Question about HP Compaq 6510B Keyboard - 446448-001
Any key in the laptop keyboard are not working tell me how to troubleshoot
2 keys of hp laptop keyboard not working
If you find that some important keys are not working on your notebook keyboard, they can be difficult or, more often, impossible to fix. The best solution is naturally to have the keyboard replaced. This is a big enough job on a laptop as the machine has to be taken apart to replace the keyboard.
Another solution I reccommend is to REMAP that keys that do not work. Using a small program you can tell your computer to use another key instead of the key that does not work. In this way you can take, for example, an important key like the "delete" key, and remap it to an unimportant key, like the "Alt Gr" key. Then pressing Alt Gr will perform the delete function. This is really a temporary solution but if you can live with it, then by all means use it permanently.
The best program for this process is called SHARP KEYS and is free to use. It can be downloaded here: http://sharpkeys.codeplex.com/
Jun 02, 2014 | Computers & Internet
"t,y" keys not working on
have you tried an external USB keyboard? That will really tell what the problem is.
kc
Mar 15, 2011 | Computers & Internet
I have a dell inspiron 1420 laptop. its keyboard is not working. none of its key respond on clicking. it tells me to reseat the keyboard. how to solve the problem? if to reseat, how to do it?
1. check the driver, reinstall & try.
2. check with a external key board. if working fine then ur motherboard is OK.
3. open the keyboard & clean the dust in the keyboard cables and motherboard connector.
4. if still not working ur keyboard might need replacement. check for any liquid spell on keyboard.
5. for replacement contact DELL customer support.
Aug 17, 2010 | Computers & Internet
Can you tell me how to switch my laptop keyboard
Hold function (Fn) key down and press the key on the top row that has a sign (picture) showing a padlock insde a square. (Num lock key) Normally "scroll" key
Apr 02, 2010 | Gateway 2520915 Keyboard
Keys grouping on keyboard
Sorry to have to tell you but it does look like you did maim and injure your keyboard.
BUT all is not lost
If you are willing to put some time and effort into it and feel comfortable pulling things apart but more important being able to put it back together again then you could remove the keyboard strip it down do a proper clean and re-assemble
Hmm not happy at the prospect ?
Ok plug a cheap USB or PS2 (check what you need) keyboard in and that will get you going again for the moment.
Bit Happier I hope ?
But wait there is more
Ebay is a prime source of laptop parts at great prices and the good news is that laptop keyboards are not as expensive as many might think !
They are for the most part easy to replace too !
You didn't tell us what model your lappy is so I could find a site to send you for the destructions (oops) but I am sure you can work google and maybe type "mymodlelaptop replace keyboard"
If this information is useful please click below
Aug 19, 2009 | Dell Computers & Internet
Hai, In my laptop keyboard some keys are working som r not like if i press spacebar,bacspace and H key only then somthng is getting typed..when ipress other keys nothing is hapening..? please tell me how...
Actually Laptop Keyboard are being replaced by a new one. Its defective already.Technically need a replacement.
But here some options to use your laptop by using USB Keyboard. Just plug it in your USB Port and it works.
Aug 18, 2009 | Computers & Internet
My keyboard is a mess when almost all the keys
They may have removed the keys to clean the keyboard and placed them back in the wrong spot.
Check the keys against another beyboard and see if the keys have been placed in the wrong spot.
Take it back to the people/company that did the work and tell then the keyboard is not working properly.
Jul 12, 2009 | Toshiba Satellite L305-S5907 Laptop
Keyboard repair
You should call Acer tech support and enquire about a keyboard. I am sure that they will tell you to take the computer to their rep for your area. Normaly they change the keyboard when there is a fault. If the circuit board under the keys is defective or if one of the IC's on the board failed, this would not be servicable at all. The keyboards on these computers were not really designed to be able to be serviced.
Jerry G.
Apr 19, 2008 | Computers & Internet
Help please tell me why my keys will not work on my laptop.
Try using an external USB desktop keyboard (or a PS2 keyboard, if you have a PS2 jack on the laptop).
If everything works then, your laptop keyboard is malfunctioning. This is usually due to one of three causes:
1. One key is stuck in the "down" or "depressed" position (collapsed/dented silicone cup beneath, or damaged flex legs under key). Look at the keyboard from the side, to see f any key looks lower than the rest (or higher than the rest) Be careful taking it apart to clean and reassemble.
2. Bad ribbon connector, torn, or merely corroded/oxidized keyboard cable connector. This requires opening the laptop to fix. Usually 2-3 screws under laptop labeled as keyboard, allow it to be pried off. Release the cable LOCK, and remove the thin ribbon cable. Reinsert it 5-6 times to clean off contacts, and LOCK the jack again once you are sure it is all snug. If the ribbon was TORN, you will need a new one. Good luck, not easy to find on old laptops.
3. Worst scenario... someone spilled coke (the worst) or beer/beverage inside the keyboard. This eats up the printed oxide connectors, and this cannot be repaired. you will need a new keyboard assembly.. Use a magnifying glass to look between keys, to see if there is stickey, gooey material there. This would be the bad news indicator for number 3.
Feb 10, 2008 | Toshiba Satellite A105 Notebook
HP Compaq 6510B Keyboard - 446448-001 Logo
52 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
