Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
Worked once..next time,no power,no lights,no heat
  • Euro-Pro Master
  • 43,501 Answers
Return it under warranty.. check the manuals link...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Posted on Sep 26, 2010
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
Sep 21, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
No power but lights flash
Is there a reset switch. Most vacuums have one some where near the bottom brush, to protect the vacuum from overload. If the vacuum tripped, the vacuum will not work until you've pressed the reset switch. If you can't find one, pls check manual.
Mar 04, 2014 | Sebo Automatic X1 Bagged Upright Vacuum
When do I know when my Shark cordless V2945Z is fully charged?
The light next to the power button will illuminate when the unit is charging and turns off once the charge is complete.
Jan 18, 2014 | Euro-Pro Shark Cordless Stick Vacuum...
Power steam elite not registering descale
We had this problem whilst still in warranty. Without question they sent a new iron. We have only used the di-ionised water in the new one making descaling much less painful
Jan 12, 2014 | Morphy Richards Power Steam Elite 42221...
Eureka powerline umc-18 vacuum quit working
The Motor has locked up due to over heating. Once that happens the only way to go is either replace the motor drive or get a new cleaner. Do not try and keep energizing the Vacuum as you could blow circuit-breakers or start an electrical fire.
Dec 18, 2013 | Eureka 1810 Central System Vacuum
It wont get hot
The manual for your EP961 says that it needs at least 10 minutes to heat up before it will produce heat. A yellow light will light up when it is ready. Did you wait the appropriate time? Also, there are 2 switches, one to start the system and another on the handle to start steaming once the water heats up.
Is this a new steamer?
If you have used it before,are familiar with it, followed the directions and still no steam, then I would contact the company for repair.
Hope this helps,
Handie Andie
Mar 25, 2011 | Euro-Pro EP961 Steam Vacuum
I have a Bissell ProHeat 2x, and I did something dum. I had some powdered cleaner that said it works with carpet cleaners-well I mixed it in-and the next time I tried to use it, nothing came out. So, I...
Heck yeah, give it a shot. Try running some water through it too- fill it up, heat it just to where it's hot and unplug it, shake it around and dump it out. Repeat. You might have to get a wire or something to go through and get the powder loosened between the boiler and nozzle, but if the stuff will dissolve in hot water then once you get it going a little it'll flow better the longer you keep heating it and putting new water it.
I say I think you should unplug it once it gets mildly hot the first few times because if there is a pile of the powder stuck to the side of the tank you may find that the tank gets very hot there and overheats/fails.
You should be able to clean the solenoid too, hot water is your friend.
lp
Jan 11, 2011 | Bissell Vacuums
Stop working. brush was cloged. It there a reset button?
i had a similar thing happen and just got off the phone with dyson. there is a resettable switch on the handle. they told me to start the vacuum in the upright position, put it in the non upright position, then push and hold in the beater bar switch which is located next to the on/off button for 10 seconds and the beater bar should start to function once again
Jul 15, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Green light on power nozzle of Kirby vacuum, Model G7D
The green light is just to inform you that the brushroll is spinning. there is a magnet on the brushroll that makes the green light come on every time it rotates. also why it looks like the light flickers because the magnet only makes contact once per rotation of your brushroll. Let me know if you have any other questions.
Jan 03, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Unit will not run
I DON'T KNOW WHAT YOU MEAN BY "F/C" LIGHT, BUT IF THE MACHINE IS OVER HEATING THE LIGHT LOOKS LIKE A THEMOMETER. IF OVER HEATING IS THE PROBLEM, ONCE THE MACHINE COOLS IT SHOULD WORK AGAIN.
Aug 30, 2007 | Electrolux Guardian Bagged Canister Vacuum
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Greg Cann
Greg Cann
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
