Question about Haier Refrigerators
Haier compact refrigerator model HMSE03WAWW the refrigerator is plugged in and everything seems to be working fine but refrigerator is not getting cold at all it's just seems like its not working
Did you make sure you turned on the thermostat?
Posted on Sep 30, 2008
  • Marcile Lindsey Sep 21, 2013
    yes thermostat is turned on
My mini fridge stopped working while I was at work
RF-6850-16 Start Relay
Is the compressor again getting hot once you turn the temperature down? Will the refrigerator cool if you turn the temperature to as cold as it can get? Reason I ask is I am trying to decide if it is the thermostat or a defective staryt relay. Even at the cost of parts I would be careful and sure of what you are going to do here. Haier is not well know for quality products or customer support and there are other brands names out there that will support customers much better than Haier. Not trying to say bad things about your refrigerator I just hate to see when people invest into something and then get left holding something that Haier will not help with and does to all of their customer. Thanks Sea Breeze
I have lost valuable customers because of Haiers lack of customer support.
May 29, 2013 | Haier HMSE03WAWW (33 cu ft) Compact...
I have a haier model # htq18jabww-01 and the freezer seems to b working fine but the fridge does not seem to be cold at all...any soultions??
The "Cold-to-Coldest" adjuster in the freezer steals chilled air from the refrigerator to add more to the freezer. It's a mechanical damper. Set it fully CCW to cold (warmest position). I also put duck tape over half the chilled air outlets in the freezer to increase the chilled air pressure feeding the refrigerator section. Set the thermostat in the refrigerator to 8 or 9 and the freezer works fine and everything in the refrigerator is 38F.
Apr 18, 2012 | Haier HTQ21JABWW Top Freezer Refrigerator
My Haier compact refrigerator, Model # AES27, stopped running. I unplugged it and then plugged it back in and only hear a humming sound for like 10 seconds and then nothing.
These are noted for bad controller boards. It is located under the back cover. Look under the cover and see if the control circuit board is blackened or smells burned. You can get parts at this link:
http://www.repairclinic.com/Haier-Parts?gclid=CMajgvvFpqYCFYdi2godeBsFmA
Jan 06, 2011 | Haier HSB03 Compact Refrigerator
I have a Haier HMSE03WAWW Compact Refrigerator and it was running fine for about a year. All of a sudden it stopped running. I unplugged it for a day and plugged it back in and it started running. Got a...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 05, 2010 | Haier HMSE03WAWW (33 cu ft) Compact...
Honeywell compact refrigerator model # 88031not cooling.
Honeywell compact refrigerator model # 88031 making a clicking noise, not cooling, interior light blinks, and the fans in back are not working properly....seems as if it's not getting full power. worked fine for about a year and justed stopped.
Mar 18, 2010 | Refrigerators
New fridge
Hi!!! sorry to inform you , but you have a seal system problem.Them haier frigs have problems with the seal system..You i\either have a restriction or a leak in the evaporator..
Jan 14, 2009 | Refrigerators
Compressor on Haier hmse03waww mini-frige shuts off after 10-20 minutes and is hot to the touch.
If the temperature in the refrigerator is correct then this is proper function for the compressor. It should run until the desired temperature is reached then shut off. The compressor also gets really warm. If the compressor is shutting off prior to the correct temperarure being reached then you may have a compressor problem. If the compressor is bad and our of warranty, it is time for a new refrigerator. If it is still under a warranty, call for factory service. Good luck, and I hope this helps.
Mike
Sep 29, 2008 | Haier Refrigerators
Haier hrt02wnc compact refridgerator 1.7 cubic
I have a Haier mini fridge model hrt02wncbb it will not cool, The fan runs all the time. I keep it in my class at school but there is five other mini fridge they work find what should i do?
Apr 13, 2008 | Haier HRT02WNC Compact Refrigerator
Refrigerators Logo
361 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
