Question about Bosch Classixx WFL 2066 Front Load Washer
Fabric softener not been taken away when the machine is in use
The fabric soften remains in the draw after the washing cycle has finished
  • 641 Answers
SOURCE: Maytag Washing Machine
The detergent dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distributed to drawer's cells (following the programmed cycle) by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next test !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Posted on Sep 06, 2007
  • 213 Answers
SOURCE: Problems with fabric softener
you either have low cold water pressure being caused by the screens on both ends of the cold waterline being clogged by sediment or one of the solinoids for the water inlet is bad. try removing cold water hose and cleaning both screens if that doesnt help youll need a solinoid
Posted on Nov 20, 2007
  • 4 Answers
SOURCE: Fabric softener compartment problem.
I have this problem as well.. All washing machines manufactured nowadays are energy effficient, which means that they don't use as much water as the older models. This can result in a build-up of bacteria in the top part of the washing machine, which is clogging up the bit where the water comes through to flush the fabric conditioner into the drum. What I have to do every so often, is to take the top off the washing machine and clean out the layer of black slime that has built up, blocking the holes where the water goes into the washing machine. Another contributory factor is that the usual program used is a 40 degree wash, which is not hot enough to completely flush the machine through. Manufacturers recommend running a 90 degree wash once a month with just washing powder in iit, no clothes. Hope this is some help
Posted on Dec 12, 2007
kjmac
  • 97 Answers
SOURCE: Dispenser still full of water and fabric softener
hiya
this could be caused by a faulty cold inlet valve if the detergent is not being taken away. however if the detergent iis being taken away then the valve is working ok as it fills the compartment with water lifting the detergent out and into the washing machine.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Posted on Aug 03, 2008
SOURCE: Fabric softener dispenser does not empty on Bosch
I have a bosh washing machine and the fabric dispencer was not emptying, i took the compartment out and washed it all out making sure all the muck was off. Then i looked in the machine (where the dispencer had been) and looked up. There were some holes so i got a needle and poked it up and wiggled it, some black muck came out, i cleaned the rest of the holes and now it is working again.
Posted on Mar 24, 2009
Fabric dispenser leaves water in dispenser after wash is done
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a ... filter at the bottom of my machine is also full of water after every wash my machine is Russell ... My washer flushes out the softener but then leaves the water at the end. ... When the wash cycle has finished the fabric conditioner ...
Jan 16, 2016 | Washing Machines
The fabric softener drawer does not empty after a washing cycle so how do I solve this
It is normal for some water to remain in the fabric softener dispenser after the wash cycle is complete
Jan 10, 2013 | Washing Machines
I have a front loading Kenmore washer and when i put liquid detergent and fabric softener, the liquid flows into the machine - should the detergent and fabric softerner remain in their compartements until...
Yes the detergent and softener will stay in the dispenser drawer until the correct time for them to be dispensed. The detergent is dispensed during the main wash cycle and the softener will not dispense until the rinse cycle
Jul 26, 2011 | Kenmore Washing Machines
I have a Siemens XL 1400 washing machine and recently the fabric softener is not being taken from the drawer. I am unsure if this is because the fabric conditioner ( Comfort Concentrate Aloe Vera ) is too...
Siemens
WXLP1460 Front Load
Thisvideo will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question..
Mar 08, 2010 | Siemens WXLP1460 Front Load
Why is water remaining in the fabric softener drawer?
There is a FLAP which acts to prevent backflow into the fabric softener compartment. It is usually synthetic rubber, and covers the end of a tube (from the fabric softener compartment, and is usually cut at an angle. The flap opens to permit the softener to flow out, but apparently is not 'flapping back' to prevent backflow. Best thing is to check that flap, and possibly it is prevented from 'flapping back' by lint or some other bit of fabric/thread/tissue left in a pocket, &tc.
Feb 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
No fabric softener being taken from the draw of washing machine
This video will show you how to keep your soap draw clear and how to service the parts
Nov 01, 2009 | Hotpoint WMA54 Front Load Washer
Water goes thru fabric softener dispenser not soap dispenser!
Yes you will need a service call, you may have a issue with the water valve or control, At the start of the cycle it should not be filling the softener dispenser till later in the program.
Jan 10, 2009 | Kenmore 42822 Front Load Washer
Clothes softener does not drain out of the holder
Do your clothes smell funny? Does it take forever for a load to wash? That happened to me and there was a wire loose in the machine somewhere and it would quit mid cycle and never finished a rinse or spin cycle. My fabric softener never drained either!
Oct 03, 2008 | GE Energy Star WCVH6260F Front Load Washer
Water remains in fabric softner compartment
Is the softener entering the machine; that is at the appropriate time? You can take a peep at this time, if possible. If it is water it is okay; this is just the remaining water. The softener is dissolved with water and flushed into the machine.
Dec 05, 2007 | Bosch WFMC 3200 Front Load Washer
fabric softener This video will show you how to keep your soap draw clear and how to service the parts
Nov 15, 2006 | Bosch WFL 2463 Front Load Washer
Bosch Classixx WFL 2066 Front Load Washer Logo
143 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
