Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Water dripping from freezer section, into front dispencing area
Water leaking
  • KitchenAid Master
  • 43,501 Answers
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Apr 30, 2010
My refrigerator has water leaking from the freezer into the main refrigerator compartment. How can I stop that?
Ok, you have too sources of water in the freezer section. one from the ice maker if you have one, other is defrost. Either one can cause this, check the drain under the evaporator, most likely the drain is obstructed and the water has no where to exit so it builds up and drains into the lower section (gravity). Te drain can be found under the evaperator behind the false wall in the freezer section. Good Luck
Jan 15, 2015 | Whirlpool Refrigerators
Water dribbling out of dispencer whirlpool american fridgefreezer
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
May 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water leaking into refrigerator section from freezer
The drain trough is clogged under the coils behind the freezer wall and also there should be a "p" trap on the back that is connected to the drain tube running to the bottom. Remove trap by turning and pulling being careful not to break the neck. You should be able to blow any debris out. Good luck. Blow don't ****. lol
Feb 13, 2010 | GE Refrigerators
Water is leaking from inside the freezer side of
water drianage is normal, it is supposed to drip from the freezer area to a drip pan under the unit and evaporate before it gets full. check to make sure that the drip pan is properly located and exsits and that you do not have an obstruction hindering the drain opening
Aug 22, 2009 | Hotpoint Refrigerators
Water leaks from the freezer area to the fridge
Check your drip pan and the nozzle of the line and see if it is dry. If it is dry you got a clog like I did.
I solved my own is the line from freezer to the drip pan was clogged with ice. Just remove the two back screws in the freezer section and melt the ice using hot water from the tap and maybe use a light pump could be a small foot pump nothing to powerful to put in the hole and pump until you see the water come through.
Aug 04, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Do I need to empty the water from my drip pan
the pan is there to catch condensation from the compressor during the refridgeration cycle. the water build up to me indicates one of two things. Either the refrigerant level is low and it is freezing up then thawing, or if you have ice or water dispencer it could have a leak in the line. the only thing other than that is a leak in the magnetic door seal or other insulation causing condensation. hope this helps
Jun 07, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Our GE TFX22PPDA started oozing a sticky brown substance from the bottom left corner of the freezer door. We defrosted the freezer and cleaned out the drain. Next we checked the drip pan under the frig,...
I have a GE refridg. and a light, brown sticky liquid periodically drips from the water dispencer panel area. This started after we lost power for 5 days. What to do??
Apr 19, 2009 | GE Refrigerators
Dripping water dispencer
Dripping problem is from 2 sources.  Faulty water valve or faulty water connector behind refrigerator.  If the dripping is constant and doesn't seem to end, then it's a faulty water valve.  If the dripping stops after awhile, then the water connector is allowing air into the water line causing the dripping.  Have that connection checked to make sure that it's securely in place.
Nov 12, 2007 | LG LFD22860 Stainless Steel Bottom Freezer...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
215 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
