Question about Dell Dimension 2400 PC Desktop
Dell Dimension 2400 when picked up from customer computer would not load windows. 1st Attempt to Fix -cleaned and formatted hard drive by connecting drive to another computer and exploring as slave. -installed back in Dimension 2400, formatted when installed XP SP3 -install took approx. 20 hours!! -booted in safe mode and installed all current drivers (retrieved from dell website) -ran incredibly slow, CPU constantly spiked at 100% -upgraded from standard ram (512mb) to 1gb (512mbx2) -didn't seem to affect speed (Windows bootup takes approx. 10 mins and computer runs too slow to be considered usable) 2nd attempt to fix -left with 1gb of ram -changed to another HD (thinking I might have a corrupt HD causing speed issues) -XP sp3 install again took over 12 hours -computer will boot but still incredibly slow!!! Please help me! I cannot figure this out. I am a moderate computer user with enough knowledge to build and repair most PCs. I cannot seem to figure out what is causing this computer to be so slow. I do not know how the computer ran before my first attempt to fix but owner says the computer was usable. What would cause this computer to run so slow even after several clean installs? And why are my installs taking so ridiculously long? I have used my boot disk on tens of other computer and never had any issues with speed at all. Could it be CPU? MOBO? HD? RAM? Power Supply?
    Brigadier General:
  • 7,191 Answers
From the description of the problem it looks like a hardware problem, most probably a HDD problem.
Try replacing the hard-disk and let us know the findings.
Thanks for using FixYa
Posted on May 12, 2010
Is wd1200jb-00gvc0 hard drive compatible with dell dimension 2400
That is a western Digital Hard drive compatible with most computers even Dell Computers
May 15, 2014 | Dell Dimension 2400 PC Desktop
My Dell Dimension 2400 refuses to load Windows XP
What happens?Does it hang on the loading page or does it restart itself before loading?
If it hangs on the loading page,press CTRL,ALT and DEL.This boots the system.
If it restarts itself,remove the hard disk and re-fix it again.Problem solved?
Remove the CMOS battery and the hard disk and re-fix them again.Problem solved?
If not,you may have to repair your operating system.
This how you do it:-
  • Remove your hard disk and enslave[fix it as a secondary drive] it on another machine with a good operating system.
  • Start the machine.Accept to run unnix[using two drives]
  • The machine will automatically detect your hard disk's failure on the operating system and repair the damaged files.
  • On completion and after Windows opens,turn off the machine and remove your hard disk.
  • Fix the hard disk now on your machine and start it.
Hope this helps.Thanks!
Please rate this answer.
Oct 31, 2011 | Dell Dimension 2400 PC Desktop
I wanted to wipe my entire hard drive on my old Dimension 8400 that contained windows xp on it and reinstall it with windows vista, which i have the cd for. however, when i did so, each time i try loading...
1. you will need to know 1st that the hard drive you are installing is compatible with the desktop.
2. Is the hard drive compatible with the new Operating system (VISTA).
3. Check to see if you have the hard drive properly inserted that is properly cabled and connected.This will render error in installation.
4. Make sure you are installing the Operating system correctly.
5. Some boot sectors become corrupt during a change in Operating system if the hard drive is not properly formatted.
6. Try formatting the hard drive again and re-installing.
Feb 12, 2011 | Dell Dimension 8400 PC Desktop
How do I clean my hard drive before i get rid of my computer?
With a floppy or cd do a reformat. Do it this way
Format c:/ s
What you are telling the computer is system format so when the next person loads windows, windows will see the harddrive
Jul 25, 2010 | Dell Dimension 2400 PC Desktop
Dell dimension 2400 desktop-2003 model
Michael
Looks like a hard drive failure- simple as that. You can try a number of things but as far as my experiance goes the hard drive is dead. You either need a new hard drive or better a new computer.
Dont want to give false hopes...
regards
keshey
Feb 16, 2009 | Dell Dimension 2400 PC Desktop
Hard drive crashed
It all depends. Best bet is take it to a data recovery professional & see if they can recover anything for you. Hope this helps.
Feb 10, 2009 | Dell Dimension 2400 PC Desktop
Dell dimension blue screen stop error
When you start up computer press F12 to force computer to load from CD/DVD rom . Once it detects cd follow on screen instructions. If for some reason it doesn't work then try another cd , might need cleaning or try another CD/DVD rom if you have more the one in you system.
Aug 03, 2008 | Dell Dimension 2400 PC Desktop
Hard drive
You will need to try a recovery disk or a working version on windows XP or Vista to boot from and repair, or format hard drive.
Jul 31, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 Freezes frequently
check inside the case of the computer to make sure that the interface cable between the hard drive and the motherboard are fully connected. Also check to see if the RAM modules are fully inserted into their slots. If not, they try removing them one by one, until the computer starts up faster. If this doesn't fix it, then try a new hard drive, and interface cable.
Feb 21, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
27 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
