Question about Carrier Heating & Cooling
Carrier Ceiling Casstte 40GKX Air Conditioners Group wiring (operating the units Simultaneously
  • smernat May 11, 2010
    Hi, Can you please elaborate further regarding your problem? What is it that you want to accomplish? Thanks.
5 Suggested Answers
SOURCE: Looking for auto restart on carrier 40GKX series
Can you please check if the remote handset is this?d6f691e.png if yes, follow below
• Connect the system to the electrical current.
• Press the button M and of the remote control and keep them pressed down for at least
5 seconds.
• The clock digits show the first configuration item (rAdr = remote address) and the temperature
digits show the default value of the respective configuration item (Ab = control of both indoor
units).
• Press the button M repeatedly until "ASt " appears.
• Press the buttons ∧ or ∨ to change the default value (OF) to the new value (ON).
• Press the button to send the new configuration to the unit.
• Press the button to exit the configuration menu.
To see other available configuration options, consult the table.
Item Viewfinder display Explanation Description
1 "rAdr" "A": remote unit A Remote address of indoor unit A.
"b": remote unit B Remote address of indoor unit B.
"Ab": remote units A and B Default address of the two units.
2 "UCFG" "HP": Heatpump Default address and heatpump
"AC": Cooling only Changes the cooling-only address
3 "UAdr" 1-240 with an increment of 1 Address of the CNN unit.
Default = 1.
4 "ZONE" 1-240 with an increment of 1 Zone number.
Default = 0.
5 "GFdn" 1-240 with an increment of 1 GFD number.
Default = 1.
6 "A St" "OF" : Shutdown mode Select the function mode after an
"On" : Automatic restart electrical power failure.
If no button is pressed for 30 seconds, the remote control automatically exits the
configuration menu and the entire procedure must be restarted.
NOTE
Posted on Apr 30, 2010
Sea Breeze
  • 4654 Answers
SOURCE: Identify unit capacity.
Carrier XHD183D 25" XH Series Heat/Cool Room Air Conditioner w/ 17800/17500 Cooling BTU, 230/208 Volts & 1870/1830 Cooling Watts.
The model you listed is what you have, Thanks, Sea Breeze
Posted on Jun 07, 2010
kel1guy2002
  • 3740 Answers
SOURCE: All our our Panasonic Split
The genset power most likely is 220V line to ground power. You utility power is 220V line to line but uses 2ea 110 VAC line inputs to get that 220VAC. The only way to correct this is to reconfigure your generator connection to 220V line to line IF possible. Some generators that only have a 220V output. Re-configuration is not possible
Measure power at the breaker on gen power as the source and again with the utility as the source. You will see the difference in voltages. Utility power.... each side of the Breaker output to ground = 110V across the 2 terminals 220V
Gen power one side of the breaker output = 220V other side = ZERO.
You can make it work but it would take some heavy duty relays in a power sub paenl so that when the generator is running one side of the power is 220V and the other side is Ground. Once utility power is restored the relays would disengage and power would again be 220 VAC line to line.
You will need a licensed electrician and a PERMIT to install a relay panel such as I mentioned above. Improper wiring of the power relay swtitching panel can cause major power problems in any given installation and trip the MAIN PWR breaker.
Thanks for choosing FixYa.
Kelly
Posted on Sep 05, 2010
hvac1960
  • 2133 Answers
SOURCE: do i need to install
Before you buy, you have to calculate the heat load of your room and as well as the temp to be maintained in that room. Basing on that, there so many engineers in sales counter of every branded air conditioner to recomand you the correct model.And I hope with same expansion valve you can get required temp.
Posted on Dec 26, 2010
CARRIER TRANSICOLD A/C SYSTEM
I can find no A27 fault code for this unit, what is it doing? You can call carrier and ask for the definition, I think they will give it to you, just have the specific model number in hand when you contact them.
Aug 18, 2016 | Carrier Transicold Division Heat/cool...
Plugs on Carrier yc273d air conditioner
You probably have a 230 volt AC that uses a different plug. If you insist on using unit there you will need an electrician to run the correct wiring and install the correct female for your unit to operate.
Jul 13, 2015 | Carrier Heating & Cooling
Why won't my Carrier room A/C stop cooling?
TO MEASURE THE AIR TEMPERATURE AT THE SAME HEIGHT AS YOUR WALL MOUNTED UNIT & COMPARE IT TO THE REMOTE CONTROL SETTING. THERE CAN BE A 8 DEGREE DIFFERENCE BETWEEN THE TWO. I HAVE TO TURN ON MY CEILING FAN TO CIRCULATE THE COLD AIR THAT DROPS AND THE WARM AIR THAT RISES.
GOOD LUCK
Aug 12, 2014 | Carrier Heating & Cooling
WHAT IS THE REFRIGERANT USE FOR CARRIER CEILING MOUNTED MODEL NUMBER 42XQ060 ACU?
It will be stamped or written on the data plate, of the unit.
www.carrier.com/carrier/en/us/contact-us
Jul 02, 2014 | Carrier 36KCARMS Air Conditioner
Hampton bay ceiling fan broke. How to screw it back up
It already looks like it's "screwed up". ( LOL) BEFORE BEGINNING READ ALL OF THIS FIRST< PLEASE> First turn off the breaker that supplies power to the fan. Take down the whole unit up to the ceiling mounts. It looks like the wood is broken that the screw bracket used to mount the fan is on. If it is you will need to reinforce the wood and rescrew the fan mounting bracket on it. THe ball carrier from the bracket should now be secure and ready to mount the swing ball of the fan at the top of the fan unit motor. Next rewire the fan to the wires in the ceiling with the wire nuts you removed. Tighten the ball screw and push the cover plate up to the ceiling, fastening it in place with the screws provided to the ceiling plate...Done!
Jan 01, 2013 | Heating & Cooling
Do i need to install a jet expansion valve for the Carrier Model 40GKX casette type aircon unit? I was asking because the temperature of the room is not getting the temperature i wanted.
Dec 25, 2010 | Heating & Cooling
Where is the filter on my actual unit? Have one in the ceiling is that the only one?
If someone has installed a filter return grill in the ceiling, then thats the only one you will have or need. Even if the original unit has a place for the filter, when an over head filter grill is installed, the installer will not put one in the unit as there is no need. Hope this answered your question and good luck!
Aug 19, 2010 | Carrier 38CKC036 Air Conditioner
Wiring diagram needed for carrier air con unit
Here ya go:
http://www.xpedio.carrier.com/idc/groups/public/documents/techlit/38ckc-c2w.pdf
May 27, 2010 | Carrier 38CKC036 Air Conditioner
I am installing a ceiling fan. There are 4 white wires and 4 black wires in the ceiling. Should all 4 white wires be connected to the white wire from the fan? and the same for the 4 black wires?
Generally, yes. If all 4 white wires are already connected together, that is a group of grounded wires. If all the black wires are connected together, that is a group of power wires. If you have more than 2 groups, something more is going on in that box and it is too complicated to guess which wire goes where from way over here.
Jul 20, 2008 | Heating & Cooling
Heating & Cooling Logo
189 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
