Question about Microsoft Windows XP Home Edition
LOCAL AREA CONNECTION
How to remove ''Cancel'' button that sometimes appear while repairing the Local Area Connection?
  • 1 more comment
  • dreamz_147 May 01, 2010
    Nope! Not working!
    Any new trick please!
    Nope! Not working!
    Nope! Not working!
  • Microsoft Master
  • 12,061 Answers
Simply "Refresh" the desktop, right click, anywhere on desktop, and select, "Refresh".
Posted on Apr 30, 2010
  • electronic & computer repair&  servicre
    Log OFF and then log On again, leaving everything still running... Also get a program called WINSEIZER, it is a "Window" "Grabber' with it you can close, move whatever ANY window on your desktop, i use all time to shut down bad windows, get it and use it.
    http://www.alexnolan.net/software/window...
Connected with limited connectivity
Go to your local area connection from Control panel>Network and internet connection>Network connection.There choose the property of your local area connection.
In property,uncheck the option Notify me when this connection has limited or no connectivity.And choose OK button.Now you have done.Now disable and enable local area connection from network connection.You will seenotification saying acquiring network address and connected.The error of limited area connectivity will never disturb you again.
Resource : http://www.ehowportal.com/fix-limited-connectivity-laptops-wireless/
Apr 26, 2012 | Computers & Internet
Tip
Forcing Card
Windows XP:
1. Click on the Start Menu, and then click on the Run option.
2. When the DOS window opens, then input control ncpa.cpl into the Run field, then click on the OK button.
3. Either the Network Connections or Network and Dial-up Connections screen will then appear.
4. On this window, please right click on the Local Area Connection that controls the Ethernet Adapter (normally the one without a number if there are multiple Local Area Connections) and click on the Properties option from the menu that comes up after right clicking on the icon.
5. When the Local Area Connection Properties window appears, click on Configure.
6. When the Adapter Properties window appears, click on the Advanced tab.
7. After the Advanced section loads, look under the Properties section for Connection Type, Media Type, Connection Speed, or Link Speed/Duplex Mode.
8. After selecting one of the options above, change the Value from Auto to 10 Base-T, 10 half mode, 10 half duplex, or something similar.
9. After changing the mode, click on the OK button. Please click on also the OK or Close button on the Local Area Connection Properties window. The Network Adapters speed will then be 10 Mbps Half Duplex.
on Mar 29, 2010 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
My wireless laptop cannot detect wireless networks..
Try this,
* Click Start * Click Control Panel * Select Network and Internet Connections * The Network and Internet Connections window will appear: Select the Network Connections icon * The Network Connections window will appear: Double click on Local Area Connection * The Local Area Connection window will appear: Select the General tab and click, or highlight Internet Protocol and press Properties * The TCP/IP Properties window will appear: * Make sure that both the Obtain an IP Address Automatically and Obtain DNS Server Address Automatically are selected, or checked.
If this helpful, please give a testimonial and vote by pressing button four thumbs up icon.
Sincerely Thiyaga
Aug 28, 2011 | Acer Aspire 5315 Notebook
My laptop wont connect to hub when wireless, says ip address wrong
Try manually locating ip address to your laptop Right click on the local area connection icon and then click on Status, click on the properties this will help you to be able to Change the Local Area Connection Properties, Click on the Internet Protocol(TCP/IP) Click the properties button under then click on use this IP address provide the required IP address, Subnet mask and Default gateway and also click on use this DNS server address and then fill the field as necessary after try repairing the Local Area Connection.
Mar 18, 2011 | Computers & Internet
I have a wireless router, my vista laptop is upstairs in my room, my wireless network connection is working. but the "local area connection" says that there is a network cable unplugged. but i have...
"local area connection" is the wired connection, which in your case is "unplugged" If you go to control panel and look in connections, you will see that you are connected with the wireless, if you right click on the wireless there is a checkbox to display the status on your toolbar along side of the "Local Area Connection" Hope that clears it up a little
Aug 29, 2010 | Computers & Internet
I can't find my local area connection...how can i can i get it?
may in service pack 2 there is no LAN but you have to reinstall to he your original service pack that you to contact dell and one more thing for you have to install drivers of connection or internet because your service pack2 has not installed drivers
Dec 16, 2009 | Dell Computers & Internet
Network Connections missing icon. Plus others problems.
XP tags "Local Area Connection #" with your Network Adapter. If you have a built-in LAN, it will take Local Area Conn 1" and when you disabled it and plugged in a new network adapter, it will be named Local Area Conn 2 and so on in that pattern. Your Local Area Connection will only be back when you plug the original Network adapter that XP tagged as Local Area Connection. It is not "variable" where you can choose how to name it.
Jul 31, 2009 | Computers & Internet
My computer (Dell) unknow Network Card
i) Click on Start button ---->Select option Control Panel------>Select Network Connections----->
  a new window appears showing the "internet connections icon " Such as:
  Local Area Connection 1 or 2 or 3 and since you are not connected it will show this icon as:
eg1: Local Area Connection 1 or 2 or 3
  Network Cable Unplugged, Firewalled
  VIA compatible Fast Ethernet
  in this case u can download VIA network drivers....from internet..
  or
  eg2: Local Area Connection 1 or 2 or 3
  Realtek RTL8139 Family Fast Ethernet NIC
  in this u can download "Realtek RTL8139" network drivers.... from internet(which is showing model     no: RTL8139 through google search engine )
        (OR)
ii) Click Start button ---->Select RUN option ----> type in the text box devmgmt.msc --->Select               Network Adapters....
    but this will show wheter ur network adapter or NIC is VIA or Realtek or......but doesnt show the           correct Model NO: of VIA or Realtek....
    so i would suggest to follow the step (i)
Thanking you
M.Sridhar
Dec 25, 2008 | Dell Ethernet Card Network Adapter
Local area connection
If it says that your local area connection is unplugged then you cant have a cable plugged into the ethernet socket on your pc into a router or there is a break in the cable.
Feb 10, 2008 | NetGear WGT624 Wireless Router
Microsoft Windows XP Home Edition Logo
52 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
