I HAD A PROBLEM WITH THE FUSING UNIT..MY HARD COPIES BECAME SMEARED..aFTER OPENING THE FUSING UNIT..I FOUND OUT THAT SOME STAPPLE PINS ACTUALLY CAUSED IT..I ORDERED AND REPLACE THE UNIT..bUT AFTER REPLACEMENT I SATRTED GETING ERROR 6A....WHAT DO I NEED TO DO?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To reset this error code please follow these instructions:
1. Turn off printer
2. Hold down MENU button on front panel and turn on power while continuing to hold.
3. Release button after 5 seconds (after the Please Wait message)
4. If error still occurs:
5. Press 91
6. If error still occurs:
7. Press 99
Please do accept the solution if the issue is resolved or post a comment with the manufacturers name and model no# for further assistance.
Thanks
Rylee
Posted on Apr 30, 2010
Black image streaks on sharp 2700n
You only have to make single color copies with each color CMYK
and check all the copies if only the black and white copies is smeary
then replace only the black the drum unit.
Mar 21, 2014 | Sharp MX-2700N Color Copier
Persistent error code on Sharp AR-162S copier
I see the user manual says contact your SHARP service center immediately and is no further help. But a bit of websearching revealed
Error Codes Starting with "H" are fuser faults.
H2-00 Fusing unit temperature error
H3-00 Overheated fusing unit
H4-00 The fusing unit doesn't heat up
If you haven't got the user manual it is here:- http://www.sharpusa.com/files/cop_man_AR162S.pdf
Importantly it shows how to release the fusing unit. If you cant see an obvious problem then you may need to get a new fusing unit.
You may need to reset the copier to clear the error so it can try starting again when you switch on.
Oct 21, 2007 | Office Equipment & Supplies
Code H3-00 / crack in Fusing Unit roller
You should be able to just replace the lower fuser roller if your a technician.
Nov 09, 2017 | Sharp MX-3501N All-In-One Printer
Prints lines on copies. replaced photo conductor unit. didn't make a difference
if you already replace PCU still produce line on copy it could be fuser roller found at fusing unit. if black lines replace fuser unit or if available fuser roller much better but if white lines just clean laser unit. another problem may contribute might be deform frame of scanning section includes mirrors and alignment of lens unit this problem occur usually upon transport of the machine.
Dec 30, 2013 | Ricoh Aficio 1013 All-In-One Laser Printer
The fuser unit does not make contact how do i fix
when you see the fusing unit from the front, you will see on the bottom part of it, have a metal plate with 3 holes. the middle hole is for a screw and the two other are for the pins which are on the machine. now slowly slide the fusing unit inside the machine and see does the pins come out through the holes on the fusing unit. if they do not come out through the holes, then you will need to bend the metal plate or hit it with something for the pins to come out, just be careful to just hit on the metal part. when the pins will come out and the metal plate on the fusing unit will be touched with the chassis of the machine, close the doors the front and the right, and if after that still the machine say that the fusing unit is not set. you have a problem with the connector for the fusing unit. does it is the fusing unit connector or the machine connector for the fusing unit you will need to test. you can spray them with WD-40 as a try.
Oct 03, 2013 | Ricoh Aficio 2035 Copier
In the number of copies selected area a flashing H now appears. what does that mean
There is some problem with your fusing unit try to remove the fusing unit and check the continuity of the heater rod and thermostat contact me if you have any queries and rate me
May 04, 2011 | Sharp AL-1642CS Copier
The copy will print, but parts of the copy are smeared and can be wiped off with fingers leaving nothing on the copy in those areas.
Bad fusing unit. The fusing unit is the assembly that get hot and "fuses" the toner onto the paper just before the paper exits the machine. If you or someone you know is mechanically inclined you could replace the unit yourself. $150 to $180 for the fusing unit.
precisionroller.com has them. Part# R3200
Replacement consists of removing the back cover so you can unplus the wiring. The opening the right side door and removing 2 mounting screws.
Good Luck and Thank You for uning Fixya.
Jun 21, 2010 | Xerox WorkCentre XL2140df Laser Printer
RICOH 1224C COPIES ARE SMEARED
Smeared output can also result when you refeed a printed page into the printer to make a double-sided page. This happens because the rubber rollers that grip the paper to pull it into the printer can pick up toner from the first side’s printing and smear it. So before replacing this is an easy thing to check. Printing multiple pages consecutively will make the pages print progressively cleaner.
Smeared toner also happens because the nonstick coating on the fusing roller is scratched or has baked-on debris. This can happen if the printer is in a dirty environment especially. If you are comfortable removing the fuser, you can try to clean it with a soft cloth and alcohol, but make sure you let it cool down first!
If this does not resolve your issue then make sure the fuser is heating; if not, the thermostat is bad and you will most likely need to replace the entire fuser assembly. This will be pretty expensive to repair so hopefully it's one of those other issues.
May 12, 2010 | Office Equipment & Supplies
The paper comes out crumpled with smeared ink on one side
the problem is the fusing film of the printer. go to a store and try to change the fusing of your printer. sayedelyaskavesh@gmail.com
Jan 18, 2010 | HP LaserJet 1300 Printer
Faxes are hard to read - they're smeared with ink all over.
Sounds like a fuser issue. Check the owner's manual to see if this device has a fuser. If so, try replacing it. If not, next step may be the drum.
Apr 16, 2009 | Office Equipment & Supplies
16 people viewed this question
k24674
jasbo
jasbo
