Question about Argox X-1000 Thermal Label Printer
Label skipping during printiig - Argox X-1000 Thermal Label Printer
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 240 Answers
Open printer cover and try to move the sensor to the middle of the label. If that don't help try to clean the sensors. Depending on what software you use it could be settings fault. Example- Gap size to big or to small- check settings. Please clarify what software you use with printer. Good Luck
Posted on Apr 30, 2010
My TLP 2742 skips every other label
Skipping every other label is a software template or size format issue. This means your label size in the computer is not set up to match the label size your printing or you have too much text on your label causing it to print out of the bottom margin causing it to skip to the next label.. Very common issue.
We have labels that may help alleviate your problem as well
Labeldomain com
May 01, 2014 | Zebra Eltron TLP 2742 Thermal Label...
The printer prints one label and skips another one
First, I need to admit it. This is the worst printer I have ever used. I had all kond of troubles with it.
The skipping labels problem was my misery for 2 days to. I had to find out that my labels were falling out of the printing area generating a new page (label). Go back fix your width. Make sure your label fits one page (label). Print again. That's what I did. Good luck.
Mar 27, 2014 | Zebra LP 2844 Thermal Printer
Dmx i4308 skipping every other label
emelish: If is constant the print label and skip label, you have adjust the label size in your software. If the label skip is not constant, then clean the label sensor, position it in better place and perform a quick calibration pressing and hold FEED button by 5-6 seconds and release it. Maybe you can do it once more time. Roberto Martinez
Sep 02, 2011 | Datamax DMX-I-4208 Label Printer
When we print labels, it skips one each time. We have been on the phone with Datamax three times and all systems appear normal. When we do a test of the Datamax it DOES NOT skip[ any labels but as soon...
Hello, Nancy.
It's clearly your application, since a test print appears normal and all systems appear normal. Is it possible to reinstall your application ?
Hope this helps.
Mar 06, 2011 | Datamax DMX-I-4208 Label Printer
I want to print 2X4 labels without skipping 2 labels each time
obviously its your vb software. try using a real label program and end this issue.
Sep 05, 2017 | Zebra LP 2844 Thermal Printer
Zebra stripe s500 skips 5 labels prints 1 skips 1
He are the steps you need to calibrate your printer
Label Length Calibration
Note: This is typically the only procedure required when first installing the labels.
1. Load the printer with media and ribbon.
2. Press the printer front panel MODE key until the CALIBRATE LED is lit.
3. Press the FEED key and allow the labels to feed.
4. When the labels have stopped press the MODE key once to save the value in memory.
Jul 10, 2009 | Zebra Stripe S500 Thermal Label Printer
Datamax I-4208 not printing allocated amount of labels
Eventually you HAVE to give the printer a break, during inventory times at work, we have to print 50K+ labels, and in order to prevent either serial number skipping or other issues, I print in 250 batches, yes; there is a time gap but it's better than to restart a series of prints because a few numbers were skipped. Try printing 200 and 200 sets to prevent errors or skips.
Jun 03, 2009 | Datamax I-4208 Thermal Label Printer
Mis align printout
hi, its hard to say but.... does it feed ok or skip labels??? if it skips labels, the sensor will need replacement or adjustment, also download the latest drivers, and if your driver or software gives u the option, play around with the magnification settings, also double check length, borders etc, try making the label length setting appear longer , shorter etc. Hope this is of help to you,M,
Feb 12, 2009 | Intermec EasyCoder PM4i Printer
Skipping 1 mm (regular intervals) while printing labels
1-try to recalibrate labels
2-make sure the label size is correct in the settings:
here is the link for the driver. :
http://barcode.toshibatec.co.jp/Eng/download1.html
Nov 02, 2007 | Toshiba TEC B-SX4 Thermal Label Printer
Argox X-1000 Thermal Label Printer Logo
308 people viewed this question
Top Argox Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
sahoo_sanjay
bvmihai
Are you an Argox Office Equipment and Supply Expert? Answer questions, earn points and help others
