Question about Lexmark P6250 All-In-One InkJet Photo Printer
Carrier jam cant see any paper jammed anywhere
When this printer says "carrier jam," it has nothing to do with a paper jam. It means the printer can no longer see the ends of the carrier track. Best course of action is to toss it into the trash, and buy an epson. Lexmark is great for the free software. The printers are garbage.
Posted on Jul 21, 2010
  • 4,041 Answers
Hello there
Just incase it is some thing there try this.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 30, 2010
Paper Jam Error
Epson RX595 Photo All-In-One Printer
Paper Jam Error
Dec 28, 2013 | Epson RX595 Photo All-In-One Printer
I have a 5650 lexmark printer and it keeps saying paper jams but there is not paper anywhere.. how can i find a solution... when you load paper it keepps getting stuck.. help
There could be something blocking the paper path. Try to shake the printer upside down. You'll be amazed of the things that falls off inside the printer. Also, make sure that there's no paper left inside the printer. Tiny pieces of paper will still lead to paper jams.
May 31, 2012 | Lexmark X5650 AllInOne InkJet Printer
PIXMA 450...Keep getting paper jam message and I can't see any paper bits anywhere. Trying to open the machine from the back to look inside. Have removed the 4 screws on the back and still can't remove...
Hi
The paper jammed can be found in the paper tray, remove the paper at the paper tray and inspect the roller for small pieces of paper jammed.
The paper can be found in the ink cartridge compartment, open the cartridge door and remove the ink cartridges, look for posibble paper jammer. Also once remove, check also the cartridge carrier if does not stuck up or jammed (cause this might me the problem). Turn off your printer and then move the cartridge head using your hand moving to the from right to left side and from left side to right side for 2-3 times. Move it gently.
Paper can be found in the rear access door if it is accessible. Inspect some paper jammed there.
Please let me know if you need more help
Mar 10, 2011 | Canon Pixma MP450 All-In-One InkJet...
Carrier Jam? What? I can't see anything wrong, I've cleaned it all, what do I do?
See if there is a door on the back of the printer. I have found paper jammed back there when I couldn't see it anywhere else.
Jan 27, 2011 | Dell V305w All-In-One R840635AU InkJet...
What is a Carrier Jam?
You might have lost a little spring. Can you possibly return it to the store where you got it?
May 16, 2009 | Dell 924 All-in-One InkJet Printer
Oki 5250 380 paper jam
Sometimes you will find debris has fallen into the printer. Take off back to clean it out. Something as small as a staple can create this problem.
Apr 09, 2009 | OKI C5250n Printer
202 Paper Jam om Lexmark c510
1. Make sure the printer is on.
2. Raise the scanner unit.
3. Remove both print cartridges.
4. Make sure the cartridge carrier lids are closed.
5. Close the scanner unit.
6. Press to turn the printer off.
7. Disconnect the power cord from the wall outlet.
8. Plug the power cord back into the wall outlet.
Jun 09, 2017 | Lexmark C510 Laser Printer
Paper Jam
Most likely a bad or obstructed sensor. Use compressed air to blow around the top and back of the printer removing heavy paper dust and look under the pickup rollers for small pieces of ripped paper. If the sensor is bad, contact service and support.
Jul 29, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Lexmark P6250 All-In-One InkJet Photo Printer Logo
100 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
