Question about Samsung Jet S8000 Cell Phone
Why does my battery discharge quickly even when the phone is not in use. i bought this samsung jet phone 2 wks ago.brand new.
  • Samsung Master
  • 284 Answers
Samsung Jet S8000 Android Smartphone: Battery depletes when not in use, phone is 2 weeks new:
Hello.. Welcome to Android Life.. So this is not the fault of the phone's hardware or software, this has to do with User error. I know a lot of us, we buy something new and not realize that our set & forget settings selections may cause increased battery life until we understand what is happening..
If you keep WiFi on when you are not using it, the phone will keep searching for WiFi where ever you go, even if you are not in range.. this is the same for Bluetooth and GPS. These 3 are the main cause of battery drain. Turn off all the extra options that you don't use, and only turn them on when you actually need it.
Here's some basic battery life tips from PC Advisor:
Make your phone battery last longer
When you first start using Android, there's always some widgets on the phone's desktop.. I bet you didn't know that these are wasting your battery life even if you don't use them. Remove any unwanted apps showing on your desktop screen or put them in folders. The less number of screen windows showing, background colors shown, etc is there.. the more battery you will save
How to add or remove widgets
Add or remove widget to your homescreen Samsung Galaxy reg II As You Go
If you use the Facebook app and Facebook Messenger app it will really mess up your battery life. If you don't have to cling to being on all the time waiting in limbo for someone to contact you via Facebook, just log out of the app. Rather, on your own time, check in to the app to see if you got messages, so that Facebook doesn't rule your life or your phone's battery life. Facebook and it's messenger app is one of the biggest social media battery drainers across all devices.
I would also recommend turning off Google Apps Sync and update service.. when you are on WiFi and at your choosing you can turn it back on, so that you control when all your apps update. If they remain on the default setting to auto update.. it will do so at any given time, eating up your precious data limit over cellular, even though you are not on WiFi at home or at your favorite free WiFi hotspot location.
(even though the Nexus phone is not your device, it is an Android phone, similar to yours.. the following link is for Nexus Users but Google's suggestions are also good for you)
Save battery life by changing your settings
I recommend turning off Google Now Cards, it's a big battery drainer..
How to get better battery life on Android
I do not recommend installing all the recommended battery saving apps suggested in the linked web pages.. instead I will only recommend a few of my daily driver apps that I use:
The on-board screen dimmer is nice, but at night it's still too bright and I like instant one touch gratification, so I use:
Screen Filter
https://play.google.com/store/apps/details?id=com.haxor&hl=en
To save battery life, this app has a special algorithm that regulates the use of internet access. Use it with it's White List function in the free version to allow one app to be accessible when your screen times out. I use it with Pandora, so that when my screen locks, it is still able to run in the background so that I can listen to music.. knowing that this app won't allow unused background accessible apps to run and access the internet without my knowledge is important to saving battery life.
Using a background with any kind of black in it on Android helps to save battery life. This black wallpaper is not a black color, it's a live wallpaper that does nothing and is designed to save you battery life
Null Black Wallpaper
https://play.google.com/store/apps/details?id=net.rocboronat.android.wallpaper.npe&hl=en
2 Battery
2 Battery Battery Saver Android Apps on Google Play
The Samsung Task Manager is a good basic app closer, however this app helps to keep my phone running smoothly with a deep clean, allows me to disable certain apps I don't use from starting up when the phone boots up if it is restarted.. If your device runs slow, this could also cause the phone to waste battery life
All in One Toolbox
All In One Toolbox Cleaner Android Apps on Google Play
I also highly recommend carrying an extra battery around (in a plastic protector so that nothing scratches it up or accidentally wets it (it's much easier to charge up a second battery while you sleep in an external wall charger specifically for the battery only, carry it instead of USB charging cable and charging adapter, and even just switch it out to instantly go to 100% when needed rather than attach an external charger to wait for it to charge
Wall battery dock/charger
why does my battery discharge quickly even when - battery-discharge-quickly-even-when-kyzl0pi20tqzz121bvlihxv0-2-0.jpg
battery-discharge-quickly-even-when-kyzl0pi20tqzz121bvlihxv0-2-5.jpg (also get a replacement battery for your phone, search for "Samsung Jet S8000 battery" online)
switching out/rotating your OEM battery with a cheap China battery when needed helps to increase your original battery's life over time. So, instead of it lasting one year, it may last 2. Also, this increases the life of your micro USB charging port on your phone, because you will end up using it less to charge your phone.
I usually buy 2-3 extra batteries and keep them charged. Whenever I need to go out, I just grab 1-2 depending where I'm going, just in case.
Posted on Feb 02, 2016
  • 33 Answers
It's probably nothing to do with the battery health, as the phone is very new. I repaired my battery life by updating the phones firmware. Went from 17hours to 5+ days!
Posted on May 28, 2010
  • scaffelpike Mar 21, 2011
    what firmware did u use? got a link??
  • 713 Answers
Hi,the reason why the phone battery discharges,is as e result of the fact that the battery cells are weak/bad,hence the battery is unable to hold charge for a long duration.
the solution to this problem is to get a replacement for the battery from where the phone was purchased,However you should ensure to charge the new battery for at least 5hrs initialy before using the phone at all,this might be responsible for the problem you are experiencing with the present battery right now.
Thanks and take care
Posted on Apr 30, 2010
Overnite my htc p3400i lost all the charge it had and when i plug in the charger to charge only red light glows....i changed the charger and charged it but the 100% charge now discharges quickly nad last...
hi
just see dear if your phone battery is not damaged means that it is not broken or the upper portion hasn't not grown means a hill like portion on battery you can keep it on table and spin it if spin try both sides then battery problem need to purchase new one if not then you can charge it via computer then check and last option is discharge it completely then charge it for continually 8 to 10 hours may be it can solve your problem. regards aniruddh
May 31, 2010 | HTC Touch P3450 Smartphone
Battery does'nt hold a charge
Hi there
You are having a battery problem and the best solution is to get a new battery for your phone to work properly
Have a nice day
Feb 20, 2010 | Samsung S8300 Ultra Touch platinium-red...
Quick discharging of the Iphone 3gs battery
Yes its normal. To maintain the most power adjust your brightness bar down to 1/4 or 1/2. Keep the push mail function off when you don't need it. Don't recharge the battery until the unit shuts itself off. Then recharge the battery to max before using. This is called conditioning the battery, even though many say you don't need to on lithum ion batteries because there is no memory effect. But their full of sh.t, cause you do the first time you get the battery and should do it once a month to extend the life of the battery.
Feb 04, 2010 | Apple iPhone Smartphone
perfectly normal. as the iphone is a super-powerful smartphone. also it depends on wich application you are using. 3d games, 3g wireless internet and the PUSH notifications, generally contribute to drain the battery's life. to enlarge you battery's duration i would recommend to disable the push notifications, or at least give them a longer refresh delay. also, it would help if you install a battery monitiring application and lock the phone immediatly after use. the drawback is that you wil hae to manually check you e-mails and other things that depends on the push notifications.
Feb 04, 2010 | Apple iPhone (16 GB) Smartphone
Samsung SGH-F480i phone won't charge
remove the battery of ur cell phone put it in the pot and then flush it. buy new one and if then also it doesnt works then through ur cell phone in the *********
Jan 11, 2010 | Samsung SGH-F400 Cellular Phone
Battrey fast discharges
dear, there are two possible reasons of battery down.. 1st is that your battery is not ok and the other is your phone's charging IC is going to drain it.. so check the battery with other set or try with new battery in your phone.. regards, hope it will fix the issue so dont forget to rate it...
Jun 04, 2009 | Samsung Cell Phones
Battery gets discharged
Possible Problems:
1. Maybe there's a virus.
2. Often restart can drain the battery.
Possible Solution:
Format it by pressing the green key or call key + no. 3 + asterisk(*) at the same time. But 1stly, turn off ur fone, then b4 the NOKIA logo appears, hold these following keys altogether. You will see the "Formatting" word afterwards..
OR...
Format it by typing *#7370.
Aug 03, 2008 | Nokia 3230 Cellular Phone
Rapid battery discharge/non connecting calls
take the phone and have it either reflash or the main-board replaced.
May 22, 2008 | LG CU400 Cellular Phone
Samsung 40" lcdtv.
sounds like the power supply is out, should be in warranty no matter where you bought it, call 1-800-SAMSUNG
May 08, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Brand new dvd player just shut off and won't turn on or charge
Your problem is most likly the ac/dc adapter, try your power cord for your car see if that works. if it does then its the adapter. Venturer has had some problems with their chargers.
Jan 10, 2008 | Televison & Video
Samsung Jet S8000  Cell Phone Logo
1,106 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
