Question about Acer Computers & Internet
How can i execute hyperlink in ms word? - Acer Computers & Internet
    President:
  • 524 Answers
Below link has a perfect example of executing hyperlink in MS Word.
- http://support.microsoft.com/kb/310520
Please let me know if you have any further questions or concerns.
Thanks.
Posted on Apr 30, 2010
Repair Word File ?
Kernel for word Repair tool is a best solution for corrupt or damaged MS Word document. It is easily repair corrupt or damaged MS word document and recovers all data like as OLE objects, images, forms, graphs, hyper links, tables, text, headers,footnotes,etc. without any hardship. For more information, Click here:- http://en.wordrepair.org/
Dec 08, 2014 | Microsoft Word Computers & Internet
HYPERLINKS
What kind of message do you get when you click on dead hyperlink?
Jul 31, 2008 | Dell Dimension 2400 PC Desktop
How to install MS office in Ubuntu?
http://samanathon.com/how-to-install-microsoft-office-2007-in-ubuntu-804/
Sep 23, 2011 | Canonical Ltd. Ubuntu
What is the mean auto exe c bat in dos files??
An AUTOEXEC.BAT file contains MS-DOS commands which are executed automatically when a Personal Computer boots. This file is usually located in the root directory of the hard drive or floppy from which the computer boots (or starts) up. The AUTOEXEC.BAT file is used to set various default settings and to run programs that should be executed upon startup. Below you will find a list of executable statements (commands) that typically go into an AUTOEXEC.BAT file, along with explanations their.
The AUTOEXEC.BAT file is one form of a batch file, and it is used to automate functions in MS-DOS. In their simplest form, batch files contain MS-DOS commands (batch file language) which includes commands for such things as loops and execution branches and the like.
ECHO
Example: @ECHO OFF
This optional command will suppress the display of subsequent commands while the AUTOEXEC.BAT file is being executed
Dec 09, 2010 | Computers & Internet
In MS Excel 2000 and 2003, I was able to add a ''hyperlink window'' to my toolbar which enabled me to copy the link and place it in emails and other documents. Is there a way to show this hyperlink window...
To create your own toolbar:
  1. Click the Toolbars tab on the Customize dialog box.
  2. Click the New button, and then type a name for the toolbar.
  3. Click the Commands tab, and drag buttons and commands to the toolbar.
regards
Sep 04, 2009 | Microsoft Office Professional 2007 Full...
Good day, pls. help me, how can i install network ip address for konica 7035. thanks alot
Using arp command (Windows 95/98/NT/2000)
From Windows 95/98 MS-DOS prompt or at Windows NT/2000 command prompt, you can use the arp
command to assign the IP address to the network interface card. It is necessary that TCP/IP is set up
correctly on the computer that will execute the arp command. Perform the following procedure:
1. At Windows 95/98, select [MS-DOS prompt] from the [Start] menu. At Windows NT/2000, select
[Command prompt] from the [Start] menu.
2. Execute the arp command. For example, if the MAC address of the network interface card is
00:11:22:33:44:55 and the IP address to assign is 192.168.0.128, then input as shown below,
and then press [Enter].
(Example: C:\>arp -s 192.168.0.128 00-11-22-33-44-55
3. Execute the ping command for the assigned IP address. In this case no response is returned
from the network interface card.
(Example: C:\>ping 192.168.0.128
4. Turn off the main power supply to the print controller and the main body printer, then turn it
back on.
Chapter 2 Setting Up the Network Interface Card
2-4 Konica Network Interface Card INSTRUCTION MANUAL
A Status Page will be output. Check that the IP address is correctly set in the list. Or, when about 5
minutes have passed after having restarted the print controller and the main body printer using the
ping command, check that the network interface card responds correctly. The ping command is also
executed at Windows 95/98 MS-DOS prompt or Windows NT/2000 Command prompt. The example
of executing the ping command is shown below:
Aug 31, 2009 | Office Equipment & Supplies
Upgrade to XP Pro SP3 necessary?
If you had many problems, it's not necessary, as long as your firewall / anti-virus is configured correctly.
Jul 16, 2009 | Acer Computers & Internet
Closing Worksheet on executing Hyperlink command
You could do this by creating a close button with the worksheet- Do this via insertin ga prompt in Macro.
Dec 20, 2008 | Microsoft Computers & Internet
Hyperlinks in PowerPoint
it is because the compatible MS Office for windows vista is MS Office 2007. if you got a lower version, it is doesn't really work. try to get the latest version of MS Office.
Feb 26, 2008 | Microsoft Windows Vista Ultimate Edition
Hyperlink function in ms access
To Create a Hyperlink Field:
Display the table in Design view, create a new field to store the hyperlinks, click the new hyperlink field's Data Type box, click the list arrow, select Hyperlink, and save the table.
To Insert a Hyperlink:
Select the hyperlink field and then click the Insert Hyperlink button on the toolbar or select Insert , Hyperlink from the menu. Either select a file you want (use the Browse button to help you locate the file) or type a Web address for the hyperlink's destination and click OK.
To edit a Hyperlink: Right-click the hyperlink and select Hyperlink , Edit Hyperlink from the shortcut menu.
Is this enough?
Dec 21, 2007 | Microsoft Office Access 2003 (077-02871)...
Computers & Internet Logo
49 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
