Question about Samsung WF448AAP Front Load Washer
Just moved my Samsung WF448AAP, hooked it up and it will not fill with water, Hot and cold water valves going into machine are on. Screens are clean and hoses are not kinked, and secured tightly. Water will not flow into machine.
  • 8 Answers
You might have anti flood hoses that are braided going to the machine . remove them and make sure your water supply is coming through the water hoses.
Posted on May 06, 2010
Why does my washing machine take so long to fill?
Check to see if the screens are clogged on your water inlet valves. Just turn your water off at the Hot and Cold faucets, then remove the water hoses from the back of the wash machine.
The section that the hoses were attached to on the back of the wash machine is the water inlet valve (or valves). Take a flashlight and inspect for blockages on the screens (they're located right in the valve inlets).
If you see grit or calcium build up, you can usually pull the tiny plastic screens out with a pair of pliers and clean them out under running water. Then, put them back in and hook everything back up. Turn on your Hot and Cold faucets and see if your washing machine fills faster.
It should work, but if not, you'll need to replace the water inlet valve (or valves, depending on your model)
Oct 15, 2014 | Frigidaire Washing Machines
Error code of NF (no fill) on samsung top load washer (WA422PRHDWR/AA) even after checking lines for restrictions and ensuring clean line filters (red and blue). Now, when it does work, it will only do a...
Put the temp select switch on HOT, start machine. If water comes out check the flow amount. If no water flow, replace inlet water valve. If there is water flow switch to COLD, start machine. If water comes out check the flow amount should be approximately equal or slightly more than flow on HOT. If no water flow, replace inlet water valve. Move selector to WARM, start machine. Now there should be twice the flow of water than there was with HOT and COLD temps. I suspect it is the HOT side of inlet water valve that has failed because machines usually rinse with COLD water.
Jan 20, 2013 | Samsung WA422PRHDWR 4.2 Cu. Ft. VRT Top...
Water inlet valve is broken. When the hot water is turn to fill it trickles in. Pressure from fill hose is there.
before you replace the valve you should remove the hot and cold water hoses and check and clean the screens on the inlet valves and if there are screens on the hoses check and clean those also. i suspect the screens are dirty and plugged. if they are not, then remove the water valve and replace it.
Apr 23, 2011 | Washing Machines
Hoover 700l Cold water is not fillingproperly. Only a verey small dribble comes into the machine. I have reversed the hot and cold hoses, making sure that the setting is on "hot". Problem...
Clogged screen in fill valve on cold side. Remove hose from cold side on valve. Pull screen out. Wash under hot water, and re-install.
Jan 23, 2011 | Washing Machines
My Brada washing maching keeps displaying "NF" in the middle of every load..what does this mean and how do i fix it??
NF means "No Fill".
I was getting that code too, but we only had the cold water hooked up. I hooked up the hot water and I have not received the error since. I still only wash with cold, which is strange.
Aug 10, 2010 | Washing Machines
MAchine fills slowly. Have cleaned the screens.
Check the solenoid. You can swap the hot and cold water hoses and set the wash for hot but cold will come out. Then you can see if the flow is better. If it is the cold valve isn't opening all the way.
Mar 11, 2010 | Washing Machines
Washer Fills HOT WATER ONLY
If you checked the screens at the water inlet valve and they were not clogged, then you probably have a defective water inlet valve and will have to replace it. Hope this helped.
Jul 19, 2009 | GE WJSR2070B Top Load Washer
My maytag neptune washer stop washing with 10 minutes left to go.
If your machine is a FAV6800AWW or FAV9800AWW the (upside down u and f) may be a “NF” for no fill error. The washer has tried to fill the machine with water and has sensed a water fill issue. The control board has shut the wash cycle down with an “NF” error to the display because of excess time to complete the water fill portion of the wash cycle.
Will the machine complete the cycle with Hot water only or Cold water only? I would do a Quick Wash cycle just to test with an empty wash basket.
Regardless of the above test and assuming you have good water pressure for both Hot and Cold supplies to the washer I would do the following. Close the water source valves to the washer and remove the Hot and Cold hose connections at the back of the machine and check for clogged inlet screens. If the water inlet screens are free of restrictions I would go into Service Mode and turn on the Hot and Cold water valves on one at a time and make sure the tub will fill with about 2 inches of water in about 3 minutes in service mode. Check both Hot and Cold inlet valves individually see page 16 of the SM Board Output Test, enter service mode and do the function test for both Hot and Cold Water Valve’s. If the inlet screens are clean and you have water fill restrictions in service mode we may need to look at replacing the water inlet valve assembly. You can turn on the drain pump in service mode to empty the tub or just start a wash cycle and the machine will empty the tub.
The Service Manual for reference. Sears Parts Direct for reference.
May 11, 2009 | Maytag Neptune FAV6800AW Top Load Washer
HOT WATER NOT COMING INTO MACHINE
lets see hear.what the water fill hoses are connected to is call the water fill valve.when you select a water temp.,electricty will then go to ither water valve coil or both for warm.so if your not getting hot it could be first that the fill screens at the hose at the water valve is blocked .but most of the time thats not true of hot because minerals drop out in the water heater before getting to the water valve,unlike the cold water.so if screen is clean,next would be voltage to the water valve.if its getting voltage but not working then its the water valve.if its not getting voltage then use the wiring diagram to see what componet is before the water valve.may be water selector switch or timer
Jan 03, 2009 | Maytag HAV3460AWW Top Load Washer
Just want to know how to get the fasted wash as it seems to take about 1.5 hrs to do a load. zanussi xc6 1400
Check your screens on the fill valves. This is a good time to replace the fill hoses, the last thing you need is an old one to blow. Wash warm, rinse warm, both fill valves will be open. If you only use cold water, hook both fill valves to cold water, cold water will go thru the hot fill valve for a faster fill.
Aug 18, 2008 | Washing Machines
Samsung WF448AAP Front Load Washer Logo
248 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
