Can you ping 192.168.1.1? Click start menu Click run Type CMD and click OK In the command prompt window type this command: ping 192.168.1.1 ...and post the response here. Also use this command: ipconfig ...and post the response here.Can you ping 192.168.1.1? Click start menu Click run Type CMD and click OK In the command prompt window type this command: ping 192.168.1.1 ...and post the response here. Also use this command: ipconfig ...and post the response here.
You can't post conmments that contain an email address.
Go into your UBUNTU netwrok settings and make sure the wireless is sending the correct Security and is set to the proper security mode. Unlike the wired connection most wireless connections are protected and require the computer that connects to send the correct key.
Hi sythonk 1. Make sure you have a telephone cable connected the jack labelled "LINE" on your brother machine. Go through the Menu on the LCD, Initial setup, dial tone, choose the correct dial tone PULSE or TONE. Exit from the menu. Pick up the handset on the fax machine, and dial your nuber to make a phone call. (To send a fax, dial the number without lifting the handset.) Hope this will work for you. If it solved your problem, give a please rating Cheers luciana44
Go to My computer -> Tools (at the top) -> Internet Options -> connections
-> Click on LAN-settings -> Disable any checks there. check it should be fixed now.
If still same, Try this: Click All Programs -> Accessories -> Command Prompt At the prompt type: ipconfig /flushdns You should get a message that says: Windows IP Configuration Successfully flushed the DNS Resolver Cache.
Connecting to the internet through your Sagem phone can only be done through your service provider because it acts as your gateway through the internet. Please check with your service provider if it supports internet connectivity.
I noticed that the router i bought is a modem router and only needed an adsl line. I cannot connect the router to my broadband connection because i already have a modem from my ISP. So, i'll have to sell the router and buy a wired router without modem for me to successfully complete the installation and configuration. Cheers!
Make sure that all the network connection settings on your new computer are the same as your old computer. Also, does it show you are connected to your network?
hdmi is the least amount of cables you'd need to run, 1 cable for audio & video for each device, assuming they have hdmi outputs on them and you have enough inputs on your tv.
Hi, it is possible that your notebook is set to a high resolution that your projector cannot handle. You may want to try to: 1) run your notebook as is (without connecting to the projector); 2) soon as windows booted up, right click on any clear area of your desktop and click on Properties; 3)Go to the Settings tab; 4) Set the Screen resolution to the lowest possible setting, towards left (less) and the Color quality to the lowest possible. Clilck Ok then reboot. Run once to see everything is OK except your icons are bigger now. Youo can try connecting your projector to see if it works. Hope this be of help to you. Cheers.
