Question about Lenovo Keyboard
My Key Board is Not Working
When my computer is Start but the Computer have not detect my key board. when booting process is done no key is working on this computer but another key board is working on my computer. The damaged key board is not working on another computer. what is the problem please tell me. and solve my problem.
Thanks a lot in advance.
    Problem Solver:
  • 8 Answers
The swapping process you have used already have clearly shown that your keyboard is faulty. It may be that a key is pressed down permanently / faulty and this blocks the signalling - check all the keys carefully to ensure none is depressed. Or one of the Connector pins (the part that goes into the computer) is bent - you may need to check and use a tool to straighten it.
But it is good to know that Keyboards are cheap to replace. If the above did not help, you can buy another keyboard for as low as £5 and then continue enjoying your computer.
Posted on Apr 30, 2010
My hp desktop computer was working well but after a lightning, it is able to boot with no usb port responding and it does not have a ps2 mouse or keyboard connector. What should i do?
pls clear cmos jumper first. after power on and go to bios by press the key board key. if worked, pls check the O/S setup or recovery setup . pls select select system restore and press restore previous date.
if not working usb key board and install PCI or PCI X usb adapter and plug to key board and mouse to it and go to bios and disable on board usb controller.
go to O/S and check
Jan 04, 2017 | HP Computers & Internet
Cmos incorect perriferique non specifier
google translated
incorrect CMOS device not specify
CMOS device(electronics)
A device formed by the combination of a PMOS
(p-type-channel metal oxide semiconductor device) with an NMOS (n-type-channel metal oxide semiconductor device). Derived from complementary metal oxide semiconductor device.
The CMSOS is only a battery to store you're bios/mainboard settings.
CMOS is an on-board semiconductor chip powered by a CMOS battery inside computers that stores information such as the system time and date and the system hardware settings for your computer..
The moment that you unplug the power and remove the battery for at least 10seconds, the mainboard will reset it self into the 'default-state'.
This can also be done by selecting 'reset to default settings' in bios screen.
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps
Oct 10, 2012 | Computers & Internet
I just clear the cmos and and the board does not boot,the board is ibm pn 19r2563
you will have to reset your bios
hope this helps
Sep 23, 2012 | Computers & Internet
My micro innovations PS/2 mouse isn't working
make sure the mouse lead is seated properly and the socket is clean you might have to open up your computer to check the back of the mouse socket for dust and connection status
or you could go into safe mode
restart your computer repeatedly tapping the F8 key to enter safe mode where the only things working will be your mouse and key board allowing you to attempt a repair on your computer
or
resater your computer during the boot up process you will see a certain key to enter set up press and hold that key to enter BIOS scroll to failsafe or optimised defaults press escape then press f10 to save to cmos to restart
hope this helps
Aug 11, 2011 | Computers & Internet
Mousepad wont work then I remove the hardware component from the computer and it ask me to reboot this is done and all of a sudden it works again but then windows says to save the settings it needs to...
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
click start control panel mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp
Hope this helps
Also you might try
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
hope this helps
Jul 16, 2011 | Computers & Internet
How to install windows xp to psrd1-vm mother board
if you want to install xp to your computer
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Jul 03, 2011 | ASUS P5RD1-VM Motherboard
My board is MSI P6NGM-L ,for about a year using my desktop,sudenly set on stand by mode,how can i fix it?or reset it?
or you might try
hope this helps
Apr 12, 2011 | Computers & Internet
Key board not working
try another keyboard .. make sure the connector is seated properly into the keyboard port.
Sep 15, 2009 | Toshiba Satellite Pro L300 Notebook
Note book freezing after fan change
This is just an easy problem... what you'll have to do is follow this steps
Step 1: If you have manual of your computer it is better.. restart your notebook, press and hold the key to boot in BIOS setup... try pressing this key F1, F2, Delete or F8, because some laptop and notebooks have different method of going to BIOS.. you will know if it is BIOS Configuration because it has a BIOS Settings at the Title of the screen.. now go to Power Management or Power Monitoring.. you can find the Fan option there.. because you change the fan of your notebook, it detects that the Fan that you installed is not standard with the note book.. go to step 2.
Step 2: Now when you find the fan option try to set to ignore the fan RPM and The Voltage that is uses... if there is... then save your settings by pressing F10 key and wait for the notebook to start normally.. if the notebook won't start normally, then go to step 3.
Step 3: In this step you'll have to Start in Safe Mode.Restart your notebook, while booting press the F8 key then a boot menu will show in your screen.. if there is drive selection, choose the hard disk drive.. if none then proceed in selecting the Safe Mode menu.. wait until its done booting your windows in safe mode.. after have complete run in safe mode.. properly restart your notebook by going to Start>Turn Off Computer> Restart, and it will boot in windows normally...
Hope I Can Help
CLCTECH
Nov 23, 2008 | HP Compaq Presario 2200 Notebook
Lenovo  Keyboard Logo
226 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
