Question about Microwave Ovens
There is power to fan I replaced the thermostat, and oven element Now I don;t get power to the grill.
  • glesses Apr 30, 2010
    This is a wall oven not a microwave.
  • Microwave Ovens Master
  • 19,396 Answers
Hi.
Check connection to the top element and test the element using a multimeter.
Baking and broiling elements use the same temperature sensor. If you wired the new sensor correctly, the problem may be the element itself.
The element is tested setting the multimeter on Ohms, at Rx1, disconnecting the broiling (top) element , and reading impedance on the element terminals.
If the element returns no continuity (infinite impedance), then the element must be replaced.
If the element is ok, test the wiring harness. This is more difficult to test using impedance because you need to know where the harness to grill is connected to the OEC (electronic control board). The techs usally test the timer board reading volts. Testing with live power is not suitable for home user. As from manufacturer indications I suggest performing only tests that can be done with power off.
Test the top element, the wiring harness, then eventually the control board and replace the faulty part.
Parts can be ordered calling the number on manual. Diagrams for most makes and models can be found using the websites listed on the link below:
Where do I find parts and diagrams?
Regards.
Posted on Apr 30, 2010
  • Ginko
    Ginko Apr 30, 2010
    Hi.
    I know that this is not a microwave. Microwaves rarely have two elements. My answer was for a conventional oven.
    We know that the model selection system has its troubles, and we are used to this kind of confusion.
    As said my solution was not for a microwave.
    Best regards.
    Ginko.
My panasonic NN-8500 microwave/convection oven the microwave part is working fine but,the convection grill defrost is not
Possibly the defrost heater element has failed. You will need to strip the cabinet off and use a multimeter to test the element. May also be the overtemp safety thermostat may have failed.
Nov 19, 2016 | Panasonic Microwave Ovens
I have a built in wall oven whirlpool gold mod.gbs309pvsoo controls turn on but no heat from element
Could be element could be Hi limit thermostat could be control. In that order. First step is turn breaker off and remove element to make sure the wires are still connected to back of element. Visually inspect element very good for burns or a white powder residue signally the element burned up. Next step is harder, need to remove the oven and take off back panel, there you will find the hi temp thermostat. Check for continuity, if none replace.
Feb 02, 2015 | Whirlpool GSC309PVB 30" Built-in Microwave...
Both oven lights blown and fan not working
If you've noticed that your oven is not heating up, there could be a problem with your oven fan thermostat.
its simple to check :
1.
Open oven door and locate the back plate, which can be found at the rear
of the appliance. Remove the back plate from the oven fan (it should be held in place by between two and six screws). The oven fan is located behind the back plate.
2.
Examine the oven fan element and the fan blades (they are exposed once the back plate has been removed). If there are noticeable signs of burning, blowing, bulging or splitting in an area of the oven fan, you can tell where the problem is coming from. It is also common for there to be no visible signs of a problem. This allows you to determine whether or not the oven fan can be replaced from inside, or if it is necessary to enter the back of the appliance.
3.
Remove screws from element and disconnect wires if screw heads are showing. This is commonly the case, as it is unusual to have to further disassemble the oven. After the screws are removed, the element becomes detached from the oven. Use caution to not accidentally pull out electrical wires that are connected to the element.
4.
Take the rear cover off, which is held in place by multiple screws. After that, you should be able to see the wiring harness, fan motor and the components of oven fan element. Parts of the fan element are near the round fan motor, which is located at the center of the oven. There are two electrical connections and one earth wire. Take note of the location that the earth wire is placed, because it needs to be restored to the same position.
5.
Remove the oven fan element. Check the element again for obvious signs of damage. If there are no apparent markings, check the oven with an electrical test meter or a continuity tester. After replacing oven fan element, return all connections and covers to their original positions.
This should help you up to an extent to check it in case of any assistance please revert back.
Jun 10, 2011 | Microwave Ovens
My elba c96df oven has stopped working . The oven lamp comes on but theres no heat . Is it the elements or the thermostat?
Elba Oven not heating? How to replace a Elba fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for Elba element How to Repair Home Appliances
Mar 06, 2011 | Microwave Ovens
The fan assisted oven is not heating up, but I can hear the fan as I usually would. The top section (grill) is working fine.What could be causing this ? thank you
Probably the element has failed. Change the element or get it changed.
Spares are available from most appliance repairers or ebay.
Jan 30, 2011 | Microwave Ovens
There was a bright light from inside the oven. The fan still goes around providing the grill switch is on and the oven grill and top and bottom element still work.
Carbonised food build up or a metalic object was in the cavity as it was being used, causing internal arcing inside the food cavity. You may find the cover over the magnetron aerial is blackened. If it is change it.
Clean the oven cavity and check for damage.
Hope that helps.
Dec 11, 2010 | Microwave Ovens
Arrow fan over
problem solved, needed a new element , it has cost £60. thanx anyway
Jul 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
23 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
