Question about Toshiba E-STUDIO 650 Copier
I have a 3520c Toshiba printer with an error cd70?
CD70 indicates Used toner bag mixing paddle locked.
U need to check following:
1. Do the paddles in the used toner bag rotate? If not, replace a new toner bag.
2. Is the used toner motor rotating? (Perform the output check: 03-414)
3. Is the used toner motor lock detection sensor operating normally? (Perform output check: 03- [FAX] ON/[2]/[G])
Posted on Jul 19, 2010
How do i get rid of blank lines in copies on my Toshiba studio 3530c
Make sure the toner waste container is empty and also the charger and glass cleaner brushes are pulled out and put back to ensure these are clean. See maintenance actions in this guide. http://www.eid.toshiba.com.au/customers/c_es4520c/manuals/pdf/Mash/OM/Quick%20Start%20Guide.pdf
Sep 12, 2014 | Toshiba E Studio 3520c 3530c 4520c Copier...
How to print on envelopes on both an e-studio 5520c and 3520c?
Setup printer settings are in the software, not the hardware.
Sep 05, 2014 | Toshiba E-studio 5520c Digital...
Error c970
1. Check and clean the main charger, replace if required.
2. Check and clean the transfer/sep. unit, replace if required.
3. Before you replace the HVT board, check HVT connector bracket (the black color plastic piece mounted on the machine frame where the main charger connects). If this part is damaged or cracked, the high voltage will arc through this, which can cause C970. (found in several machines).
Apr 22, 2014 | Toshiba E Studio 3520c 3530c 4520c Copier...
Toshiba 2820c service manuall
http://www.smpcshop.com/Toshiba-e-STUDIO-2020C-2330C-2820C-2830C-3520C-3530C-4520C-Service-Manual.html
Sep 28, 2013 | Office Equipment & Supplies
Cd70 error code for toshiba e studio 2330c
Mar 01, 2013 | Toshiba E-Studio 3511 Color Copier
Faint lines
Try replacing the roller, or maybe you moved it and is not in place- in the exact position.
Jun 29, 2012 | Toshiba E Studio 3520c 3530c 4520c Copier...
What does CD70 error message mean and how do i fix it. On the printer it says call for service
Waste toner bottle is overfull or you have a problem with the waste toner auger or drive. The simple thing to check is the waste toner container inside the front door and make sure it is not over full. Then check the tube that fits into the bottle for clogged toner. If these simpler things do not resolve the code then you may want to consider calling your local service provider as it gets much more technical from there. Including dis-assembling parts of the machine. Turn off main power to reset the code.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 30, 2010 | Toshiba E-Studio 3511 Color Copier
We have a toshiba stuioo 3520c colour photocopier, and need to scan and copy documents to a USB. hOW, PLEASE/
am i right in thinking this a newish machine-if so you should have the relevant information on the disks that came with the machine if not visit the toshiba web site.
Feb 03, 2010 | Toshiba Office Equipment & Supplies
Toshiba 3510c , error code cd70
Aug 11, 2009 | Toshiba E-STUDIO 650 Copier
695 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
