Question about Watts Onan Portable Generator - 4000 , Model# 5500
Onan generator starts but stops after release of button
My onan generator starts when holding down the start button but quits after I let go. I do not have 18-22 volts coming through pins 1/7 at the board. When testing at the brushes of the generator I get no reading. I have cleaned the spindle of generator where brushes contact and cleaned the brushes, I have plenty of brush left with good springs. What else could this be, it seems like it should be something simple
  • 12 Answers
SOURCE: Have an Onan RV generator. WHat kind of oil do I
30W
Posted on Apr 30, 2009
erickg
  • 116 Answers
SOURCE: Oil type for Onan 4000 generator
SAE 15W-40 is what i used to use
synthetic? not sure about that one there may be oil pres switch that could give you a problem.
Posted on Apr 17, 2009
  • 905 Answers
SOURCE: Gen starts and runs with rocker start button pushed in..stops....
Cleaning the brushes is used to address an AC output problem. If the generator would run for a few seconds after letting go of the button, then this might apply.
But, since yours is dying as soon as you let go of the button, that tells me that you are probably looking at a low oil condition, or a sensor / sending unit failure for oil level.
Without spec number, hard to remember if the sending unit is for low oil pressure, or low oil level. Either way, the ignition is being grounded. First, double check your oil level, make sure generator is reasonably level. If still not resolved, then locate the sending unit, and remove the wire that is on the end of it. There should be a connector either a few inches from the sending unit, or a few inches from the control board (coming from big white plug). Disconnect at either place. Try starting again. If it starts this time, double check oil levels. If those are fine, then sending unit has failed, or oil pump (if pressure unit) has failed. In either case, don't run for very long until sending unit is replaced, just in case.
Posted on Aug 25, 2009
  • 142 Answers
SOURCE: Onan Marquis 5000 generator. No gas going to the
12 V going to the pump, but is it turning (do you hear it running). If not change it.
Posted on Jun 13, 2010
SOURCE: RV Onan Emerald 1 Generator
Check all the ground wires and make sure their not broken or loose. If the wires are good next check the neg. Wire to the coil. Too check the swiitch make sure you have continuity too all the post when the switch in the on position, this requires removing the switch.
Posted on Mar 15, 2011
What can cause the plastic fins on the rotor of my Onan 4ky generator to break off and rotor to rub on stator? Bearings are good no play.
Was every thing oily in the generator? It sounds like you may have lost a bearing in the engine. You definately don't want to spend without finding out where the play is that let it rub. It will do it again. Check and make sure that the rotor isn't loose on the motor shaft. Make sure the bearing housing on the end of the rotor won't let the bearing move around in it.
Dec 16, 2015 | Onan Microquiet RV Generator 4000 Gasoline...
Why will my generator start but shuts down when start button is released?
Power to the motor switching off to ignition system check wording is correct.
Jul 25, 2014 | Onan Cummins 5.5 HGJAB-901 RV QG 5500...
Onan genarator will not crank
If it wont crank, check to see if the solenoid on the starter pulls in, the starter and solenoid are one unit, it sounds like an internal starter contact, if you have 12V going to it. Assuming the battery is good. When you press and hold the stop button does the fuel pump pump prime? if so control board has power
Mar 24, 2014 | Onan Generator, 6500W, LP Vapor
Starts runs for a minutes quits but if you keep pushing the start button it keeps running
You say Guardian that is Generac???? Then you indicate Onan 4.0KY. If it is a Onan and it stops after you release the button there are a couple of things. 1 st check the brushes, and polish the rotor slip rings, check the resisitance of the rotor, the electrical harness plugs are tight. The control requires a voltage feedback while cranking to engage the PCB run circuits, if all those check out you have a bad control board.
Feb 15, 2013 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
I have a onan 6.5 emerald gen,when you start it it quits as soon as you let go of the start button, will run fine while holding start button on,then quits when you release,please help,maybe field not...
More likely the switch is bad, and only make run contact when in the start position.
Easy to test the switch continuity with a ohm meter when it is not running.
May 06, 2011 | Watts Onan Portable Generator - 5000 ,...
Aug 24, 2009 | Watts Onan Portable Generator - 4000 ,...
Only runs if I hold the start switch
The problem is that you are not creating voltage. Remove front cover. Place a volt meter on the breaker. Start genset and you will see no voltage present. The problem could be with the brushes, rings, rotor, stator, voltage regulator, or control board.
Apr 10, 2009 | Watts Onan Portable Generator - 4000 ,...
6.5KW Onan generator. wont run when the start button is released
Flight systems can test the onan circuit boards. google them they will come up. First class operation my board was was checked out and back to me in about a week, They also sell new boards and deduct the 20 dollar bench fee if yours is bad and you buy a replacement from them.
Jan 08, 2009 | Watts Onan Portable Generator - 4000 ,...
Watts Onan Portable Generator - 4000 , Model# 5500 Logo
558 people viewed this question
Top Watts Electrical Supplies Experts
Jim London
Jim London
Ottoniel
Joseph Hoffmann
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
