Question about Refrigerators
Freezer and fridge is not cooling. I can hear and feel the freezer and compressor fans. I sometimes hear a click and the light dims when it clicks in the back, the compressor is very warm and does not feel like it is running.
    President:
  • 1,554 Answers
The compressor motor is either stuck or shorted as indicated by the dimming if the light. It draws most of the current causing the light to dim and heat up the windings which will eventually burn out. The compressor is not serviceable nor repairable and needs to be replaced to make the refrigerator work again which is most of the time a non-economical fix to do depending on the make and model of the refrigerator. Please specify the make and model for the exact replacement parts if you decide to replace the compressor and need further advice.
Posted on Apr 30, 2010
How can you tell if the fan needs to be replaced?
Hi McRobbie
The devil in the details here is where the clicking is coming from, and which fan we're talking about. There can be fans circulating air in the freezer or fridge, or blowing a certain amount of freezer air into the fridge (the latter is more or less how the fridge side is usually cooled). There is also a fan that will blow on the compressor to keep it from overheating. What you may need to do is, with the fridge away from the wall and plugged in, come near to the compressor (a black metal object that looks like this
image refrigerator compressor Google Search The clicking can be the system trying to start the compressor. There is usually a bit of gear tied into the compressor that lets it build some juice in a capacitor for the startup to get moving. If the compressor isn't actually starting, then likely as not the fan won't start either, making it a symptom rather than a problem.
Is the fridge cooling now? If so, then the compressor is able to start. If not, the clicking is probably failed compressor starts. Otherwise, there will be the fan right next to it (see about halfway down the page here
Appliance411 FAQ Frost Free Refrigerator Not Cooling Properly
The latter page has a good checklist of other diagnostic possibilities.
hope this helps!
D
Dec 04, 2015 | Refrigerators
Fridge and freezer stopped cooling...light stays on, cleaned coils, drain not clogged...fan is working...hear a click about every 3 minutes, light goes dim for about 10 seconds...another click, lights back...
the click is the compressor trying to start . i would replace the relay and compresser over load . . they do go bad and this is what happens . .. mm hope this helps .. feed back pls ..
Jul 10, 2011 | Kenmore Refrigerators
FRIDGE AND FREEZER DO NOT COOL. FAN AND COMPRESSOR ARE RUNNING AND AIR IS FLOWING THREW THE VENTS BUT A WIERD NOISE APPEARS EVERY 2-3 MINUTES LIKE THE COMPRESSOR WANTS TO START BUT IS RUNNING STILL. ...
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
also are the coils clean?
Feb 26, 2011 | Maytag MBB1956GES Bottom Freezer...
Left the fridge door slightly open last night and fridge turned off. How do I turn it back on? Freezer is fine
4. Wait one hour.
let me know if this works.
Feb 22, 2011 | Sub-Zero 650 / O Bottom Freezer...
Fridge and freezer not cooling. Hot air coming from front of fridge.( Overly Hot and has a smell of burning )
4. Wait one hour.
please rate my answer.
Feb 21, 2011 | Amana Refrigerators
My freezer is not working properly with clicking sound.
The clicking sound is probably the compressor relay trying to start the compressor. When the lights dim, the compressor is trying to start and hence, pulling power from the rest of the unit. If the compressor has a start capacitor, that could possibly be the problem. If not, the compressor itself should be replaced.
Mar 26, 2010 | Maytag MSD2454G Side by Side Refrigerator
Refrigerator and freezer not cooling
Hi, If the lights are dimming, the compressor is drawing to many amps when trying to start. If the refrigerator is under 5 years old, I would check into the warranty. If it is over 5 years, You will be better off to get a new refrigerator.
I hope this gives you an idea on what is happening.
Vic
Jun 27, 2009 | Whirlpool 25.2 cu. ft. Side-by-Side...
Problems with Whirlpool 21.0 cu. ft.
checklist: freezer fan running, compressor fan running, compressor running, any frost buildup on back wall of freezer. you may have to take a rag and touch the compressor to feel if its vibrating to see if its running unless you can hear it. please reply
Jun 12, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
