Question about Mag Instrument AAA Mini Maglite Flashlight, Black #M3A016
My minimaglite is staying on it won't switch off
  • 973 Answers
It sounds like the switch is bad, contact Maglite at www.maglite.com They will repair or replace it at no charge.
Posted on Jun 18, 2010
Neuteral light won"t turn off oo my 1981 750 virago
Light blue wire going into side of engine is grounded or neutral switch is bad. If you disconnect the wire from the switch and the light stays off, the switch is bad. If it stays on, the wire is pinched somewhere.
Sep 19, 2013 | Yamaha Motorcycles
2008 ultra classic, brake light stays on. replaced front brake switch and still stays on.
check to see if there is a pedal brake light switch for the rear brake if so check out that switch as well
May 23, 2012 | 2008 Harley Davidson FLHTCU Ultra Classic...
Battery stuck in 3 AA battery Minimaglite
The battery has to make contact with the bulb as well as the end cap, so if you take the end cap off and the batteries don't come out that end I recommend pulling the bulb assembly apart and taking them out that end. And the next time you put batteries in coat the outside of them (not the terminals) with electrical grease (like you put on car batteries) to prevent them from sticking in there again. Note: if both ends are removed you can use something like a screw driver to push the batteries straight through and out the other end.
Jul 04, 2010 | MagLite Mag-Lite& Flashlight
SET WON T STAY ON STARTING TURNING OFF ON IT S OWN NOW WON T PL
Check the power supply. This kind of sets usually has switching PS. Check the capacitors, common fail of special low ESR caps. It is easy to see if there is some electrolitic content outside the cap. In case caps are damaged replace them with higher voltage, never use normal caps in this PS.
Hope to help you.
Jan 11, 2009 | Naxa Electronics NX-517 Television
How do you change the bulb in a minimaglite
1. Unscrew the "bell" (top) of the flashlite. 2. Remove the bulb by pulling upward. 3. Replace with new bulb (be sure you have the correct bulb . . . it will have two small wires protruding from the bottom). 4. CAREFULLY insert new bulb through hole in the bottom of the reflector. 5. Screw the top of the flashlight back on.
Oct 22, 2008 | MagLite Camping, Backpacking & Hiking
MINIMAGLITE 2AA LED WILL NOT STAY ON
Try twisting the head of the flashlight (left/right). Also could be a bad bulb or corroded batteries not making a good connection
Sep 17, 2008 | Camping, Backpacking & Hiking
Mag Instrument AAA Mini Maglite Flashlight, Black #M3A016 Logo
142 people viewed this question
Top Mag Instrument Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Mag Instrument Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
