Question about LG GSA-H55N DVD-RAM Burner
DVD writing times suddenly increased from 6 minutes to 45 for the indentical project.
  • 38 Answers
Get some cleaning lense cleaning solution but a bit on a disk a few drops let it spin till disk is dry then try again also restart your computer
Posted on Apr 30, 2010
During 2006, a swimming lesson at a particular school lasted 45 minutes, In 2007 the time will be 50 minutes, Find the increase in the lesson time from 2006 to 2007 as a percentage of the lesson time
Percent change =100%*(new value-old value)/(old value)
If result is positive, it is an increase. If the value is negative it is a decrease.
100%*(50-45)45=100% *(5/45) =11.11 %
Mar 30, 2014 | Casio ClassPad 300 Calculator
Dear sir My LG DVD WRITTING speed is very low. for example. 4.7 G.B DATA DISK WRITTING FOR TIME 45 MINUTS. SO HOW TO MINIMUM WRITING TIME UPTO 4 TO 5 MINUTS. HELP ME
first scan ur pc by antiviruses.some viruses make it slow.then if u use from nero or other softares for writing,u can change the speed or burning from 1X up to 20X in some models of drives.
Aug 08, 2010 | LG Computers & Internet
Rca projection tv
Capacitor on Deflection board cp150 2200uf 16v if it is puffed up on top it is bad 2 more caps cp114 cp120 220uf 35v replace them if cp150 is bad.they are green with gold writing on them.
Dec 27, 2008 | RCA D52W19 52" Rear Projection Television
Dell inspiron 1501 wonnect wireless network?
inspiron 1501..the DVD no play more.write
Nov 28, 2008 | Dell Inspiron 1501 Notebook
Mysterious "ring" on burned DVD causes playback to freeze.
Is the image preponderantly encoded in PAL? Majority PAL and some NTSC? Or fully NTSC? Used transcoding presets? Transcoded project before you built to DVD? Note: Always run "TEST" before burning (to save plastic trees)? Determined whether system or project is faulty? Tested the DVD drive? Tried burning using another application? Closed all background-running resource hogs and applications? Did the project size increase the capacity size of the disk? Used a lower write speed? Disabled startup items and services? DMA: enabled? Updated Windows? Media compatibility? System requirements attained? Updated your application? Solved the issue(s); then write it down and share it with others. Still having issues? Revert back to the computer's factory settings and rebuild, upgrade, or invest in a high-end system and buy the full version of Nero 9, with all the plug-in features....and so forth. If time is money, the latter solution is your best bet. If money is an issue, then it requires trench warfare - that is, much research, deductive reasoning and time investment to isolate your specific problem...start by analyzing your source, and then your target...cause/effect relationship...you'll conquer all problems, eventually...political machinations aside. Ye all be happy computing Chomskyites. Dr. Frank Kohnstein.
Oct 29, 2008 | JVC DRM10 DVD Recorder
Cd/dvd drive problem
there may be operating system problem try reinstalling it or may be u have given the write speed less than 10x... try increasing writing speed....
Feb 02, 2008 | Computers & Internet
Writing to DVD takes excessive amount of time
The problem is that you might not have sufficient memory. Try burning @ 8x. Burning DVDs at 16x is a speed higher than the speed @ which file transfer takes place within the pc. So the lack of availability of memory slows down the proces. I once had the same problem.
I hope u find it helpful sir...
Nov 05, 2007 | Samsung SH-S182D DVD RW Dual Layer Burner
What to do?
This unit also has ballast problems.You most likely will need to call a tech for replacment.
Mar 02, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
Samsun dpl HLN5056W
it's pretty normal for it to take up to 45 seconds for this set to fire up, could be starting to have a problem with the ballast which controls the lamp
Nov 15, 2006 | Samsung HLN5065W 50" Rear Projection...
LG GSA-H55N DVD-RAM Burner Logo
53 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
