Question about Microsoft Windows Vista Home Premium Edition for PC
I have put the correct ID but I still can't retrieve the message. ID Number 254722882444
Can i get my lost mxit through my facebook
Greetings,
If you forget your PIN and need to request a new one, you need to ensure that your Mxit Profile is updated with your mobile number.
We will not send your PIN to you if your correct mobile number is not in your Mxit profile.
To update your Mxit profile with the correct mobile number please go to:
INFO> My Profile>Mobile.
There are currently 2 ways of retrieving your PIN.
1.Sending an SMS containing PIN and your Mxit ID to 34006
If however you have registered with a Mxit ID, you can retrieve the PIN by sending an SMS with the word PIN and your Mxit ID.
For example, the user mrgreen requests his PIN he will have to send the SMS containing only the following :
PIN mrgreen
If your Mxit ID is your phone number, please ensure that you enter it in international format.
Here is an example of what this SMS should look like:
Pin 27821234567
This still has to be done from the SIM that was used to register the Mxit profile.
Please note:
* This only works with cell numbers that are in South Africa.
* Please make sure that you send the SMS from the same cell phone number that you are registered to Mxit with. This is one of the reasons why you must have the SIM card for the Mxit profile that you are using.
* This SMS costs R2.00
2.Retrieving your PIN through email
If you have added an email address when registering, you can simply go to http://password.Mxit.com and fill in the details.
Your PIN will then be sent to the registered email address which you have entered enter.
Keep in mind that the email address must have been registered on your Mxit profile before the PIN was lost.
Please do not make the mistake of using your Mxit email address to retrieve your PIN.
If you do not have your PIN you cannot access your Mxit account, if you cannot login you will not be able to receive your mail.
Apr 06, 2014 | Cell Phones
Cannot retrieve messages
shut it down and open it again.it will work
Dec 08, 2013 | Uniden DECT 6.0 Cordless Phone ID
Password isn't working and either is id someone got into the system dedenurseblondie@yahoo.com is the only email address i have
Either
1) Yahoo is updating
2) Someone got your pass
3) Your putting in the wrong pass
If it is 1 it will be over soon, If it is 2, well, good luck getting your account back.
Sep 28, 2010 | Yahoo Messenger
How to have an account in chika.,!
Dear please read this information and make a account.
When you sign-in to Chikka using your mobile phone number and password (retrieved by sending an SMS to the operator-supplied shortcode) you enjoy the full benefits of a Unified Account. This makes the Chikka Messenger and your mobile phone virtual extensions of each other. When you are offline, you have the option of having your messages forwarded to your mobile phone. The Chikka ID, in this case your phone number, is permanent. To register for a Unified Account, you are required to provide your mobile number to be able to successfully register your account. Registering from your mobile phone will cost you regular value-added service rates.
A PC-only Account allows you to register for a Chikka ID even without a mobile phone. Like any Chikka user, you will be able to receive and send messages to mobile phone users from your PC. For PC-only Account holders, your Chikka ID is a combination of digits that begin with 00 (except for India PC-Only Accounts where the Chikka ID begins with 01). Your Chikka ID is the Chikka ID number you are automatically assigned to by the Chikka system, unless you specify an ID number you prefer upon registration. Click on the link above if you want to register for a PC Only Account. Registering for your Chikka account using your PC is absolutely free!
Thanks.
May 07, 2010 | Yahoo Messenger
Retreiving deleted phone messages
I am sorry. Your answering machine has about 14 minutes recording time. Space is limited. After you delete a message to make room and new messages are recorded, so old messages are pretty much shredded and un-retrievable.
But even if the message memory has not been totally rewritten, I believe deleted message are lost for ever. That is what I read on the manual for a GE or Panasonic phone user manual.
I hope I am wrong.
Jan 25, 2010 | Uniden DECT 6.0 Cordless Phone ID
I can't retrieve my old id on yahoo messenger and i'm not going to put my viza number on here if i can't get the answers i'm looking for
if you are not using your mail regularly, then you are going to loss your id with out error! check when did you open previously or check with your sercurity Q & A settings to retrieve password to access your id! have fine
Dec 17, 2009 | Yahoo Messenger
I can't put in or retrieve a message on individual Toshiba DKT2020SD - old security code doesn't work. How can I change or put in a new security code?
Dial into voicemail extension and when message starts press * it will then ask for user ID and password which is 999 and password is 999997 by default. Go to option 8 then option 4 to reset password to default. By default all passwords are the extension number plus 997. Hope this helps.
Jun 12, 2009 | Toshiba DKT-2020 Corded Phone
Retrieve Messages when away from home
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}table.MsoTableGrid {mso-style-name:"Table Grid"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; border:solid windowtext 1.0pt; mso-border-alt:solid windowtext .5pt; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-border-insideh:.5pt solid windowtext; mso-border-insidev:.5pt solid windowtext; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Instructions for Retrieving Messages While Away from Home
Sony TAM-100 Answering Machine
Step I: Set the Remote ID (security code) on themachine itself:
1 Press (SET/REC).
2 Press (ANSWER ON/OFF).
A voice guide will say: “Pleaseset the security code. To select, pressthe SKIP or REPEAT button. To enter,press the SET button”.
3 Set a two-digit number between 00 and 99 bypressing (SKIP/QUICK) or (REPEAT/SLOW). Press (SKIP/QUICK) to increase a number, or (REPEAT/SLOW) to decrease.
Each time you press (SKIP/QUICK)or (REPEAT/SLOW), the answering machine announces a number.
4 Press (SET/REC). The remote ID code (security code) is set,and you hear a long confirmation beep.
To change the remote ID code(security code), Enter a new remote ID code (security code). The new code will replace the old one.
Note: If a powerinterruption occurs, the remote ID code will not be erased.
Please See Next Post to Continue (my response exceedsallowable text restriction ;-) ).
Oct 24, 2008 | Sony TAM-100 Digital Answering Machine
Fax Numbers-Memory?
Unfortunately that is a function of the sending unit. If they did not program their number in, then you won't have a record. If this is a persistent problem, you may want to sign up for Caller ID. Even if they put the paper in upside down, your fax will still print a head on top of the page with the information they have programmed. If they program a wrong fax number, then all you will have is a wrong number. Wish I have better new for you. Ed
Jun 13, 2007 | Muratec M1250 Fax
Microsoft Windows Vista Home Premium Edition for PC Logo
12 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
