BOSE 39120-S3V-A61 SPEAKER assembly without user guide
Sir,
We are having only 6 nos. of BOSE 39120-S3V-A61 SPEAKER assembled in maxico but we ar not having user guide to make it operational.Please guide us fot the same to make spekers operational or free download of user s guide.The detail printed on speakers as described below.
39120-S3V-A61
spaeker assembly - 25 cms.
265263 - 001
ASSEMBLED IN MAXICO
265263 - 001
012404 - 001Regards.
Shailesh.
  • 616 Answers
Its MEXICO, and you can download the manual from RETREVO.COM
Posted on May 01, 2010
Looking for a manual for sony pcg-6j2l
The link to manuals for this item is:
https://www.ifixit.com/Device/Sony_VAIO_PCG-6J2L
The above link includes the following guides. Hope this helps!
Featured Guides:
Sony Vaio PCG-6J2L Optical Drive Replacement
9 Replacement Guides
Battery
Hard Drive
Internal Fan
Keyboard
Logic Board
Memory
Mouse Assembly
Optical Drive
Speaker Assembly
1 Repair Guide
Display Assembly
Nov 09, 2014 | Sony Computers & Internet
Need instructions to replace the passenger side mirror and the driver side tail light on a 1999 Ford Taurus 4-door sedan. Thank you, Gary S.
Section 01-09: Mirrors, Rear View 1999 Taurus/Sable Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 06/25/1998 Mirror, Power-Outside Rear View Removal
  1. Disconnect battery ground cable (14301).
  1. Remove front door trim panel (23942). Refer to Section 01-05.
  1. Remove radio speaker grille from cover assembly by squeezing or pinching between thumb and index finger.
  1. Remove two screws from cover assembly.
  1. Disconnect outside rearview mirror wiring connector (C515-LH; C615-RH). Remove wiring guides as necessary.
  1. Remove three outside rear view mirror retaining nuts. Remove outside rear view mirror (17682) while guiding wiring and connector through hole in door.
Item Part Number Description 1 17682 Outside Rear View Mirror 2 N621906-S36 Nut (3 Req'd) 3 F8DB-17D699-
AAW Cover Assembly Rear Substrate-LH 3 F8DB-17D698-
AAW Cover Assembly Rear Substrate-RH 4 N808968 Screw 5 F8DB-18B984-
AAW Speaker Grille-Standard (No Badge)-LH 5 F8DB-18985-
AAW Speaker Grille-Standard (No Badge)-RH 5 F8DB-18K901-
BAW Speaker Grille-Mach-LH 5 F8DB-18978-
BAW Speaker Grille-Mach-RH 5 F8DB-238A35-
AAW Speaker Grille-Blank (No Speaker)-LH 5 F8DB-238A34-
AAW Speaker Grille-Blank (No Speaker)-RH A - Tighten to 6-8 Nm (54-70 lb-in) ------------------
Trim Panel, Door Front
Removal
  1. Remove cover behind inside door handle.
  1. Remove screw from bottom of pull cup retaining front door trim panel to front door (20124).
  1. Remove three screws retaining front door trim panel to front door.
  1. NOTE: Do not attempt to remove more than one pushpin at a time.
    Using Rotunda Windshield and Molding Trim Removal Kit 107-R0401 or equivalent, remove the door trim panel by pulling one door trim panel pushpin at a time from the inner door skin.
  1. Disconnect electrical connectors as necessary. Refer to Section 01-14A.
Installation
  1. Follow removal procedure in reverse order.
  1. Replace all pushpins with new pushpins (N808994-S).
Front Door Trim Panel
Jan 14, 2011 | 1999 Ford Taurus
HOW TO ASSEMBLE A BISSELL 1699
BISSELL User’s Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User’s Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Assembly instructions will be included in the User's Guide.
Jul 25, 2010 | Bissell 1699 ProHeat Clear View Upright...
Anyone have any info on how i can update my Nurit 2085 from NOS 6 to NOS 7 I have heard that Verifone no longer supports the update.
VeriFone NOS 6 Operating System
VeriFone has assigned “end of life” status to the NURIT NOS 6 operating system. The terminal manufacturer previously announced that it would discontinue support for NOS 6 applications and stop offering NOS 6-to-NOS 7 upgrades on October 31, 2009.
On July 1, 2010, VeriFone will permanently shut down the loader required to convert from NOS 6 to NOS 7, making the upgrade unavailable to all models of NURIT terminals.
Merchants who wish to continue receiving support for impacted NURIT terminals are strongly encouraged to update their operating systems (if possible) prior to the July 1 deadline. Currently, there are three devices in the marketplace that may be eligible for the NOS 6-to-NOS 7 operating system upgrade:
  • NURIT 2085 03
  • NURIT 2085 04
  • NURIT 2085 21
To notify eligible First Data Independent Sales customers, they will include a message in the May 2010 month-end merchant statement (scheduled for release in early June) advising NURIT 2085 users to contact the Omaha POS Help Desk to update their terminals.
To do the same call on:866-783-8380
Jul 25, 2010 | VeriFone (M19755014US1) Magnetic Card...
Sharp AR-M201
no. i cant print. its showing red light and user guide attention
Jan 14, 2009 | Sharp AR-5316 Advanced Digital Imager...
How do i open the speaker to reconecct the wires inside?
It may not be only wires loose; the speaker(or speakers) may be damaged.
The common 'dynamic' speaker has a centered magnet in an assembly that extends the field of the magnet around a coil of wire on a form called the 'voice coil' that is firmly attached to the cone which moves in and out to 'pump' air and produce sound.
The clearances (gap) between the magnet assembly and the voice coil that sits in a narrow space between the magnet and the outer field piece is very small and critical.
Once positioned in the factory, glue is used to keep the field assembly from slipping and rubbing against the voice coil.
A strong shock will break the glue bond and, if severe enough, clamp the voice coil so it cannot move freely any more.
Since the Bose is a quality product, the cabinet may be assembled with glue and screws that are concealed.
If you know someone with a simple multimeter, they may be able to check at the terminals to see if there is any continuity from the terminals to the speaker.
If it doesn't have any, then perhaps only a wire is broken between the terminals and the speakers.
There is with high probability also a filter inside that separates the frequency range and sends the signal to separate speakers that produce different ranges of sound.
Jun 26, 2008 | Bose VCS-10 Center Speaker
Manufacturing DAte Of Sharp AR-507
that copier was in production between 1998 and 2000, dont quote me but i think it is 9/9/2000
Jan 31, 2008 | Sharp AR-507 Copier
Bose Acoustimass 6 No Subwoofer sound
take it back for refund or exchange without delay. Too many times, there are cases of faulty factory assembly. Most likely a poorly connected wire inside sub, which fell off after a few booms.
Jun 17, 2007 | Bose Acoustimass 6 III System
345 people viewed this question
 Grubhead
Grubhead
