Question about Pyle Pl1157rd Led Brake Lights Light Bulbs Pl1157rd
The left one quit working about 6 weeks ago today
2005 honda civic ex brake lights quit working. and it is not the bulbs. the left one quit working about 6 weeks ago today the right one quit working but the one in the middle still works
  • 1,868 Answers
Hello! a device called the Tail Light Relay; Located in the under dash fuse/relay box is the likely culprit...It controls the left/right brake lights but not the middle brake light...Also check that the L/R brake lights have a solid ground...Use an ohm meter...Zero ohms to negative battery terminal...
Guru........saailer
Posted on May 01, 2010
I have a 1997 Honda Civic 4 door my dash lights are out and the dinging to my headlights is not coming on and I checked every light bulb and every fuse I don't know what to . Is is the dimmer switch
HONDA ILLUMINATION NOT WORKING * HOW TO FIX ...
? 3:24
https://www.youtube.com/watch?v=oOHwDWjmYWU
Feb 28, 2011 - Uploaded by vehix411
No lights,cant see the dash lights,bad bulb,how to change bulb clucter ... i have a 2001 honda civic i installed a new radio andmy cluster lights are ... I just bought the computer or (multiplexer whatever) for my 1997 accord because my back tail lights won't turn on but I ... Martin Nikolov 4 months ago (edited).
Removing a Honda Civic instrument cluster - YouTube
? 4:01
https://www.youtube.com/watch?v=kzp1VqdlmU0
Oct 28, 2012 - Uploaded by mike937739
George L 4 months ago ... I used it to fix my burnt out check engine light bulb in my 97 civic. ... I have no light on my dashboard I already replaced the fuse but still nothing? so I'm ....2005 Civic cluster in 1997 Civic working!
1997 Honda Civic Instrument Panel Lights Problem ...
? 1:26
https://www.youtube.com/watch?v=mYVt93Rao6g
Mar 26, 2013 - Uploaded by fockyoumang
Dec 16, 2015 | Honda Cars & Trucks
The left blinker on my 05 Honda stops blinking when brake is pressed. When right blinker is on, the flashers come on. HELP????
This is a common problem check the ground on that tail lamp assembly as you step on the brake the power sent to the bulb can not find ground and is returning thru the turn signal bulb so 2 positive sources keep the bulb out.
Apr 22, 2014 | 2005 Honda Odyssey EX
Honda Civic Brake light Problem
sounds like a bad earth/ground to me, common fault with brake lights
Feb 23, 2014 | 1999 Chevrolet Tahoe
My brake lights work but my tail lights and reverse lights don't work. Also my dash lights quit when I changed the switch for my headlights.
Check your fuses. I had the same problem with a 90 Honda civic. Dash lights went out, tail lights also went out. Replaced 1 fuse and all came back on.
Jan 11, 2013 | 1996 Dodge Neon
I need the stereo code for my honda
GOOGLE radio code. you will need the serial number on the radio usually by removing it. or try www.car-radio-unlocking.co.uk usually a small fee.
Apr 29, 2010 | 1999 Honda Civic
The two tailights in the trunk of my 2005 honda civic si do not work. the bulbs and fuse are ok. is this a civic problem
Do the lights on the trunk operate when the parking lights are on, but do not light up when you apply the brakes? If so, this is normal. Only the outer red lights are brake & parking combination lights. The ones adjacent to the reverse lights on the trunk lid are parking lights only.
If the red lights in the trunk lid are not working at all, check the red/yellow and black/silver wires where they go from the trunk lid down into the right side of the trunk area. The wiring harness for the parking and reverse lights are contained in a piece of black tubing that is connected to the passenger's side trunk hinge.
I hope this helps! Good luck!
Feb 20, 2010 | 2005 Honda Civic
Daigram of 1995 Honda Civic EX plug clutch pedal ?
95 civic coupe ex brake lights wont work and the shifter locks in park position, what's wrong?
Sep 09, 2009 | 1995 Honda Civic
Headlight wont work
Did you try swaping bulbs from left to right to see if you got a bad bulb? Did you check voltage at the plug where the bulb itself plugs in? Test lights don't really show you the whole picture. Invest in a Voltage meter.
Jul 30, 2009 | 2003 Honda Civic
Brake lights do not illuminate.
test and replace the brake light swith if necessary
Apr 04, 2009 | 2004 Honda Civic
Left Brake light bulb 03 civic lx
This video will show you how to replace the taillight bulb in your 01-05 Honda Civic.
Oct 27, 2008 | 2003 Honda Civic
Pyle Pl1157rd Led Brake Lights Light Bulbs Pl1157rd Logo
172 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
