Question about Refrigerators
It does not produce ice, but delivers water. Mod.GI5FSAXVY01
It does not produce ice, but delivers water. Mod. GI5FSAXVY01 Whirpool Gold
TheMobilian
  • 8220 Answers
SOURCE: whirlpool gold moder GC5SHEXN503 side by side-ice
Put some water in the ice maker and see if it will kick a batch out. If it does make a batch but does not make any more then replace the water valve. NOTE: the water valve is a dual purpose valve that supplys water in the door and supplys the ice maker. If the ice maker does not kick out a batch then something is wrong with the ice maker.One easy component to replace is the ice mold thermostat.
Posted on Feb 20, 2009
peyton32034
  • 410 Answers
SOURCE: I have a whirlpool gold
you p robably have a frozen fill tube for the icemaker. coming inot the rear is a tube for dispensing water into the icemaker. check this for ice if it is frozen you can thaw it out by using a blow dryer to melt theice out. on some models this tube comes thru the back wall of the freezer for cross the freezer icemakers there is a black tube that comes out of the ceiling. if you have any questions please post here and I'll get back to ya thanks Peyton
Posted on Mar 06, 2009
rylee_smith
  • 8619 Answers
SOURCE: ice maker stopped
Hi!
Please check these:
It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
If your ice maker has a small red plastic lever, lower it to lower the wire.
If there's no plastic lever, simply lower the wire.
In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 23, 2009
aasc
  • 1606 Answers
SOURCE: Ice maker not producing any ice.
Pour about 1/2 cup of water into icemaker . Squeeze the black fill tub which is above the icemaker cup . If ice apears to be in it , this indicates that the weter valve is not completely closing , letting a drip ocasionally go thru and freezing inside the tube , ( water valve bad ) . that will be a different solution . If the icemaker dumps the cubes after freezing . and black tube is not frozen , replace the water inlet valve . If the icemaker does not dump the ice after frozen , replace the icemaker ( only 1 screw holds the icemaker in , located on rear portion on right , faceing down . Also check the icemaker rake , which should be about the 2:30 position . To thaw out the black tube (which runs thru the top of the refrig ) a 1/4 push on connector will be needed . Remove the icemaker and use a hairdryer aimed up into the hole . Cut the tubing to the fill tub behind the fridge about 9 inches from where it enters the top of the fridge . This will let warm air inside the top fill line to help thaw . Ocassionally blow thru the 9 inch tube until you can blow thru it . May take a day or 2 , depending how frozen the line is . Once air will go thru , install the push on connector to couple the cut lines back togather .
The blinking red light on the right side , is the receiver for the electric eye for cutting off the icemaker when the door bin is full , This blinking is normal . 2 blinks ...pause...2 blinks..etc .
Do not replace the filter if water flow is good thru the dispensor .
Posted on Aug 16, 2009
aasc
  • 1606 Answers
SOURCE: ice maker not working
Pour about 2/3 cup of water into the ice maker . Also , check the black fill hose that fill the ice maker , to make sure it is not frozen . If the ice maker dumps the cubes , then replace the water inlet valve . If the ice maker holds the ice , and does not dump , replace the ice maker . When you open the freezer door , the laser light , should blink twice , then pause ,repeatedly . If you close the flap on the left side , the laser should go off . These are indication that the optics are good . If you open the door , and no laser light , then that means that the ice maker is in the harvest (dump) mode . If it stays this way , ice maker is bad .
Posted on Sep 12, 2009
Water pooling and freezing in lower freezer, whirpool gold french door? How do I rmove liner in fridge to follow line?
Sounds like a clogged drain. Remove food, remove bins and shelves. Remove ice maker if freezer is in the bottom. Remove back panel. .melt ice on drain pan and run hot water into drain.
Feb 14, 2015 | Whirpool Refrigerators
My Whirpool Ice Maker Model GI15NDXTS won't stop making ice
check bin thermistor connection or replace it is inside the bin on the right side
Aug 04, 2012 | Whirlpool Gold Series GI15NDXT 15"...
How do I get the Ice machine to work. I have a Whirpool gold refrigerator
is the water line hooked up to the house water line ?
move the ice full sensor wire to the down position.
Sep 25, 2009 | Whirlpool Refrigerators
Ice maker stopped
Hi!
Please check these:
Thanks
Rylee
May 23, 2009 | Whirlpool Gold Series GI15NDXT 15"...
I have a whirpool refrigarator with the typical ice maker. The ice make doesn't work, it sounds like it's filing up with water but it doesn't produce ice. This the 2nd time I've had this problem. The 1st...
Hi!!! In order to make ice the freezer needs to be at 5-10 degree if not then you will not produce ice.The thermostat inside the icemaker will not start.If you see the water coming in and no ice then you have to invest in another icemaker.I hate them.Good luck..
Jan 19, 2009 | Refrigerators
Ice maker Stopped producing ice
What is sounds like is somehow either the water delievery system is clogged or frozen. If your getting water out of the door, then it is probably frozen. If you are able to turn off the freezer for a bit, that would be an easy way to see if that is the problem without having to deal with Whirlpool or a handyman.
Oct 14, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
262 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
