Question about Kensington Expert Mouse Trackball
The tiny red ball bearing got lost, what could be used as a replacement?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 108 Answers
Kensington took its time bringing an optical version of its venerable Turbo Mouse to market. The Turbo Mouse was the original multi-button ADB trackball, introduced back in the late 1980s with two buttons and evolving through the late 1990s into a four-button, do-everything wunderkind of a mouse. Unfortunately, Kensington didn’t rush to produce a USB version once the iMac hit the market, leaving users stuck with the imperfect solution of a USB-ADB converter or—heaven forbid—even worse, the stock iMac mouse. Finally, when it got a USB version to market, the rest of the market had moved on to the optical mouse, and Kensington’s renamed Expert Mouse was behind the times again.
No longer.
the tiny red ball bearing got lost,  what could be - expert-mouse.gif The latest revision of the Expert Mouse, version 7.0, has been out for about a year, and it fully lives up to its billing as the “ultimate trackball.” With USB connectivity, optical tracking, four programmable buttons, a brilliantly conceived “Scroll Ring,” an included wrist rest, and a billiard-size trackball, this mouse is the whole package.
Let’s get one thing out of the way: the Expert Mouse is the epitome of all things trackball. It’s the latest offspring of the original trackball mouse. If you’re a trackball-hater, approach this review with an open mind. Don’t hate the player. Hate the game—and Kensington’s game is not to be hated lightly.
A good mouse starts off with one of two things: either it’s dead simple or it has great software. Apple has always taken the dead-simple route. Kensington takes the opposite tack, with incredible software that makes an otherwise complex mouse quite easy to use.
Software has traditionally been a Kensington strong point, and the latest version of MouseWorks for Mac OS X is no exception. The only drawback is that third-party mouse support has disappeared. (A little-known secret on the Classic Mac OS was the fact that Kensington’s ADB MouseWorks software was amazingly supportive of non-Kensington devices, sort of like an ADB version of USB Overdrive.) It’s hard to find fault with Kensington for failing to re-implement this feature when it rewrote the software from scratch for Mac OS X.
expert-app-settings.gif MouseWorks will be immediately familiar to anyone who has used the Classic version, except it’s now implemented as a preference pane rather than a control panel application. Separate tabs are provided for button assignments, scrolling control, click speed, and—best of all—acceleration, which allows for a fantastic degree of fine tuning. There is excellent help and documentation, which are thankfully no longer the rarity they once were. Buttons can be assigned on a per-application basis, giving the user limitless possibilities for individual behavior in each application. This comes in especially handy for media pros, though almost every power user can, in tithe tiny red ball bearing got lost, what could be - expert-acceleration.gif.
expert-acceleration.gif As with all good software, the default settings are sensible, too, though most folks will probably find the default scrolling speed and cursor tracking a bit too slow. Unlike Classic versions of MouseWorks, the new version bases these values on their corresponding global system preferences, so if you find yourself wanting to turn it up to eleven, make sure you’ve adjusted the settings in the Keyboard & Mouse preference pane first. Conversely, if you find it turned up to eleven and a mere tap of the mouse sends the cursor all the way across your screen, make sure the Keyboard & Mouse settings aren’t too high.
There seems to be one minor bug with the software under Mac OS X 10.3: plugging or unplugging the mouse seems to activate the screensaver within about 20 seconds. There doesn’t appear to be any rhyme or reason to this behavior, but it’s fairly reliable and happens almost every time.
Let’s move on to the mouse itself. The great benefit of this long line of trackballs has always been the size of the ball, which allows for much better cursor control than, say, the built-in trackballs on 100-series PowerBooks or the thumb-balls used on Logitech and Microsoft’s widely tolerated optical trackballs. If you’re soured on trackballs because of bad experiences with another model, rest assured this is one arthe tiny red ball bearing got lost, what could be - expert-mouse-hand.giftter, and the Expert Mouse could well change your opinion.
expert-mouse-hand.gif The included wrist rest is a nice touch. Though wrist-rest mousepads are a dime a dozen now, the pleather-covered dense foam makes for a comfortable and stable support. Just don’t plan on taking it off. It snaps into its two mounting holes very tightly, and it’s pretty tricky to remove. The leading edge sticks up a little higher than it should, which is mildly uncomfortable. Moving your hand up on the mouse a bit helps, but doesn’t entirely avoid the problem. Of course, if you already have a wrist-rest mousepad, this should be a non-issue.
Kensington sensibly attaches a six-foot cord, putting the Expert Mouse within reach of even the worst hide-the-tower-under-the-desk setups. This cord is no longer detachable, as the ADB cable on the Turbo Mouse was, nor is there a USB pass-through on the Expert Mouse, though there’s admittedly less reason for one with the proliferation of USB hubs on the desktop. Though not tested for this review, a wireless version of the Expert Mouse (using proprietary RF, not Bluetooth, unfortunately—maybe in version 8.0?) is available for an additional $20, if you’re the type who hates any cord clutter and loves to use batteries.
Tracking is accurate and generally smooth, although not as precise as I remember the Turbo Mouse being under Mac OS 9 on my Wall Street, especially at slow tracking speeds. Fortunately, with the optical pickups, you’ll never have to worry about the ball sticking or the horrible thunking sounds the ball bearings in the old Turbo Mouse could make when dirt and dust got into the mechanism. Trust me, with heavy use, this happened more often than you might think, and the Turbo Mouse required fairly frequent cleaning. Ithe tiny red ball bearing got lost, what could be - expert-scrolling.gif disadvantages of a trackball, with its upward-facing mechanism that collects whatever gravity drops on the ball.
expert-scrolling.gif Scrolling with the ring is very comfortable and feels quite natural, since my ring finger and thumb rest on or near the scroll ring anyway. It is not, however, as smooth as the tracking is. In fact, it’s noticeably jumpy at times. The scroll ring has very shallow detents that seem to exacerbate this problem, much like the soft clicking you feel on most scroll-wheel mice. At least some of the blame can be laid at the feet of application developers, though. Scrolling is noticeably smoother in Safari than in either Camino or Eudora.
Finally, those four glorious, programmable buttons are all within easy reach for maximum clickability. Even reaching over the massive trackball to chord is no problem, as your hand settles into a natural spread over the top of the mouse.
When I dropped $120 on a Turbo Mouse back in 1999, I did so sight unseen and without having tried it. Call it instinct. With the $20 price drop and superior features, the Expert Mouse is an even better value than its grandfather was, because the experience is markedly improved. While a lot of people might say $100 is too much for a mouse, a lot of people haven’t given the Expert Mouse a fair shake.
Kensington is one of the very few computer or peripheral makers to offer a fully transferable five-year warranty on anything, and their technical support has been highly praised in the rare case that it’s necessary. Do whatever you can to experience this mouse, and then try to argue it isn’t the best trackball—and maybe the best mouse—ever made. Well done, Kensington. Well done indeed.
Posted on Apr 30, 2010
    Problem Solver:
  • 9 Answers
Usually if you buy a different mouse it will still work. Hook your new mouse up to the computer and you won't have to worry about the red ball in your mouse.
Posted on May 04, 2010
Belt on my dewalt dw680 planer slips and starts smoking
If the ball bearing of the armature was getting too hot by working with too hard woods may be the bearing of the armature can melting loss the drive belt have lost a little tension by it the housing and a bearing has to replaced in that case.
Feb 10, 2016 | Dewalt DW680K 3-1/4" Planer
2000 mazda mpv passenger side ball bearing location
The following items on your Mazda have ball bearings, and are on the passenger side.
1) Wheel bearings, front and rear.
2) CV joints, inner and outer.
3) Alternator, front and rear.
4) Power steering pump.
5) Water pump.
6) Idler pulley and/or tensioner pulley.
7) A.C. Compressor.
8) a few I may have missed.
Oct 29, 2015 | 2000 Mazda MPV
Lost ball bearing unit out of bebe drawer do not want to buy wholt new glides
shops that sell bearings and seals carry a range of single balls for bearing applications check them out.. Take a sample ball in or have the size with you.
Apr 01, 2013 | Bebe Furniture 5 Drawer Flip Top Antique...
What do I replace the little red bead with?
I superglued a bead close to the exact same size in it's place and it worked for me. The bead must be round and smooth (w/o any glue residue or hole on exposed surface that the ball touches on) else the movements are a bit jerky and it's hard to control. Hardest part is finding that bead size. Perhaps a bead store?
May 19, 2012 | Kensington Expert Mouse Trackball
Can 40w oil be used in the 2000 accent
Well, yes and no, It would depend on the outside temperature, If you live in the desert, it would be perfect. But if you live up north, not so perfect. It would never crank over on a cold morning. Oil is like little tiny ball bearings, the heavier the oil, the bigger the ball bearings, Multi viscosity covers 2 weights, when it is cold in the morning it is thin, 10 w, when it heats up after running, it gets thick, 40w. 10w40 would be a good weight for a small engine, heavy enough when hot, thin enough when cold. Some people use straight 30 weight year round, but it is hot down here in Florida, I use 10w40 in all my cars and trucks. Hope this helps.
Oct 05, 2010 | 2000 Hyundai Accent
I discovered tiny ball bearings in my hot tub. Where could they come from? The hot tub is working fine.
The ball bearings from your spa are from a roto head jet. Typically they are from one of the larger sized jets and they make the swivel action in the roto swirl jets function smoothly. You can determine which jet is coming apart by the loose function of the center nozzle. The jet can be removed and replaced to solve this problem. Most jets screw out but when they have deteriorated a lot, you may need plyers to take the jet out in pieces.
Jan 03, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
My trackball is okay with large, sweeping
Background:
I have a total of six Logitech trackballs; four of the newer Trackman Wheel model, and two of the older Trackman Marble+ model (as pictured). All but one of them suffer from the problem described by dave48. The fifth, for some mysterious reason, never has this problem.
Solution:
The solution I came up with is to light a candle and let melted wax drip onto the red thumb ball. A single drip falling on three random places on the ball usually does the trick. (The wax should dry as soon as it contacts the ball.) I then start moving the ball around to work the wax onto the teflon points. The movement will be VERY rough initially, but will gradually smooth out the more you use it. Sometimes the initial three drips aren't enough and the ball starts getting rough again, so I will melt three more drips of wax onto the ball and work them in as well.
Conclusion:
This really seems to do the trick and for some reason the points don't seem to need cleaning as often either. You do have to be careful not to remove the wax when performing a cleaning, however. But if you do happen to remove some wax all you need to do is melt some additional wax onto the ball and work it in like before.
Jun 19, 2009 | Logitech Trackman Marble Trackball
DRUM BEARING REPLACEMENT KIT Frigidaire GLER341AS2 Dryer
Hi. I don't work on many Frigidaire's, but that pesky ball bearing does not go into any of those grooves. It goes in the very back center of the cradle, sandwiched between the ball and a metal strip on the back side of the cradle. (It is suppose to drain off static electricity from the drum. If it gets lost, it's not a major loss) As for lube, just put a gob of the stuff that comes with the kit in the bottom of the cradle before reinstalling drum.
Feb 22, 2009 | Frigidaire GLER341A Electric Dryer
Kensington Expert Mouse Trackball Logo
724 people viewed this question
Top Kensington Computers & Internet Experts
dctocali
Level 1 Expert
Alun Cox
Are you a Kensington Computer and Internet Expert? Answer questions, earn points and help others
