Question about Audiovox VM9212N
Wire colour explanation
Explain the colour code of the wiring harness on a vm9212n
  • 93 Answers
Please refer to this image: http://www.sbo2.net/photo2/1022/1022-05.jpg
Posted on Apr 30, 2010
How to wire a range rover power seat
There are 4 electric motors under each seat and a 5th inside the back rest. Also under each seat is a module containing the relay and memory module It is possible to run new wires but the job will be much simpler if you have (or can get) a pair of original wiring harnesses to go between the module and the harness behind the centre console (remove ashtray, lighter and storage bin) Spade terminals can be used if the module is missing. Make sure the wiring colours all match.
Of course, this is a simplified explanation. Go to Rovers.net for more detail
Jul 29, 2014 | 2002 Land Rover Range Rover
Plugging the wires fromwire harness
wires in a harness are colour coded and the connectors will be alike so find the same wire code and plug the connectors together . Remember that there may be wires in a harness with out matching wires to connect to as factory harnesses are made for extra add on items as the accessories list rises.
Apr 11, 2014 | 2005 Chevrolet Trailblazer Ext
Why we make colour code and for what purpose
wires are colour code for the purpose of being able to distinguish what wire is which at the end of the wiring loom(harness) If all the wires were the same colour then identifying where each terminal went would be impossible. IT means that if you have a main red wire with a purple stripe in the engine compartment then where ever you find that wire in the car /under dash / in the boot it is the same wire regardless of how many connections and diversions there are.
Jan 14, 2014 | Cars & Trucks
I require the wiring diagram and colour code for a Pioneer DEH2750 MP to enable me to install one
I recommend you purchase a wiring harness. All aftermarket radios have standard color coding. It's the vehicle wires that will not match. So, the wiring harness will allow you to hook the radio to it, and then plug into the harness of the vehicle, eliminating the need to check the wires. If your vehicle does not have the vehicle side of the harness, visit the websites of scosche or PAC and see if it is available. Hope this helps.
Aug 22, 2011 | Car Audio & Video
I need diagram to wire defy 600s hob and oven , can you help please
Hi Gary The hob connectors have colour coded plug ins. They are starting from right to left the red connector is for the front right plate, the white is for the back right plate, the blue is for the the back left plate and the black is for the front left plate. Now I am not sure of the config in your country but another way to look at this is that The red dot 2000 W (large plate) is connected to the black harness and the red dot 1500 W is connected to the blue harness. The std large plate 1500 W is connected to the white harness and the red harness is for the 1000W small plate. The wiring onto the actual plates should be accrording to the colour codes as follows: The harnesses are all 4 wires and are colour coded blue white ( wiring block 1) , yellow white(block 2), white ( wiring block 3) and the red white block 4. The actual plates are numbered from left to right as 1,2,4,3. But my wiring write up takes it as standard 1 to 4 so do mot worry about the numbers on the plates as some plates have no numbers. Hope this helps.
Nov 09, 2010 | Stoves 1100ESIDLa Electric Kitchen Range
Im trying to install a new stero in my car its a sony xsplode my car is toyota corolla gts what wires go to what the wireing harness that is on there now has wires connected to the wire harness that match...
Hi - unfortunatly you can forget colour coding as a means of connecting them as this rarely works. Autoleads sell adaptors to bridge for myour cars wiring look directly to the ISO connector from the Sont. Faining this a trace back or a Haynes manual will let you know what each wireof your loom is for and you sony manual shuld explain the harness
Good luck
Jul 12, 2010 | Sony Car Audio & Video
98 Ford Explorer/Puttin in NEW radio...need help
Hope this helps
Speaker wire colours
L.F. O/LG LB/W
R.F. W/LG DG/O
R.R. O/R BR/PK
L.R. GY/LB T/Y
Jul 26, 2009 | Ford Explorer Cars & Trucks
Car radio harness colour code
work it out with a meter ,,,,find perm 12v feed neg and pos ---yes could be any coloured wire depending on car maker,after finding perm 12v feed for memory look for pos from ign switch,now speaker wires are easy as both will be same colour for a speaker but one will have a band through it if not sure or colour blind like yours truelly then use pos and neg on speaker wire till you hear a thump from speaker then you know you have the right wires and location of speaker ,,ie.. front left back right ect ....Now you are a fully experianced radio fitter ??
Dec 20, 2008 | 1993 Nissan Maxima
Audiovox VM9212N Logo
104 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
