Question about Compaq Evo D310M 845G P4 Motherboard
Compaq EVO D310M shuts down and restarts automatically
I know its an old PC but a newer unit is not in my budget. I have a Comapq D310m with a 845G P4 MB. I installed a 2nd HD in it. When I attempted to reboot the PC comes on, all lights work, then reboots by itself with a post code of 1S/2L beeps. I have reseated the RAM, Cleared the CMOS, reseated the ATI PCI Video card and removed the New HD and set everything back to original. Still no help. Running windows XP SP2 with all current patches installed. Can anyone Help me here or am I out-of-luck and have to replace my system?
  • tavarish Mar 25, 2008
    Yes, I have made sure all the jumpers are set correctly. I actually removed the second HD and made sure the original was set to CS. The cable interface is using the nearest connector to the MB as was original.
    I think it has something to do with the Video but do not know why it worked before attempting to install a second drive but does not work now.
Have you tried to re-configure the jumpers on the back of both the hard drives? There should be a master/slave setting on the drives. On such an old PC there will be jumpers on the drives to configure. Move the jumper on the original hard drive to MASTER and the secondary drive to SLAVE setting. Also, there is a cable select setting on both the drives, when using this setting you must make sure that the MASTER Drive is attached at the end nearest the Motherboard and the secondary drive is attached at the farther end.
Posted on Mar 25, 2008
SOURCE:
Can I increase the RAM from 504 to 1008 on my D310m/845G?
Yes you can increase the RAM of your motherboard. It contains two DIMM slots, but can only be upgraded to a maximum of 2-GB ( max of 1GB on each slot.) The slots support DDR Synch Dram PC2100 (266-MHz) and DDR Synch Dram PC1600 (200-MHz) Non-ECC Memory only.
Nov 02, 2010 | Compaq Evo D310M 845G P4 Motherboard
How can i clear the bios pasword compaq evo D31MP.2.4 MS-6541 Ver 1.0
remove the cpu cover look for three pin near the cmos remove the jumber connect it with the pin which is free and restart in some motherboard the cpu wont start dont panic remove the jumper and replace it in earlear position and restart this clear the bios password
Oct 13, 2010 | Compaq Evo D310M 845G P4 Motherboard
Wanted mother board drivers p4 compaq 845g
If you can't find them at the Compaq site, then go to http://www.belarc.com and get the free Belarc Advisor, which will tell you what components are in your system. You should be able to find drivers from there.
Jan 23, 2009 | Compaq Evo D310M 845G P4 Motherboard
Most of the drivers/software I get are from a web site driverguide.com you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
Motherboard
EVOD510 FF (33 MGB)in place of this can I use this Evo D310M 845G P4 Motherboard please suggest.
tks & regards
Sreenivas
[email protected]
Apr 17, 2008 | Compaq Evo D310M 845G P4 Motherboard
Adding AGP Graphic Card on Compaq Evo D310M 845G P4
Was it onboard graphics you had before? If so there is a setting in the bios that you need to change to get it to run from the agp slot.
Hope that helps?
Jan 05, 2008 | Compaq Evo D310M 845G P4 Motherboard
Compaq Evo D310M 845G P4...
Best bet would be to hit up ebay for this and look on there for spare parts.
Just take what you posted in the title and hit ebay.
Note: prices may vary and if you bid be sure you are getting a working board.
Nov 29, 2007 | Compaq Evo D310M 845G P4 Motherboard
Compaq Evo D310M 845G P4 Motherboard Logo
138 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
