Print head noi installed
I have a Cabnnon Pixma 1500 printer installed on my computer. Suddenly I have started getting warning 'Print Head Not Installed'. I removed the print head & reinstalled yet it is not reading it & warning is repeating. Reinstalling the printer also did not help. What should I do?
  • tomos10 Jun 10, 2008
    I keep getting an error message saying print head is not installed.  I have turned on and off a couple of times to no avail.
    Scholar:
  • 141 Answers
Sometime the problem is the cartridge it self....And sometime it's the cartridge beside the one that is always warning.
Posted on Mar 25, 2008
SOURCE:
PRINTER SUDDENLY PRINTING VERY FAINT ALL INK FULL
It is most likely a blockage in the print-head. Run a nozzle check to see if all the jets are firing cleanly. If there are colours missing or "scratchy" run a deep cleaning cycle. If that doesn't improve the nozzle check, remove the cartridges and then the print-head. Run the underside of the print-head under hot water from the tap for a moment. dry it with a paper towel and re-install the print-head and cartridges. Give a standard clean and re-try. If it still doesn't work, the print-head is probably dying.
Mar 11, 2015 | Canon Office Equipment & Supplies
Printhead pixma ip 1000
wipe out print head connection point with arosel and instal head again
Dec 28, 2013 | Canon PIXMA iP1600 Printer
My printer sends through blank pages
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Feb 17, 2013 | Canon Pixma iP4500 InkJet Printer
Canon mp258 printer can not fine driver on my computer it only picked up the scander part
Possible causes of failure:
1. Error install driver process
How to install the correct driver canon
- Do not connect the printer to the computer. So, turn on the printer but do not connect the printer to the computer.
- Insert the driver CD and do the install process.
- At the time of the install process, it would appear the request connect the printer to the computer.
- Connect the printer to the computer. The computer will detect the printer, and install process will continue until completed.
- Then, press the START - Printers and Faxes - Right click the Canon MP258 series Printer - select Printing preferences - click Maintenance - Print head alignment - Align print head - OK - etc. Perform print head alignment until completion (approximately 3 times the heat print alignment). Print head alignment, to configure the printer and computer.
- After the print head alignment is completed, the printer is ready to use.
Install the wrong driver canon
- Connect the printer to the computer, then perform install process.
- Solution: disconnect the USB cable from the printer to the computer, then uninstall the drivers and applications that are already installed, then restart the computer.
- Repeat the process to install in the correct way.
2. Drivers don't support the operating system
If you need a Canon MP258 driver download here:
Canon Support and Download
- Follow the link
- Product category = Inkjet Multifunctional Printers
- Product series = PIXMA
- Model = PIXMA MP258
- Document type = Drivers & Software
- Click Find
- Select OS = example : Windows 7
- Download driver printer; MP250 series MP Driver Ver.1.04
- Download driver scanner; MP Navigator EX Ver. 3.04
I hope this information helps. Thank you for using FixYa!
Oct 07, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Canon pixma ip 1500. Will not print black ink. Have cleaned, and deep cleaned nozzles. Color prints good, black does not print at all.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jul 01, 2011 | Canon Office Equipment & Supplies
Canon PIXMA iP3000 inkjet printer- print head is overheating
Try to remove the print head from printer and turn it on.If starts you need to replace the print head.It's part number is QY6-0064 becouse the old print head QY6-0034 is discontinued.
Oct 09, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Suddenly starting receiving "print head not installed" error
open your printer head and see it is burning change it and buy new
Jun 29, 2009 | Canon Pixma iP6000D InkJet Photo Printer
Canon Pixma iP2000
try cleaning the print head as follows, otherwise a new print head.
OK, Canon will hate me for posting this.
1. Remove ink cartridges
2. Remove print head
3. go to sink or tub (stainless steel, not plastic type), pick up a roll of paper towel on the way.
4. Fold several layers of paper towel and place on flat surface.
5. Run hot water until HOT!
6. Turn hot water back to a dribble.
7. Run the dribbling hot water through print head, be careful not to wet the gold contacts.
8.When water running through print head is clear, place print head on paper towel.
9. Repeat number 7 and 8 until no colour shows on paper towel.
10. Gently DAB print head (DO NOT WIPE) inside and out with dry paper towel until dry.
11. I normally replace print head after drying, but you may wish to let it air dry overnight.
12. Replace print head in printer and install cartridges
13. Start printing.
I do this to all 4 of my Canon printers every 6 months or so.
If any colour fails to print after this process it means your print head probably needs replacing.
Jun 28, 2008 | Canon PIXMA iP2000 InkJet Printer
Canon pixma IP 1500
Seat the print head Below is the procedure for seating the print head and ink tanks:
  1. Open the printer's front cover.
  2. Raise the print head lock lever, and lower the print head lock lever firmly.
  3. Check if the ink tanks are installed properly.
    Ink tanks installed correctly
    Ink tanks installed incorrectly
  4. When installing the ink tanks, push the top of the ink tank until a click sound is made.
    Note: If the ink tanks are not installed properly, paper may not be fed properly, or ink may not be ejected.
  5. Close the front cover.
Dec 04, 2007 | Canon PIXMA iP1500 InkJet Photo Printer
558 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
