Question about Canon MultiPASS MP730 All-In-One InkJet Printer
Canon MP730 - All pictures are too blue
I have a canon MP730. When printing colour pictures they all come out really blue!!
  • foster_rob May 01, 2010
    I did a head cleaning and a head refreshing.
    the nossle check looks fine, I think, the boxes under L & M are blue are they suppose to be?
    But when i print a picture it is still really blue,
    the browns come out purple,
    green comes out blue!!
    Still no good.
    After studing some prints i have worked out that they contain very little or no yellow.
    So i tried to print a yellow picture,
    it came out a very very pale pink!
    Looking back at the nossle check the yellow is really really faint.
    It gets fainter from left to right and some horisontal lines are missing.
    None of the boxes marked A to M are Yellow.
    How do you interpret the boxes and numbers next to them anyway?
    President:
  • 1,070 Answers
Hello,Check the Following If the printed Pattern is broken, missing, or a specific color is not printed, clean the print head.
  1. Press the <Menu> button on the printers operation panel.
  2. Press the left [<] or right [>] arrow buttons to select [MAINTENANCE].
  3. Press the <Set> button.
  4. Press [<] or [>] to select the cleaning setting you want. Select [HEAD CLEANING] for normal print head cleaning. Select [HEAD REFRESHING] for deep print head cleaning.
    Note: [HEAD REFRESHING] uses more ink than [HEAD CLEANING], so perform [HEAD REFRESHING] only when necessary.
  5. Press <Set>.
  6. Print a Nozzle Check Pattern and perform at least two Head Refreshing if the pattern is not correct.
When replacing the ink tanks, confirm that the new ink tanks are installed properly. If the ink tanks are not locked into place, paper may not be fed properly, or ink may not be supplied to the print head.
  1. Make sure the device is powered on.
  2. Press the <Open> button (1) and lift up the scanning unit. The print head holder automatically moves to the center of the machine.Canon MP730 - All pictures are too blue - 0c4caf3.jpg
  3. Press on the tab to release the empty ink tank, then remove it from its slot.
  4. On the new ink tank, pull the orange tape in the direction of the arrow and remove the plastic wrapper so you can see the air hole.0974e70.jpg
  5. Turn the ink tank over so that the protective cap is facing up. Then hold the ink tank and remove the protective cap.
  6. Insert the ink tank into the empty slot on the print head. Press down gently on the ink tank until an audible click is heard.
  7. Repeat steps 3 to 6 to replace another empty ink tank.
  8. Close the scanning unit until it locks into place.
  9. If additional ink tanks need to be replaced, replace them before starting a new print job.
  • Print Image from another Source
  • Replace Ink Tank
  • Remove tape From Ink tank
Hope this text make you Better..Thanks for Contacting FixYa....
Posted on Apr 30, 2010
  • shafi
    shafi May 01, 2010
    OK ..Check these too..
    Setting Colour Adjustment Click here
    Previewing Document Printing Click here
    Setting Paper Type & print Quality.. Click here
    Setting Print Quality Click here
    >Are you sure the nozzle check is fine? If it
    is really fine then it has to be the ink that is not color balanced. Check also if there is cartridges as contaminated
    Install ink
    tanks in the correct order (from left to right)
    1.
    BCI-3e Black
    2.
    BCI-3e Cyan
    3.
    BCI-3e Magenta
    4.
    BCI-3e Yellow
    Hope this Make you better...Keep Using...
  • shafi
    shafi May 01, 2010
    Check when Using Ink Tank
    Use Only Original Ink tank>Replaced in tank should be
    New>If you Install partially Used Ink tank Nozzles may block (Ink tank
    Replacement Warning may NOT accurate)>For Best to Use with in One years from
    Purchase also Use with in Six month after placing>only open Ink package when
    Ready to Install>Quickly Replace Ink Tank. Delay/Placing out may Cause not to
    properly function when Installed in Machine
    >Printing nozzle check Click here
    >Aligning print head 1.Click here,2. Click
    Most Cases Surely solve by doing any of above things...Keep Using....
Colour printing has a blue tone. Colours are not
This is problem may be one of the cartridges is dry or there is low level of ink .you did all the possibilities check only thing is pending the you can replace the cartridge and see the result.
Have a nice day and do not forget to rate please...!
Feb 06, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Canon mp 730 prints colours BUT NO BLACK
Sounds like you need a printhead, QY6-0064-000 around $40.00. The only other thing that could do that is the purge assembly if it's not cleaning the black part of the printhead properly.
Jul 21, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Colour printing coming out with lines throughout print - shading
my color prints have proper colors but lines come through all through the print even using the best canon photo paper
Jan 23, 2009 | Canon SmartBase MP730 All-In-One InkJet...
My Canon mp730 memory holds a fax- how do I retrieve it?
just press the start/print button on the machine and it should print it out for you.
pressing delete would clear the memory.
Aug 07, 2008 | Canon S200 InkJet Printer
Canon MP730 Pritner
nope..sounds like a communications issue...maybe a new cable?
http://tinyurl.com/6qcpgy
Jul 27, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Colour printing very "off"
is that when you print , or when you scan or make photocopies
Mar 24, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Canon MP730 won't print at all (blank pages).
try to move the blue nozzel over the printing head to the from the right to the left and try, it will work
Feb 03, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Canon smartbase mp730
Have you tried doing some maintenance like nozzle check,printing head alignment,clean the nozzles if not then try it by going into control panel - printers and faxes - where you see your mp730 right click and go to properties then click on the last tab which would be maintenance.Try those options if none worked then u might have to replace you print head and that should work
Nov 26, 2007 | Canon SmartBase MP730 All-In-One InkJet...
Canon MP730 stops printing midstream
Is the issue the same with a anormal text document or just with heavily colored docs? If the text doc gets printed fine, then it is an issue with print spooler and we might need to work on that. revert & lemme know
Aug 05, 2007 | Canon SmartBase MP730 All-In-One InkJet...
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
210 people viewed this question
old marine
old marine
