Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Brush will not turn
Cannot get the brush to turn.
  • 20 Answers
Assume that the belt is broken to the power brush /head. Did you happen to smell burning rubber or see small pieces of black rubber? Look in your manual for replacing power head/brushes belt! With the unit off , try turning the brushes by hand and clean them off of debris, etc., as well while there. See if you feel some tension or hear the motor moving inside, indication that the belt is still attrached and if it doesn't seem to have any resistance and you see small pieces of rubber and /or, the band/belt may have just broke from normal usage. WalMart sells most types or your local vacuum repair facility.. check the Yellow pages and let your fingers do the walking.. Good luck
Posted on Apr 30, 2010
  • 833 Answers
SOURCE: brush not turning
ez...there may be a second belt or the bearings in the beater are gummed up. Open up the area where the beater is. There should be a belt in there...if it is broken, you'll have to replace. Before you do...turn the beater by hand...if it turns hard, the bearings are jammed up with old grease or debris. You'll have to deal with that.
Posted on Dec 07, 2007
Kazong
  • 152 Answers
SOURCE: Rotating bruch
take off the bottom cover where the roller brush is a few screws should be all it takes underneath cover should be roller and belt if belt is broke replace it lift up roller there is a slot for the belt to run in put other end should be the motor side put belt around pulley bar put it back the same way it came off.
hope this helps
Posted on Jan 06, 2008
SOURCE: rotating brush will not turn on my Dyson DC07
Yes I had the same problem on my animal Dysom. There is a button on the top of the dysom that turns the cacuum on. Right beside that button is another one that turns on and off the brush!!! Good luck!!! I accidently one day bumped that button and couldn't get my brush to work but after troubleshooting it, that was my solution.
Posted on Jan 24, 2009
SOURCE: The brush on my Dyson DC17 Animal does not turn
Remove the plate over the brushbar. Gently clean out debris. Put plate back on,plug in and turn on vac and press brush bar button to reset.
Posted on Apr 12, 2009
  • 3 Answers
SOURCE: brush froze up and keeps breaking belts
I had the same problem but I found that I had replaced belt incorrectly. After placing one end of belt around pully, it has to be run behind the "belt disengager" which looks like a 1/2" wide metal tab just past pulley. After placing belt correctly I had no more belt, burning smell or brush problems.
Posted on Jul 28, 2009
Bissell heavy duty 9x cyclonic vacuum cleaner has loud noise when brush roller is turned on
Inspect the area around the brush roll. There may be something stuck somewhere in there. Remove the brush roll to see if the brush roll end caps will spin freely. If there is hair or debris restricting the brush roll may be causing noise.
Feb 19, 2015 | Bissell Carpet Cleaner Powerbrush Deep...
Brushes not turning, 2 inch piec on one brush in place, the housing is spinning but not turning brushes
Hello there! It sounds like you may need to replace your brush block assembly. Try turning that drive shaft connected to the middle brush. All the brushes should be able to do a full turn simultaneously. If the brushes get stuck and cant make a full turn or if all of the brushes aren't spinning together then your brush block will need to be replaced. To purchase a replacement brush block simply follow the link below. Hope this was helpful!
Search Results
Sep 22, 2014 | Hoover SteamVac F5914-900 SpinScrub...
I put a new belt on my vacuum and right away it broke
There may be a problem with the brush roller itself. When the belt is removed and you have the brush in your hand, make sure that you can turn it.
If the brush turns fine, what I suggest is put another belt on, and before you close it up, turn the brush with your fingers. The brush should turn. If not, and I have done this myself before too, the belt may have been caught under the brush and not able to turn at that point.
When you get it closed up again too, before plugging it in, give the brush another turn. Just make sure that it is not pinched by the lower housing too.
Good Luck,
Mark
Nov 08, 2010 | Bissell 3576 CleanView II Bagless Upright...
Actually have model 6594. no suction. any suggestions?
If you hear the motor running and the vacuum is not sucking up debris, I would believe you have a problem with the beater brush. Problems with this brush are usually caused by 1 or 2 if not both of these problems: 1- The drive belt for the brush is broken. 2- The brush itself is frozen due to debris. Remove brush and clean all debris off. Pay special attention to end pieces of the brush that hold it in the vacuum. The brush should rotate around these two pieces. Clean ends and spray on a little WD40 and turn to work it so that the brush turns freely. If you find the brush is frozen and needs to be cleaned, probably a good idea to put a new belt on at the same time. Be sure the belt is put on correctly so the brush turns in the proper direction. Feel free to contact me if you have questions.
Sep 17, 2010 | Bissell 6596 Bagless Upright Vacuum
The brush will not rotate. I thought this was a direct drive system.
Note: The brush will not rotate when the machine is locked in the upright position, because an internal micro-switch turns the brush motor off.
- Check the belt through the clear brush cover. If this appears damaged or broken, please take your machine to a local BISSELL Authorized Service Center to have this replaced. If the belt is intact, please continue checking the following:
- Ensure both power switches are turned on when you check for brush rotation.
- Unplug the power cord and remove the handle completely. Slide handle back into the lower section of handle, ensuring the screw is in tight. If the handle is not aligned properly, this will affect the power of the brush motor.
- Look for debris wrapped around the brush (i.e. string, hair, fibers, etc.). When the machine is unplugged, cut away any visible hair, fibers or debris from the brush roller. This brush is NOT removable from the machine.
- If something has become lodged in the foot and the brush shuts off, turn off the vacuum and unplug this from the outlet. You can now remove the obstruction. The brush will automatically reset when the vacuum is plugged in and turned back on.
If you continue to experience difficulty with this, please take your machine to the following Service Center in your area. The warranty on this machine is five years.
Aug 12, 2010 | Bissell Healthy Home HEPA Bagless Upright...
Beater brush
- Make sure brush switch on the handle is on.
- Check the belt through the clear brush cover. If this appears damaged or broken, take your machine to a local BISSELL Authorized Service Center to have it replaced. If the belt is intact, please continue checking the following:
Jun 15, 2010 | Bissell Healthy Home HEPA Bagless Upright...
I have the bissell power force bagged upright vacuum and the brush is not turning, I have replaced the belt but the brush will not move but the metal piece that is hooked to the motor that spins the belt...
sounds like your brush roll is seized. Remove the brush roll (see picture) and make both of the end caps spin freely. If not, replace it and you should be set.
*An example of a brush roll*
Make sure that the brush roll spins freely.
Hope that helps.
Chris
Jun 09, 2010 | Bissell 3522 PowerForce Bagged Upright...
The brush bar on my Dyson DC17 stopped turning.
If this model has a brush control - i.e a roller at the side of the model which controls brush to spin or not, then its a protected brush model - therefore even if the drive belt is intact the Dyson would have to be repaired by a service personnel or professional. The brush protection isn't able to be taken apart and sounds like it may well have slipped off due to tension.
Mar 31, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Riccar model rad.7 upright (radiance). roller brush won't turn and red roller brush indicator is on. roller will turn easily by hand and belt is in place. how do i fix this?
As you already know, the red brush indicator light indicates that the brush roll has stopped turning, usually because an object has become stuck in the brush roll. When that happens you should turn the machine off (unplug it also for safety), remove the obstruction and turn the vac back on. That should have cleared the light and allowed your brush to turn again.
Occasionally, you will get debris in the brush roll end caps and the brush roll will spin slower making the sensor think there is an obstruction. You can remove the brush roll, pop the end caps off and clean out any debris to see if that helps.
If none of the above worked it is possible that the brush roll sensor is bad or the circuit board in the machine is bad. You'll need a Riccar service center for that. The good news is your Radiance has a 6 year warranty.
Feb 22, 2009 | Riccar 8955 Upright Vacuum
Bissell upright vac, brush on bottom does not rotate
The front brush motor will not engage until the power is turned on and the handle is in the down position. In the upright position the brush motor wont engage. Typical faults will be the belt is broken and needs replacing or the fornt brush motor needs replacing.
May 21, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
142 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
