Question about Columbia Telecommunications Group GMRS/FRS 2-Way Radio
My gmrs 1 will not turn on with batteries installed. Purchased a set at a thrift store and dont have an account, want to know why they will not at least turn on.
  • 4 Answers
Are the batteries fully charged? Are the batteries inserted with the correct polarity? If still no job return them to the store for an exchange
Posted on Apr 30, 2010
Purchased trivial pursuit 90's second hand. missing board and directions. can we get a board anywhere and directions. we have a regular board.
Look on eBay or at local thrift stores. There are always trivial pursuit games at the thrift store
Feb 01, 2017 | Toys
Tip
Finding lost charge cords, connectors, & adapters for 1$
Thrift Stores usually have bins full of all kinds of cords; chargers, connectors, adapters-you name it-and only a dollar each! I've found everything from expensive, top-of- the-line USB to USB cords to the oddball power cord to my old waffle iron. No matter how old or how new, common or uncommon, digging through the bins at your local thrift store saves not only money, but time and effort as well.
on Mar 17, 2014 | Electronics - Others
Electric hair rollers
When I owned and used a set of these, probably Conair,
I did add a small amount of water to the well. This was in the early 80's.
Dec 13, 2017 | Kitchen Appliances - Others
How many watts do midland walkie talkie xt20 have?
These are FRS/GMRS (Family Radio Service/ General Mobile Radio Service) radios. The legal power limit for FRS is 500 milliwatts - or 1/2 watt. GMRS on the other hand is limited to a much higher 50 watt level. The wattage you transmit determines if you need to have a GMRS license. Most GMRS radios are in the .5- 5 watt range however.
The likelihood of your XT20 being a 1/2 watt out on both FRS & GMRS is very good. For Midland (or anyone else for that matter) to produce a radio with a 1 watt output that can run on just 3 "AAA" batteries would be quite the feat! If Midland did do this, the radio's battery life would extremely short. To balance the needs of light weight and battery life, output power needs to be reduced.
Claims of 20 miles is crazy. If you had these radios on mountain tops 20 miles apart - with a clear line of sight between them - MAYBE - you could hear one on the other. This would need to be done under only the most ideal conditions. The actual distance you can expect to get out of a pair of any brand FRS radios in "real world" conditions (line of sight blocked by trees and buildings) is about a mile.
An FRS/GMRS radio limited to 1/2 watt output when used on a GMRS frequency that is close enough to access a GMRS repeater system could easily cover 20+ miles. The key here is having a license and access to the repeater. Repeater owners take a dim view of unlicensed users access their repeater.
Channels 1 thru 7 are FRS and GMRS. That is, if transmitting .5 watts, you can use it as FRS. If transmitting more than .5 watts, you will need a valid GMRS license.
Channels 8 - 14 are expressly for FRS. Only .5 watts transmit power is permitted.
Channels 15 - 22 are expressly for GMRS at any transmit power up to 50 watts. Even if transmitting .5 watts, you MUST have a valid GMRS license on these frequencies.
I know - more infor than you wanted and no vclear cut number for wattage - but there's no info on these radios on Midland's site or anywhere else that I could find. Good luck!
Jun 16, 2012 | Midland XT20 Two Way Radio
How do I program a Midland GXT760VP4
After installing and charging the battery pack (or installing alkaline batteries), turn on the radio by turning . Then press Menu once to set your Channel. Press Menu additional times to set other features. To set the channel to listen to Weather Radio, continue pressing Menu to the Weather Channel sub-menu (Channel 1 is 162.400 MHz). If you press and hold Menu for more than 5 seconds with the radio in GMRS mode, the radio will scan all 10 weather radio channels.
Midland has the manuals to many of their products here: http://www.midlandradio.com/Two-Way-Owner-Manual . The direct link to the manual is http://www.midlandradio.com/Resource_/OwnerManual/201/GXT760%20Owner%27s%20Manual%20.pdf .
Please let me know if there is a specific item you want to set up on the GXT760VP4.
Nov 18, 2011 | Midland Radio Communications
Motorola SX700 battery drainage w/tactical mike
It is likely the mic set you are using is not made for the SX700 radio, and is drawing too much power from the radio. Some audio accessories draw more power than others. It is possible your mic set is intended for a professional model radio which would supply more power to the device. You should check with Motorola to see if they have a mic set similar to go with your SX700 radio. Here is a link to their online store: http://www.store.motorola.com/mot/en/US/adirect/motorola;jsessionid=130652F39955D9E9CA94908C45C73822.mot3?cmd=catDisplayStyle&entryPoint=adirect&catKey=601560&messageType=catDisplayStyle
Oct 18, 2009 | Motorola SX700R 12-Mile FRS/GMRS Radio...
I JUST PURCHASED THIS MONITOR THE HP PAVILLION F1703 FROM A THRIFT STORE FOR 10.00 IT TURNS ON ,YOU CAN SEE MY ICONS THEN IT TURNS OFF RIGHT AWAY. I DONT KNOW WHAT THIS CAN BE ? WHEN IT FIRST TURNS ON IT...
This is a commom problem on this monitor and the fix is easy. Remove the back cover and look for the inverter board (This is the board that the 4 backlights connect to) On this board you will see 4 coils. Re-solder these coils to the board (Its usually just one of them that causes the problem but to be safe I re-solder all of them) Re assemble and the monitor should then work fine.
Aug 14, 2009 | HP Computers & Internet
Programing helmet chatterbox to cell
Push and hold the GMRS-X1 intercom button and turn the unit on, continue holding the intercom button down until the display changes to "BT" and the bluetooth indicator flashes. - then seek device's on your cell as usual, pairing code is 0000
Jul 07, 2009 | Chatterbox GMRS-X1 (15 Channels) 2-Way...
I purchased a Leap Frog Read & Write Leap Pad Learning System in
I took the entire toy back to the store where I purchased it and exchanged it for a new one.
Nov 11, 2008 | Toys
Columbia Telecommunications Group GMRS/FRS 2-Way Radio Logo
101 people viewed this question
Top Columbia Telecommunications Group Radio Communications Experts
eradiostore
eradiostore
Michael
ka4iup
ka4iup
Are you a Columbia Telecommunications Group Radio Communication Expert? Answer questions, earn points and help others
