Question about Canon PC-940 Black and White Copier
Canon PC941 Copier: Wide white bar down middle of copies
Copies are coming out with white (blank) bar down the middle of the page. Shaking the cartridge, which is almost new, helps for 1 or 2 copies but then the problem comes right back.
  • Anonymous Mar 31, 2014
    I still am using the original toner cartridge. I shake it, and the problem goes away for one or two copies, then it returns.
  • 86 Answers
Try replaceing the cartridge the toner has run out.
Any problems please get back to me.
Thank You
Posted on Mar 25, 2008
If I Have a streak down the middle of my copies, is it the roller? If not, what do I do ?
if its not the cartridge then its the fuser. buy a new copier, cheaper than fixing it.
Feb 10, 2015 | Canon PC170 Black and White Copier
Canon NP6221 copier makes copies with black streak down middle.
I suggest You Go to Official Canon Printer Page For You Canon Problem On Below Canon Page URL:
Copy Has Vertical Black Streaks In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Canon Printer Support
Feb 16, 2014 | Canon NP6221 Fuser Thermofuse
Canon NP6221 makes copies black and white with black streak down middle. How can it be fixed--works well otherwise.
They are manny cause of black copy.
1.over tone.
2.arching on main charger or dirt on main charger.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Brother Printer Support
Canon 7130 black and white copier. It looks like it is scanning but blank pages come out. I changed the toner and nothing. There are no alarms. also can this machine still be bought?
**** open the copier to see if the developer has fallen away from the drum unit or is the tab below where the toner is put in out of place. Sometimes, if out of place, when the copier closed shut the arm is moved to the right side of the post ( located on the lower half of the copier ) and move the developer away from the drum unit and produces light copiers or even blank copies.
May 17, 2011 | Canon NP 7130 Black and White Copier
What causes a line down the middle of copied pages
There is something on your scan glass. My guess is you are getting the line on your copies when you run the original through the document feeder. If you get lines through the document feeder but not on copies made off the glass then it is a dirty scan glass. There is a thin glass strip where the document feeder feeds the original. Usually something like white out that did not dry smears off an original and ends up on this thin strip of glass. Scratch it off with your finger nail and use some glass cleaner to resolve the problem. The scan glass is about 1/2 an inch to an inch wide and will be on the same side of the machine that the copier feeds the originals in on.
May 24, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
Dirty Copies and Black Line in Middle
the electrostatic drum probubly whent out if it was a cheap copier get a new one if it was expensive have it serviced or replace the drum yourself
Jan 22, 2009 | Canon PC-940 Black and White Copier
Canon NP 6218 B&W Copier
try also to change or to service the corona units both the upper corona in the drum unit and the the transfer corona assembly unit down the drum. ok try your best.
Sep 01, 2008 | Canon NP 7130 Black and White Copier
Canon PC-940 copier
sounds like white out on the scanner. clean all glass and slit glass
Jan 24, 2008 | Canon PC-940 Black and White Copier
Canon PC-940 Black and White Copier Logo
254 people viewed this question
old marine
old marine
