Monitor is black and blue light flashing
My monitor Samsung Synchmaster 931b is not working The blue light is blinking and the screen is black, although I can dimmly see the screen saver flashing intermittently behind. I have tried the obvious unplugging of cables ect. Any idea
Boot from safe mode and try a different pixel/color arrangement. Obviously a lower pixel and color setting.
Posted on Mar 25, 2008
6ya staff
SOURCE:
Black screen and blinking blue light
blinking blue lights means the monitor is stand by.for the black screen
you should check your cabels from monitor to computer.they should be seated tight.if still no picture your videocard is proberly brooken.
it should be point out at LCD-monitors are fragile.
Apr 20, 2013 | Samsung SyncMaster S22B150N - LED monitor...
I have no blue light at the power button for my Synchmaster 225BW
The power switch is a momentary tactile switch. If you want to fix it, you will have to turn it off and look at the size of the switch to try to find the replacement for it. Not much you can do but open it up to find the cause of the problem.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 17, 2010 | Samsung 225BW LCD Monitor
I have completely black screen, and the powerlight stays blinking, can't shut it off
First place to check will be the power supply section, look for caps with bulging top, post back what you see so we can guide you further, see example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 06, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
Screen blinks on /off - can syncmaster 931b be repaired?
This model was released in 2001, you need to open it up and look for bad caps with bulging top first, the problem can also be in the backlight inverter circuits. Post back what you see so we can guide you further, see example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 27, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
I am using Ubuntu 9.10 in a dual-boot config with XP. I have a Samsung Synchmaster 931B monitor in analog mode. Works fine and drivers installed under XP, but will not support extended effects under...
it's your graphics card not the monitor that often has proprietary drivers to drive compiz and other effects.
If this is not a laptop, then it is easy to interchange.
Nvidia is one such vendor that supplies special drivers for Ubuntu
Jan 29, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
Black screen with power switch flashing blue.
I have been same problem but in other type syncMaster, the solution is open your LCD monitor look for power supply module (PCB which have connector to AC power), on that PCB look for capacitor , for normal condition its look like small tube. now look for broken one which upper part is bloated.
Nov 23, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
I hit a button on the bottom of my monitor and now my screen is black and the light is flashing blue? what do i do
I have had the same problem with two of these monitors. If it is not still covered under warranty, start by opening the case. Once you remove the power board, you will probably notice several capacitors (the round, can shaped parts) that have tops that are not flat. If you see any that have bubbled tops instead of being completely flat, they need replaced. Once they are replaced, the monitor should turn right back on. Hope this helps.
Nov 14, 2008 | Samsung SyncMaster 931B 19" LCD Monitor
Blinking blue light and no display
I WOULD REMOVE REAR PANEL AND LOOK FOR A MASTER RESET BUTTON OR A BLOWN FUSE ALSO CHCEK
YOU AC ADAPTOR TO SEE IF IT IS WORKING FIRST.
Dec 06, 2007 | Samsung SyncMaster 204B 20.1" LCD Monitor
Computers & Internet Logo
475 people viewed this question
Ekse
Marvin
Marvin
