrot MINIKIT Bluetooth Hands-Free Kit...
I have a parrot ck3100 and had it installed and it worked well for a day or so then it stopped audio from the parrot. It still says connected but no sound is heard from any function. Can anyone help?
If the parrot kit sound comes from your car speakers and your radio is working then the problem may be a wire in one of the connectors that are plugged into the Parrot blue box, I have seen wires pushing out when the plug is inserted.
Feb 27, 2011 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Connected Parrot Ck3100 in Toyota Rav4 with Alpine 5897 aftermarket head unit. Tapped the Parrot harness into the speaker wire between the Front driver side speaker and amp, per instructions and phone...
First, you will have to ensure that the vehicle doesn't have an amplified system build in it. Cause in that case the kit should use the two wires line in and line out and check behind the autoradio if you have the entries line in line out. (with this solution, no accessibility with the mute when you have the radio and you receive a call).
But the general idea is to ensure about the vehicle system build in it, cause with an amplified system, you have to avoid it to passing the sound directly to the speakers. (may be wires to wires or a specific harness which is taking acount of it).
Feb 27, 2010 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Parrot to GMC Sierra setup.
here,
When I did this truck I had to go to the amp under the center console. Good luck
#510564: 2007 GMC SIERRA C1500 2DR TRUCK
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery ORANGE (+) RADIO HARNESS
Accesory (CLASS 2 DATA) (+) RADIO HARNESS
THE RADIO HARNESS DOES NOT PROVIDE A SWITCHED POWER SOURCE. RUN A WIRE TO THE FUSEBOX FOR SWITCHED POWER. THE ACCESSORY TURN-ON AND AMPLIFIER TURN-ON ARE CONTROLLED BY THE CLASS 2 SERIAL NETWORK.
Ground BLACK/WHITE (-) RADIO HARNESS
Illumination GRAY (+) RADIO HARNESS
Dimmer BROWN (+) RADIO HARNESS
Amp Turn On PINK (+) RADIO HARNESS
LF Speaker (+) TAN
LF Speaker (-) GRAY
RF Speaker (+) LIGHT GREEN
RF Speaker (-) DARK GREEN
LR Speaker (+) BROWN
LR Speaker (-) YELLOW
RR Speaker (+) DARK BLUE
RR Speaker (-) LIGHT BLUE
Amp Location UNDER CENTER CONSOLE
Steering Cntrls OPTIONAL
THIS VEHICLE MAY BE EQUIPPED WITH OPTIONAL ONSTAR® TELEMATICS EQUIPMENT. USE AN APPROPRIATE INTEGRATION HARNESS OR INSTALLATION PROCEDURE TO ENSURE PROPER FUNCTION OF THIS EQUIPMENT.
Speed Cntrl OPTIONAL
Radio Security YES
Jan 08, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
Installation of Parrot hands free car kit - bluetooth
In the parrot kits I've seen, they insert a relay to switch the audio to the phone. This only works with 2 speakers generally. Your vehicle either has dedicated amp channels for each of the 3 speakers/door or the installer tapped into the wrong point. If it has individual amps for each speaker, they may need to force the amp to shut off to get it to mute the audio.
May 13, 2008 | Car Audio & Video
111 people viewed this question
 Grubhead
Grubhead
