Question about Sharp AM-400 Digital Multifunction Printer
How do i get a power pack to replace the bad one
    Guru:
  • 324 Answers
HI, check the rating, as in the power in wattage, the current in Amps, you may check on ebay, or sharp website for accessories
Posted on Apr 30, 2010
I have a ML300RTW and I do not hear any noise from the unit or ticking from the timer. When I advanced the timer to check if it would send power to the lights, they come on and when advanced to turn off...
Power packs do not have repair parts anywhere on the internet that I know.
Occasionally folks take power pack apart, but nobody reports being able to repair transformer or timer.
Once power pack goes bad, then it needs to be replaced.
Good news for your specific problem however:
'Harry' wrote to fixya with some information.
His timer stopped working so he bought cheap plug-in timer, set power pack to override, and then plugged power pack into cheap timer. Cheap timer turns lights on-off.
Harry also said his power pack has 5 year warranty and he was negotiating with Malibulights.com. No word how that came out.
Best I found are tips for next power pack that might save money:
The reason I add tips now, before your power pack needs replacement is some fella wrote fixya.
He bought 500 Watt power pack to replace 300 Watt > thinking bigger was better.
Power pack burned out. Here's why:
a) Match wattage of bulbs with wattage of power pack
Lets say you have fifteen 20 watt bulbs = 300 watts, so install 300Watt power pack
b) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
c) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
d) When working on bulbs, unplug power pack or power pack may burn out.
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 11, 2011 | Intermatic Malibu 300W Power Pack...
I have the 300 watt xformer. Lights worked fine for quite a while...now the lights come on and go instantly off, agai and again almost 'flickering" I am positive I have less than 300 watts on the...
Use manual override and see if lights work correctly.
Check that bulbs are each working. If one bulb is burned out, then others will burn out, and the load change can cause power pack to stop functioning.
Always unplug power pack when working on lights.
I checked Intermatic, Malibulights, ebay, amazon, and listened to fixya customers.
Occasionally folks take power pack apart, but nobody reports being able to repair the transformer or timer.
Once power pack goes bad, then it needs to be replaced. Bad news because they're expensive.
Harry also said his power pack has 5 year warranty and he was negotiating with Malibulights.com for replacement. No word how that came out.
d) When working on bulbs, unplug power pack or it may burn out.
Feb 04, 2011 | Malibu Intermatic Inc. ML121RT Low...
The clock has stopped working. Can clock be replaced?
If I understand correctly, you have Malibu power pack and can manually turn lights on-off but timer is not working.
1) 'Harry' wrote fixya with a work-around. He bought cheap plug-in timer. Set power pack to override and then plugged power pack into cheap timer.
2) Harry also said he has 5 year warranty and was negotiating with malibulights.com for refund.
3) Other than Harry's solution, I have not found repairs and parts for power packs.
Hours of reading manuals, searching Malibu, Intermatic, ebay etc turned up nothing.
There are folks who write fixya how they took apart their power pack, but nobody reports fixing a power pack once it goes bad.
4) Best I found are tips for next power pack that might save money:
The reason I add these tips before your power pack needs replacement is some fella wrote-in.
-15 each X 20 watt bulbs = 300 watts, so install 300Watt power pack
Jan 25, 2011 | Malibu ML600TW - Low Voltage Power Pack -...
Timer dial does not move must use manual switch on timer to turn lights on
If I understand correctly, you have a Malibu power pack and can manually turn lights on-off but timer is not working.
1) 'Harry' wrote fixya with a work-around for this problem. He bought cheap plug-in timer. Set power pack to override and then plugged power pack into cheap timer.
After hours of reading manuals, searching Malibu, Intermatic, ebay etc I found nothing.
There are folks who write fixya how they took apart their power pack, but nobody reported fixing a power pack once it goes bad.
The reason I add these tips now, before your power pack needs replacement is some fella wrote-in.
5) Add a comment for more free help.
Jan 21, 2011 | Intermatic 200W Power Pack & 12v...
On the zt1135 pavilion the brand new battery won't charge. It is the correct battery replacement. OS: windows xp home edition. The orange light on laptop lights when battery is charging. Well, after...
well it can only be 3 things
bad battery
bad power pack
bad mobo.
the mobo as a charge chip, the power pack is just 19vdc .
if the chip is bad or there are shorted modules on the MOBO
the charging will fail. (battery good.)
is the power pack new, and 19vdc and at least 65watts>?
Jul 16, 2017 | HP Pavilion zt1135 Notebook
Hums but no power to lights
If I understand correctly, you have a Malibu power pack and can not manually turn lights on-off but timer is humming so the timer has power.
1) That eliminates electric circuit as suspect.
2) Try to spark a wire across terminals and see timer has power on terminals.
3) Check that your bulbs are good, because they can all burn out in a hurry if a couple of them suddenly go bad.
4) I have not found repairs and parts for power packs.
5) Best I found are tips for next power pack that might save money:
The reason I add these tips now, is some fella wrote-in to fixya.
Jan 07, 2011 | Malibu ML600TW - Low Voltage Power Pack -...
Power outage caused by bad weather. Afterwards, DVD will not come on...no electrical power seems to be incoming. Help?
Due to the power outrage caused by the bad weather. The voltage that got into the player was so high that it affected the power pack of the player.
To fix this, you have to get the appropriate screwdriver and unscrew the cover of the player, you will see a board that is attached to the cable that is plugged to the power source.
Get a meter reader, test the components of the power pack and you will notice the part that is burnt.
Replace the power pack with a new power pack and the player will be in good condition again.
Take care.
Jun 14, 2010 | Protron PD-DVR100 DVD Recorder
Where can i purchase replacement timers for malibu 300watt power pack trans former. have 14 in yard three have bad timers.
The clock motor has gotten weak and now it is overheating and will not recover.
There are no replacement clock motors.
To buy more time with old power pack, purchase cheap plug-in timer, set power pack to override, and then plug power pack into cheap timer.
For more information on power packs showing replacement trippers, useful links and tips
http://www.fixya.com/support/r8391011-power_pack_not_working
May 23, 2010 | Intermatic Malibu 300W Power Pack...
Procedure of replacing coil pack on 1998 Ford
see if you have power to the coil pack.if your have power tothe coil and no power coming out . the coil is bad. check your fues
Sep 23, 2009 | 1998 Ford Escort
Power pack creates 'hummmm' in wireless headphones.
I don't think the 12V power pack is the problem. Generally there would be a regulator on the plug pack input to the transmitter (as power packs are notoriously bad at voltage regulation).
My guess is it an 'earth leak' between the TV and the transmitter via the audio lead. Does the powerpack have a earth pin. If so, are you able to plug it into an non-earthed power outlet.
If this isn't possible try removing the ground connection from the audio lead.
It could also be a bad audio lead.
Is the TV mono and the transmitter stereo or visa versa? You may need a mono to stereo lead.
Hopefully something in here will help.
Mar 17, 2009 | Electronics - Others
26 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
