Question about JUMP START SYSTEM
I had my jump start hooked up to car lighter when I hooked it up to battery.. didn't notice it was in the on position. There was a spark and now the box does not work, nor does my car outlet. What happened?
  • 3,740 Answers
Check the Lighter Fuse. It has probably blown. As for the Jump starter it also may have blown an internal fuse of failed completely. You turned it into a heating element when you connected it to the battery while plugged into the lighter. More or less you smoke checked it. Do you have a model number for the Jump start unit? I will see what I can find.
Kelly
Posted on Apr 30, 2010
Motor blows fuse
there is a short in the system that is connected to that relay/fuse. Could also be melted wires if you tried to ever jump start it from a car, start position on a charger or jump start box. Jump starting a motorcycle should never be done. The gauge of wires on a motorcycle are much lighter than vehicles.
It is VERY rare but i have seen batteries that are reversed polarity. Check to make sure battery is 12v + when you test it. Not 12v -
Apr 03, 2014 | 2007 Suzuki Boulevard S40
Tip
Jump starting a Buick Lacrosse 2005
Jump starting
If your vehicles battery has run down, you may want to use another vehicle and some jumper cables to start your vehicle.
1.Check the other vehicle. it must have a 12-volt battery with a negative ground system.
2.Get the vehicles close enough so the jumper cables can reach, but be sure the vehicles are not touching each other. If they are, it could cause a ground connection you do not want. You would not be able to start your vehicle, and the bad grounding could damage the electrical systems.
3.Turn off the ignition on both vehicles. Unplug unnecessary accesories pluged into the cigarrete lighter or the accessory power outlets. Turn off the radio and lamps that are not needed. This will avoid sparks and save both batteries. And it could save the radio.
4.Open the hood on the other vehicle and locate positive (+) and the negative (-) terminal locations on that vehicle. You will not use yours vehicles battery for jump starting. It has a remote positive (+) jump starting terminal, located on the underhood fuse block, for that purpose.
on Oct 08, 2010 | Buick LaCrosse Cars & Trucks
Car will not start
A simple jump start with battery cables should get the car started and recharge the battery. If you don't like dealing with battery cables, there are products that attach from inside the car using the cigarette lighter to jump start the car that work very well.
Oct 28, 2011 | 2008 Toyota Prius
Haven't run the bike in a while, won't start. I have run the battery down trying. Where do I hook up to "jump start" from a (non running I am told) car?
Personally, unless I was stranded somewhere, I wouldn't jump start the bike. I'd rather recharge the battery and try to start the engine again. But, you may wish to find out why the engine is not starting rather than continue to run down the battery or take a chance of damaging electronic components with a voltage spike. You didn't tell me what year and model the bike was nor whether it's carbureted or fuel injected. If's it's been sitting for an extended period of time, the fuel system may be gummed up due to the fuel evaporating and leaving the gummy residue to stop up the fuel passageways. But, if you still want to jump start the engine, connect the jumper cable directly to the battery in the bike, positive side first to positive post of the battery. Connect the negative from the car's frame or engine to the bikes engine or frame last. This prevents a spark and the possibility of the battery blowing up your face. I've had it happen before and it ain't fun.
Good Luck
Steve
Sep 12, 2011 | Harley Davidson XLH Sportster 883...
Hi, I have a 2008 Pontiac G5 and I accidentally kept the lights on all day. Since I only have a positive (red) connection, I ground the negative connection to metal as well as the other car negative...
sounds like you are on the right track. Hook the jumper cables up to the dead car first. The red cable should go to the jumper terminal as you mentioned and a good place to hook up the black cable is the bolts on the strut tower.
then with the other car running hook up the red lead to the cars positive battery cable and then the negative to a good ground. Let the two cars sit for about 5 to ten minutes to give the dead battery a chance to charge.
Once the dead car is started let it idle with the lights turned off for at least 45 minute to an hour or drive it for the same amount of time with the light on (I assume you will be driving in the dark) or if its day time drive it for 30 to 40 minutes with the lights off. This should be enough time for the alternator to charge the dead battery.
Jun 24, 2011 | 2006 Pontiac G5
I have a 2001 alero with a manual transmission. My battery is dead and I am wondering if I can jump start it or will the security system not allow it? I tied it once but it didnt start.
You should be able to jump start it, make sure that your battery cables are tightly connected to that battery. Then hook up that positive battery cable on the car that is running then the positive on the battery you are jump starting then hook up the negative cable on the car running then the negative to the dead car. If your connections are good when you hook up the last connection you should be able to see a little spark, and hear a hissing or popping noise. Leave it hooked up for at least 5 minutes before you try and crank it. If it then cranks and then just clicks you need a better connection between the jumper cables. If you get nothing it might be your starter if you are getting headlights, and a radio working. If nothing works there is a bad wire somewhere.
May 15, 2011 | 2001 Oldsmobile Alero
Is there a proper way to jump start my 1999 Mercedez CLK 320?
When jump starting any vehicle always hook up the positive to the battery first and then hook the ground(black) lead to some metal surface on the engine. This way you do not throw sparks near the battery.
Nov 17, 2010 | 1999 Mercedes-Benz CLK
How do you hook up booster cables to the battery of a 1999 Breeze. I notice that there is a negative mount on the frame, but I can't seem to locate a metal surface to put the positive cable on. Where is...
Along with the solution provided above be sure to hook up the positive cable Red to the positive cable on the car to be jumped and the car used to jump the battery both cars off. Next on the car with the dead battery hook up the negative cable to the frame of the car if it is a liquid or lead acid battery, next hook up the negative cable to the car that will jump the other dead car. Warning an arc can cause an explosion if there is gas coming from either battery so when hooking up the negative cable be sure to clamp the negative cable on the frame. Next start the car and rev it to about 800 RPMs hold it to 800 RPMS for about 5 minute's before try starting the other car, this will allow the other battery to charge up and will help start the car. If you have small jumper cables like #6 copper give it about ten minutes to charge before try starting or you could damage the alternator of the charging car. once the time has elapsed try starting the other car, push throttle down once while cranking it over and hold pedal half way till it starts, do not crank for more than 30 seconds if it does not start wait for the battery to charge up again to try starting. with low voltage condition if you crank the car and it slows down it can damage the computer by drawing to much amperage caused by low voltage.
Dec 18, 2009 | 1999 Plymouth Breeze
Jump start
The battery "jumper terminals" are in the engine bay on the right side. You have to remove the black steel cover plate by removing the 3 screws, then you'll find the terminals. The positive terminal is marked red, unless your previous owner has resprayed the engine bay.
Be careful if you are 'jumping' the battery; the power source has to be even. If you can not use a boost pack and have to use jump leads from another car, make sure the other car engine is switched off - you can damage the management system
May 15, 2008 | 2005 Ferrari 612 Scaglietti
JUMP START SYSTEM Logo
171 people viewed this question
Top Vector Vehicle Parts & Accessories Experts
Lawrence Oravetz
Vernon Taylor
Are you a Vector Vehicle Part and Accessory Expert? Answer questions, earn points and help others
