Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
Who can I call to look at my Laars Lite 2 pool heater that will not start? I am in Jackson, NJ.
  • 33 Answers
Call me I can help !
http://www.laarsman.co.uk 01903 240 320
Miles
Posted on Jun 05, 2010
Leaks
check gas pressure if not correct will overheat and will start leaking
Jul 07, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars Lite 2 Heater will not go on
make sure little pump is moving if not check syphon tube going to pressure switch if ok check pressure switch
Jun 29, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
Gas pool heater model no.lg125p laars lite 2 max.gas preesure 14.
should be between 9 and 10 on front side manifold side should be 3.5
Feb 10, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
How do I change a thermal coupler on a laars lite 2 pool heater?
ther is no thermos coupler in lite 2 it has a ignitor depending in what vintage 2 white wies go down either to a box in bottom middle or to lower-right burner check fuses in black cases first if ok change ignitor if bad change fuses
Aug 24, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars Lite 2 Heaters starts up (ignites) and shuts down in 2 secs
usually indicates a flame sensing problem. remove sensor and clean with steel wool .
Jun 23, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Pilot light on but heater will not start
check the high-limit switches. Under the inlet/outlet header. if either is open it will not allow you to fire up. my 150 degree switch was corroded and after jump9ng out, bam it worked.
May 25, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pool Heater repair
Could be a regulator fault, thermostat, flow switch (pump) or ignition fault get unit serviced by a competent gasfitter
Jul 19, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Heating & Cooling Logo
139 people viewed this question
Top Lite On Heating & Cooling Experts
1STHVACMAN
Paul Carew
Michael Galve
Michael Galve
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
