Question about Sony Playstation 3 (PS3) Console
My ps3 at times will randomly flash please reconnect controller and my controller will shut off until i reconnect it to the usb cable and hit the ps button. is there a logical explanation for this? Is this a problem anyone else has ever heard of?
    Problem Solver:
  • 10 Answers
Fsdfffff
Posted on Apr 30, 2010
I Got an speedlink SL-4451-SBK for ps3 and it wont connect
This works: Turn ps3 on. Plug the controller into the usb cable and into ps3. Then plug the dongle into other usb port. After a short time the dongle will flash quickly (this means it's in pairing mode - when the dongle flashes slowly it's too late). Press the PS/Home button as soon as you see the dongle fast flashing. All the LED's on the controller will begin to flash and after a short time one (or two) will remain solid. Immediately disconnect the charging usb lead from the controller and again the LED's will flash, push the PS/Home button again and after a short time one or two will remain solid. The controller should now be working. If the controller fails to respond repeat this process but make sure that you disconnect the dongle and reinsert (so you can see the fast flashing lights and try again).
Dec 02, 2012 | Video Game Consoles & Games
How to connect wireless ps3 controller
Connect the controller to the playstation with the usb cable which came with the PS3, then hit the PS button in the middle of the controller...and wait until the light stops blinking on the controller.
Jan 29, 2012 | Sony Playstation 3 (PS3) Console
My mad catz controller will not configure to my ps3.How can i do it wireless?
sir good day there are two way on how to configure your wireless controller to your ps3 console.... the automatic pairing and a manual pairing
first way an automatic pairing
1.turn on your ps3..
2.Connect the smaller end of the included USB cable to the PS3 controller.
3.Connect the opposite end into either USB port on the front of the PS3.
The pair light on the PS3 will flash. When it stabilizes, you can disconnect the USB cable
and use the controller wirelessly.
second way a manual pairing
1.. turn your ps3..
3.Connect the opposite end into either USB port on the front of the PS3. Press the "PS" button on the center of the PS3 controller. The pair light on the controller will flash. When it stabilizes, you can disconnect the USB cable and use the controller wirelessly.
you can try that 2 way on how to configure your controller to your ps3 console if this help you please rate me thank you sir..
Jun 12, 2011 | Mad Catz Call of Duty Black Ops...
Im trying to connect the newer ps3 to my dynex tv using the yellow,white and red cables. i plug it into the tv and hit video1 and it says "no signal detected" what do i do?
Are you coming from HDMI to AV?
If so:
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until you here 3 beeps. Let go.
It should ask you to connect your controller via usb and press the PS button in
the middle of your controller. There will be a menu with 6 options. Try 1-5.
Jan 24, 2011 | Sony Playstation 3 (PS3) Console
Everthing comes on but controller lights flash from 0-5 red lights and cannot start disc or film or game
It sounds like your controller has to be reset and linked with your PS3. Press the reset button on the controller with a pen or paper clip, then reconnect it via USB cable to your PS3. While red lights are blinking, hold down the PS button on the controller until it connects. If you have issues, I can give more clarification as needed. Thanks.
Nov 04, 2010 | Sony Playstation 3 (PS3) Console
PS3 controller has 4 red flashing. Console has green, display OK. No response from PS button with USB connect or not. 5volt on 1 USB is on and off, other OK Help please
4 flashing means it has a dead battery leave it plugged in with the system on. if that doesnt work change the cable reconnect and leave it to charge good luck
Sep 09, 2010 | Sony Playstation 3 (PS3) Console
PS3 Controller will only work when plugged into the USB
i had same problem turn off your system with controller plugged in to usb unplug controller remove the power cable for a couple of mins reconnect and use controller PS button to turn system on and it should be back to normal. it worked for me
May 31, 2009 | Sony Playstation 3 (PS3) Console
Dualshock 3 sixaxis why does it always need to be plugged in
Once the controller is plugged in and connected to the console, hold down the PS button to select "turn off the system." Once the system has completed shutting down, unplug the controller and press the PS button. The console should turn on. If so, the controller will connect wirelessly. Unfortunately you'll have to do this with each controller but it works every time.
Feb 19, 2009 | Sony Dual Shock 3 Controller for...
Controller still wont work
Hmm. I think i'll need a bit more info please.
When you reset your PS3 and the system's light goes red and you hit the PS button your controller the four lights just flash? Is that right? The only time your controller will "connect is when you plug it in with USB?
Try this. Turn your PS3 on. Press the reset button on the back of your controller and hold it for a few seconds, then press the PS button to see if it connects then. If it doesn't you could try removing the internal battery from the controller and putting it back in. That might clear up any settings that were saved in it.
Let me know how it goes.
Jun 24, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
78 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
